Nie daj się oszukać, sprawdź VIN i historię
Chcesz kupić, bądź sprowadzić auto..nie wiesz, które wybrać? Napisz o tym tutaj...
Moderatorzy: palio, jhosef, VIP
VIN
Post autor: VIN » wt maja 29, 2012 14:44
Zły numer, albo brak go w bazie.
Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
bth
Re: Nie daj się oszukać, sprawdź VIN i historię
Post autor: bth » wt maja 29, 2012 17:17
Uprzejmie proszę o sprawdzenie numeru VIN: WVWZZZ1HZTP048393
VIN
Post autor: VIN » wt maja 29, 2012 17:43
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1HZTP048393
Model Designation	golf cl
Date of production	21.08.1995
Model year	1996
Sales type	1H12F3
Engine code	AAM
Transmission code	CKX
Axle drive	4A
Interior trim code	RB
Roof color	B4
Exterior color / Paint Code	B4 / B9A
Activated carbon canister 	1E1 	Activated carbon canister
Additional body covers, side 	6EA 	Without additional side body covers (stone guard)
Additional child seat anchors 	3B0 	Without additional child seat anchor
Additional tires (winter tires) 	2WA 	Without additional tires
Additional tunnel cover 	4J1 	Floor tray, extension center console
Additional warning lights 	9TA 	Without additional warning lights
Air bag 	4UE 	Air bag for driver and front seat passenger
Antennas 	8L1 	Bright rod antenna
Anti-theft protection system 	7AA 	Electronic vehicle immobilization device
Antifreeze 	1C1 	Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Ashtray light 	8PB 	Ashtray light
Automatic transmission indicator light 	9FA 	Without automatic transmission indicator light
Backrest release 	3H3 	Backrest release for front seat(s)
Batteries 	J1L 	Battery 280 A (60 Ah)
Body measures 	5C0 	Without special body measures
Body style 	K8G 	Hatchback
Brackets 	3P1 	Bracket for first aid kit and warning triangle
Brake pad wear indicator 	9U0 	Without brake pad wear indicator
Brake type, front 	1LL 	Disc brakes, front
Brake type, rear 	1KB 	Drum brakes, rear
Braking systems 	1AG 	Nine-inch power brake
Bumper 	2JG 	Body-colored bumpers
CD changer/CD player 	7A0 	Without CD changer/CD player
Cassette and CD storage unit 	4W0 	Without cassette and CD storage unit
Catalytic converter control 	8KA 	W/o catalytic converter warning light
Cd enhancing underbody panel 	2D0 	Without cd enhancing underbody panel
Center high-mounted stop light 	8R0 	Without center high-mounted stop light
Center rear seat belts 	3C1 	Static lap belt, center rear
Chassis 	2E0 	Base chassis
Climatic zones 	0Y1 	Standard climatic zones
Clutch actuation 	1K0 	Without clutch actuation
Component part sets with country-specific design requirements 	B0X 	Component parts set, complying with vehicle type for Germany, various parts
Components with special surface appearance 	6FA 	Components without special surface appearance
Cruise control 	8T0 	Without cruise control system (CCS)
Cruise control warning and speed limit system 	6Y0 	Without cruise control warning system
Dashboard 	4N1 	Padded dashboard
Door and lid locking system 	4F0 	Mechanical locking system
Door and side pockets, rear 	4YA 	Without stowage box rear (door and side panel)
Door and side trim panels 	4AF 	Door and side trim panel in foam film and woven fabric
Door pockets, front 	3YH 	Door pockets, front
Doors 	0A1 	2 doors
Drive layout 	1X0 	Front wheel drive
Engine specifications 	M8M 	4-cylinder gasoline engine 1.8 L/55 kW Monomotronic, cataly. conv. MVEG 2/EU 3D base engine is T5U
Equipment levels 	A8C 	Comfort equipment
Exterior noise suppression measures 	2B0 	Without additional exterior noise suppression
Flame retardent materials 	4Q0 	No flame retardent materials
Floor coverings 	3MQ 	Ibolours floor covering
Floor mats 	0TA 	Without floor mats
Front fog light/additional headlight 	8WA 	Without front fog light
Front seats 	Q1A 	Standard front seats
Front spoiler 	5L1 	Front spoiler
Front stabilizer 	0AA 	Without front stabilizer
Front turn signal lights 	6Z1 	Yellow turn signal lights
Front underbody guard 	1SA 	Without additional front underbody guard
Fuel quantity for initial filling 	1Z0 	Initial standard fuel filling
Fuel tank treatment 	2LB 	Fuel tank with special material treatment
Fuel tank vent line 	1TB 	Fuel tank vent line with gravity valve and PVC breather hose
Gearshift boot/cover 	6R0 	Selector lever cover
Gearshift knob/handle 	6Q1 	Plastic gearshift knob/handle
Generators 	8GM 	Alternator 70 A
Glove compartment 	4Z2 	Lockable glove compartment door
Hand brake lever handle 	6PA 	Plastic hand brake lever handle
Headlight 	8BB 	Halogen headlight for driving on the right
Headlight activation 	8K0 	Without special headlight activation
Headlight washer system 	8X0 	Without headlight washer system
Headlight-range adjustment 	8Q1 	Headlight-range adjustment
Headrests 	3J7 	Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 	7E0 	W/o heat accumulator/auxiliary heating
Heated door lock cylinder 	9X0 	Without heated door lock cylinder
Heated washer nozzles 	9T0 	Without heated washer nozzles
Heating and air conditioning system 	9AA 	Manually controlled heating system
Horns 	8Y1 	Two-tone horn
Identification plates 	1EC 	Special identification plate
Ignition/starter switch locking system 	0RA 	Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 	2G1 	Insert for the filling up of unleaded fuel
Interference suppression 	8E5 	Local interference suppression for FM radio reception
Interior noise suppression measures 	3W0 	Without additional noise suppression measures for passenger compartment
Key for locking system 	8QA 	Key without LED
Label for brake-proportioning values 	0Q0 	Without label for brake-proportioning values
Lashing rings/rails for load restraint 	6B0 	Without lashing rings for load restraint
Left exterior mirror 	3BR 	Left exterior mirror: non-speherical, adjustable from inside
Lock operation for tailgate/trunk lid 	4E0 	Tailgate/trunk lid unlocking from outside
Luggage compartment cover 	3U1 	Foldable trunk cover
Luggage compartment floor covering 	6SC 	Tufted trunk floor covering
Luggage compartment lighting 	9E1 	Luggage compartment lighting
Luggage compartment lining 	5A2 	Comfort trunk lining
Manufacturing sequence differentiation 	0FG 	Mosel manufacturing sequence
Molding roof liner 	6NA 	Unsplit molding roof liner
Multi-function display/trip computer 	9Q0 	Without multi-function display/ on-board computer
Nameplate set 	0ND 	Nameplate set "TDI"
Night vision system 	9R0 	Without night vision system
Outer rear seat belts 	3ZB 	3-point seat belts, outer rear with ECE label
Paint preservative/transit coating 	5K0 	Without surface protection, with additional transit coating
Partition 	3CA 	Without partition
Preparation for sound combination for rotating emergency light 	9F0 	Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 	9D0 	Without preparation for two-way radio installation
Proportioning valve 	1H1 	Load-sensitive proportioning valve
Protective side molding 	4B1 	Protective side molding
Radiator grille 	6KA 	Radiator grille
Radios 	8AB 	Radio "alpha"
Reading light 	8S1 	Reading light front
Rear axle 	0N2 	Heavy-duty rear axle
Rear cargo area 	3GA 	Without cargo area
Rear fog light 	8TC 	Rear fog light for driving on the right
Rear headrests 	3Q0 	Without rear headrests
Rear license plate bracket 	6P1 	License plate bracket rear (ECE)
Rear seats 	3NB 	Rear seat bench/backrest, completely folding
Rear spoiler 	5J0 	Without rear spoiler
Rear stabilizer 	0BA 	Without rear stabilizer
Rear window wiper and washer system 	8M1 	Rear window wiper and washer system with intermittent control
Restraint systems, front 	3QT 	3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 	3AD 	Right exterior mirror: convex, adjustable from inside
Roof insert/convertible top 	3FA 	Without roof insert (standard roof)
Roof rails/roof load rack 	3S0 	Without roof rails/roof load rack
Seat adjustment 	3L0 	Without special seat adjustment
Seat belt check 	9P0 	Without seat belt reminder
Seat covering 	N2J 	Fabric seat covering
Seat heater 	4A0 	Without seat heater
Shock absorption/suspension, chassis 	1BA 	Standard suspension/shock absorption
Side and rear windows 	4KA 	Side and rear windows in clear glass
Side assist/lane departure warning 	7Y0 	Without lane change assistant
Side lights 	8F2 	Side turn signal lights
Spare wheel/breakdown set 	1G6 	Space-saving spare wheel
Speaker installation 	8RD 	2 speakers (passive)
Special alarm systems 	9A0 	Without taxi alarm system
Special color trim 	0UA 	Without special color trim
Special editions 	E0A 	No special edition
Special labels/plates 	0SA 	Without special labels/plates
Special registration measures 	3M0 	Without special measures
Speedometer cable and seal 	8CC 	Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 	7L0 	Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering 	1N1 	Power steering
Steering column systems 	2C0 	Standard steering column
Steering system arrangement 	L0L 	Left-hand drive vehicle
Steering wheels 	1MZ 	Steering wheel for air bag system
Sticker (customized or special edition) 	0KA 	Without stickers and badges
Supertone system and tone sequence control 	9J0 	Without supertone system and tone sequence control
Taillight assemblies 	8SA 	Taillight assemblies, standard design
Telephone/telematics 	9W0 	W/o car phone preparation/installation
Tires 	H4V 	Tires 175/70 R14 88H
Trailer hitch 	1D0 	Without trailer hitch
Transmission shafts 	1WB 	Transmission shafts w/ 100 mm in diameter
Transmission specifications 	G0E 	4-speed automatic transmission
Transmission types/gearshift mechanisms 	0G2 	Selector lever
Trunk sill protection 	2P1 	Plastic trunk sill protection
Type approval countries/countries with special requirements 	B01 	Type approval Germany
Vehicle class differentiation units/platform components 	0DG 	Installation differentiation for build status of vehicle class A3 (VW Golf/ Vento/Variant), unit components
Vehicle specifications 	F0A 	No special purpose vehicle, standard equipment
Wheel covers 	1NE 	Wheel center cover
Wheels 	C5Y 	Alloy wheels
Window regulator 	4R0 	Mechanical window regulator
Windshield glass type 	4GD 	Clear glass windshield
Windshield wiper intermittent control 	8N2 	Windshield wiper intermittent control infinitely variable
 	RAB
Base engine 	T5U 	4-cylinder gasoline engine 1.8 L unit 051.7
Control number (no PR-Family) 	S8E 	R-Line support
Control number (no PR-Family) 	S90
Instrument inserts 	U0C 	Instrument insert with tachometer clock and km/h speedometer
Tire suppliers 	V0A 	Tires w/o specification of tire brand
noomercy
Post autor: noomercy » czw maja 31, 2012 22:53
witam i z gory dziekuje. PILne!
WVWZZZ1HZVB063056
VIN
Post autor: VIN » pt cze 01, 2012 09:19
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1HZVB063056
Model Designation	golf gti
Date of production	14.10.1996
Model year	1997
Sales type	1H16M4
Engine code	AGG
Transmission code	DFQ
Axle drive	5S
Interior trim code	35
Roof color	D8
Exterior color / Paint Code	D8 / P3G
Additional body covers, side 	6ED 	Additional body cover on wheel arch and side sill for bumper without skirt
Antennas 	8L3 	Roof antenna
Brake type, front 	1LN 	Disc brakes, front
Brake type, rear 	1KK 	Disc brakes, rear
Braking systems 	1AC 	Anti-lock brake system (ABS)
Bumper 	2JE 	Partially painted bumpers
Center high-mounted stop light 	8R1 	Center high-mounted stop light
Chassis 	2E1 	"Plus" chassis
Clutch actuation 	1K1 	Mechanical clutch actuation
Components with special surface appearance 	6FE 	Body-colored exterior mirror housings and tailgate handle
Door and lid locking system 	4F1 	Central locking system
Doors 	0A1 	2 doors
Engine specifications 	M11 	4-cylinder gasoline engine 2.0 L/85 kW Simos, catalytic converter and MVEG 2 base engine is T8A
Equipment levels 	A8H 	Top sports equipment
Floor mats 	0TL 	Front and rear floor mats (leatherette binding)
Front fog light/additional headlight 	8WJ 	"Highway light"
Front seats 	Q1X 	Sports front seats with integrated storage trays
Front spoiler 	5L2 	Front spoiler
Front stabilizer 	0AC 	Front stabilizer
Front turn signal lights 	6Z4 	Turn signal lights with dark colored lenses
Gearshift boot/cover 	6R2 	Leather gearshift boot
Gearshift knob/handle 	6Q6 	Aluminum gearshift knob/handle
Generators 	8GD 	Alternator 90A
Hand brake lever handle 	6PC 	Leather hand brake lever handle
Headlight 	8BU 	Halogen headlight for driving on the right
Heating and air conditioning system 	9AB 	Manually controlled air conditioning
Interference suppression 	8E2 	Local interference suppression for FM/AM radio reception
Key for locking system 	8QC 	Key with light
Left exterior mirror 	3BS 	Left exterior mirror: aspherical, electrically adjustable and heated
Manufacturing sequence differentiation 	0FC 	Brussels manufacturing sequence
Multi-function display/trip computer 	9Q1 	Multi-function display/on-board computer
Nameplate set 	2VZ 	Nameplate set "GTI" (without model designation)
Navigation device 	7Q0 	Without navigation device
Proportioning valve 	1H0 	Without proportioning valve
Protective side molding 	4B3 	Protective side molding
Radiator grille 	6KG 	Radiator grille
Radios 	8UZ 	Radio preparation (for 4 speakers)
Rear seats 	3NC 	Rear seat bench/backrest, split folding
Rear spoiler 	5J1 	Rear spoiler
Rear stabilizer 	0BB 	Rear stabilizer
Right exterior mirror 	3AF 	Right exterior mirror: convex, electrically adjustable and heated
Seat adjustment 	3L3 	Manual height adjustment for front seats
Seat covering 	N2Z 	Seat covering for special editions
Side air bag 	4X0 	Without side air bag
Side and rear windows 	4KC 	Side and rear windows in heat-insulating glass
Side lights 	8F6 	Dark colored side turn signal lights
Spare wheel/breakdown set 	1G9 	Space-saving spare wheel for temporary use, radial tire (5-hole)
Speaker installation 	9VE 	Digital sound package
Special editions 	E2U 	GTI "Co-Branding"
Special labels/plates 	0SB 	Labels/plates in German
Steering column systems 	2C1 	Height adjustable steering column
Steering wheels 	2PZ 	Leather steering wheel for air bag system (rest-of-the-world) (lightweight design)
Taillight assemblies 	8SB 	Taillight assembly w/ dark colored lens
Tires 	H6E 	All-weather tires
Transmission specifications 	G0C 	5-speed manual transmission
Transmission types/gearshift mechanisms 	0G3 	Gearshift linkage
Wheel covers 	1NL 	Covers for alloy wheels
Wheels 	C2M 	Alloy wheels
Window regulator 	4R4 	Power windows with comfort operation and circuit breaker
Windshield glass type 	4GF 	Windshield in heat-insulating glass
 	RCT
Base engine 	T8A 	4-cylinder gasoline engine 2.0 L unit 037.K
Instrument inserts 	U1L 	Instrument insert w/ km/h speedometer, clock, tachometer and special color trim
 	WJ2
ksyniu22
Post autor: ksyniu22 » pt cze 01, 2012 14:20
VSSZZZ6LZ8R066716
a co powiecie o tym?
może ktoś za drobną opłatą sprawdzić historię serwisową??
Death_Proof
Post autor: Death_Proof » pt cze 01, 2012 15:33
ksyniu22 pisze:VSSZZZ6LZ8R066716
Kolega Fucker Ci pomoże.
~VAGSTYLE~
Palmoster
Post autor: Palmoster » pt cze 01, 2012 21:51
Bardzo proszę o sprawdzenie tego numeru vin: WVWZZZ1HZXK000712.
Z góry bardzo dziękuję ;)
neos50
Post autor: neos50 » pt cze 01, 2012 22:44
Witam Bardzo bym prosił o sprawdzenie numeru WVWZZZ9NZ2Y095888
wrzesiek
Post autor: wrzesiek » sob cze 02, 2012 10:30
Dziś planuję zakup. Bardzo proszę o sprawdzenie: WVWZZZ1JZ2W441324
Z góry bardzo dziękuję!
Hodowla [b]YORKOWA FRAJDA[/b] poleca szczeniaczki [b]Yorki[/b] i [b]Chihuahua[/b] z rodowodem.
[url]http://www.yorkowafrajda.za.pl[/url]
Dodaj nas do znajomych na Facebooku:
[url]www.facebook.pl/yorkowafrajda[/url]
VIN
Post autor: VIN » pn cze 04, 2012 17:56
Kod: Zaznacz cały
Vehicle Identification No.	VSSZZZ6LZ8R066716
Model Designation	ibiza sport
Model	IB
Date of production	02.10.2007
Model year	2008
Sales type	6L1524
Engine code	AXR
Transmission code	JXY
Axle drive	5S
Interior trim code	18
Roof color	Z4
Exterior color / Paint Code	Z4 / C9Z
"Multimedia", video/DVD/notebook connection 	9WC 	Without "Multimedia" in vehicle
Activated carbon canister 	1E0 	Without activated charcoal canister
Additional dust seals 	6U0 	Without additional seals outside
Additional instruments 	8LA 	Without additional instruments/switches
Air bag 	4UF 	Driver's and front passenger air bag with front passenger air bag deactivation
Air cleaner (engine) 	1L0 	Standard air cleaner
Air duct, front area 	VK0 	Air duct, standard
Backrest release 	5B0 	Backrest release for left front seat right front seat w/ "Easy Entry" funct.
Base engine 	T5X 	4-cylinder diesel engine 1.9 L unit 038.L
Batteries 	J0N 	Battery 330 A (61 Ah)
Body measures 	5C7 	Additional body measures
Body treatment 	6J1 	Special body treatment
Brackets 	3P0 	Without bracket for first aid kit and warning triangle
Brake type, front 	1LQ 	Front disc brakes with integrated adapter
Brake type, rear 	1KD 	Disc brakes, rear
Breakaway interior mirror 	4L2 	Dipping breakaway interior rear view mirror
Bumper 	2JV 	Body-colored bumpers
CD ROM/DVD/SD card 	7QA 	Without CD/DVD for navigation
Carrier frequency for radio remote control 	5D1 	Carrier frequency 433.92 MHz-434.42 Mhz
Center rear seat belts 	3C7 	3-point seat belt for center rear seat
Child seats 	QA0 	Without child seat
Chrome work package 	QJ1 	Chrome work package
Component part sets with country-specific design requirements 	B0C 	Component parts set, complying with vehicle type for Belgium, various parts
Components with special surface appearance 	6FF 	Body-colored exterior mirror housings and various add-on parts
Cruise control 	8T2 	Cruise control system (CCS) electronic
Cup holder 	4M5 	Cup holder
Customized installation 	FC0 	Without customized installation
Dashboard 	4N2 	Standard dashboard
Dashboard illumination 	7V0 	Standard dashboard illumination
Door and lid locking system 	4K3 	Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 	3LD 	Door and side trim panel
Doors 	0A1 	2 doors
Drawers under front seats 	QN0 	Without drawers under front seats
Electric interface for external use 	UF0 	Without electric interface
Emission standard 	0GG 	Emission standard EU4
Engine cover 	NM0 	Without engine cover
Engine specifications 	MS7 	4-cyl. turbo diesel eng. 1.9 L/74 kW TDI pump-jet injection system Base engine is T5X/T21/T71
Equipment levels 	A8F 	Sports equipment
Exhaust tailpipe 	0P6 	Rear exhaust tailpipe
Exterior mirror setting 	6XE 	Exterior mirrors: electrically foldable and electrically adjustable/heated
Exterior noise suppression measures 	2B2 	Additional exterior noise suppression
Fire extinguisher 	6A0 	Without fire extinguisher
First aid kit / warning triangle 	1T0 	Without first aid kit and warning triangle
Foot area lining 	QM1 	Foot area lining with cover
Fresh air intake for passenger compartment (with particulate filter) 	2V1 	Dust and pollen filter
Front fog light/additional headlight 	8WD 	Integrated front fog light
Front license plate bracket 	6W0 	Without license plate bracket front
Front stabilizer 	0AQ 	Front stabilizer
Fuel filler cap/door, locking option 	2W1 	Lockable fuel filler cap
Fuel systems 	0F9 	Cooled fuel system for diesel engine
Gearshift boot/cover 	6R1 	Leatherette gearshift boot
Gearshift knob/handle 	6Q2 	Leather gearshift knob/handle
General operating permit, alterations 	C28 	Operating permit, alteration
Glove compartment 	4Z4 	Glove compartment door without light
Grab handles at roof frame 	5N3 	Folding grab handles
Headlight 	8BG 	Twin-headlight for driving on the right, with integrated high beam
Heated rear window 	8P1 	Heated rear window
Heating and air conditioning system 	9AK 	Climatronic with impact pressure control free of cfc
Horns 	8Y4 	High-sounding horn
Identification plates 	1EX 	Special identification plate for EC for M1 passenger vehicle
Insert for the filling up of unleaded fuel/fuel type 	2G5 	Filler neck module 1 without insert
Installation differentiation for vehicle components 	0EJ 	Installation differentiation for transmission MQ 250 vehicle components
Interior light in driver compartment 	9GB 	Interior light with switch-off delay and door pillar switch
Key for locking system 	8QE 	Key for locking system with remote control
Left exterior mirror 	5SJ 	Left exterior mirror: convex
Left vanity mirror 	4SK 	Left vanity mirror not illuminated with cover and pocket
Lockable wheel bolts 	1PC 	Wheel bolts with anti-theft protection (unlockable)
Luggage compartment lining 	5A6 	Full fleece trunk lining
Luggage net/pocket on backrest(s) 	4U5 	Luggage pockets on backrest
Manufacturing sequence differentiation 	0FD 	SEAT manufacturing sequence
Mass damper for steering wheels 	1Q0 	Without mass damper for steering wheel
Nameplate set 	2VP 	Nameplate set "TDI" "I"
Owner's manuals 	0XN 	Information kit in French and Dutch
Paint preservative/transit coating 	5K1 	Paint preservative (wax)
Park distance control 	7X0 	Without park distance control
Pedal cluster 	VF0 	Standard pedal cluster
Pillar lining 	4XC 	Exterior pillar lining
Platform group class 	7PB 	Platform group class 2
Platform module floor pan, rear 	4P2 	Rear floor panel module, type 3
Radiator grille 	6KL 	Radiator grille
Radios 	8AA 	Without radio
Reading light 	8S0 	Without reading light
Rear axle 	0N7 	Heavy-duty rear axle (design 2)
Rear headrests 	3Q6 	Three rear headrests
Rear license plate bracket 	6P0 	Without license plate bracket rear
Rear seat catch 	6QA 	Rear seat catch
Rear spoiler 	5J4 	Body-colored rear spoiler
Restraint systems, front 	4QV 	3-point seat belts with electric tensioner and height adjustment, front
Right exterior mirror 	5RQ 	Right exterior mirror: convex
Right vanity mirror 	4TC 	Right vanity mirror with cover
Service interval prolongation 	QG0 	Without service interval prolongation
Shock absorption, chassis, front 	G19 	Front shock absorption
Shock absorption, chassis, rear 	UB1 	Rear shock absorption for sports design
Side air bag 	4X1 	Side air bag front
Side and rear windows 	4KX 	Side and rear windows tinted green hinged quarter window operated manually
Side lights 	7R3 	Side turn signal lights (white)
Smoking/non-smoking package 	9JD 	Smoking package, ashtray front
Socket 	7B0 	Without socket
Spare wheel/breakdown set 	1G2 	Steel spare wheel with original equipment tires
Speaker installation 	8RE 	4 speakers (passive)
Special editions 	E1J 	"Formula Sports II"
Special labels/plates 	0SG 	Labels/plates in French
Steering 	1N6 	Power steering
Steering column systems 	2C5 	Axial and vertical adjustable steering column
Steering wheels 	2PH 	Leather steering wheel
Taillight assemblies 	8SG 	Standard taillight assemblies (type 2)
Tire pressure warning light 	7K0 	Without tire pressure warning light
Tires 	H2J 	Tires 205/45 R16 83W
Tool kit and jack 	1S7 	Tool kit and aluminum jack
Transmission types/gearshift mechanisms 	0G4 	Cable gearshift
Type approval countries/countries with special requirements 	B02 	Type approval Belgium
Upgrading measures 	GP0 	Vehicles w/o special upgrade measures
Vehicle class differentiation units/platform components 	0CY 	Vehicle class differentiation 6L0
Vehicle type 	AZ0 	Vehicle with standard production scope
Washer fluid level indicator 	8W0 	Without washer fluid level indicator
Weight category front axle 	L39 	Suspension range 39 installation control only, no requirement forecast
Weight category rear axle 	0YB 	Weight range 2 installation control only, no requirement forecast
Wheel housing liners 	KG2 	Wheel housing liner front and rear
Wheels 	CM5 	Alloy wheels 6.5J x 16
Window regulator 	4R1 	Power windows
Windshield wiper arms/blades 	9PB 	Windshield wiper arms/blades with additional guide vanes
Windshield wiper intermittent control 	8N4 	Windshield wiper intermittent control with potentiometer (four speeds)
 	PB3
 	PF3
Front seats 	Q4H 	Comfort sports seats, front
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1HZXK000712
Model Designation	golf estate
Date of production	07.05.1998
Model year	1998
Sales type	1H50U4
Engine code	AKS
Transmission code	DGG
Axle drive	5S
Interior trim code	71
Roof color	T3
Exterior color / Paint Code	T3 / C6M
Backrest release 	3H0 	Without backrest release for front seats
Batteries 	J1P 	Battery 220 A (44 Ah)
Body style 	K8D 	Station Wagon Variant/Avant
Brake type, front 	1LY 	Disc brakes, front
Brake type, rear 	1KM 	Drum brakes, rear
Components with special surface appearance 	6FB 	Body-colored exterior mirror housings
Door and side pockets, rear 	4YB 	Stowage box rear (door and side panel)
Doors 	0A2 	4 doors
Engine specifications 	MV9 	4-cylinder gasoline engine 1.6 L/74 kW EU 3D base engine is T0C
Front stabilizer 	0AF 	Front stabilizer
Front turn signal lights 	6Z2 	White turn signal lights
Fuel tank vent line 	1TE 	Fuel tank vent line with gravity valve and second vent line with PVC breather hoses
Gearshift boot/cover 	6R3 	Rubber gearshift boot
Gearshift knob/handle 	6Q4 	Comfort gearshift knob/handle
General operating permit, alterations 	C02 	Operating permit, alteration
Lashing rings/rails for load restraint 	6B1 	Lashing rings for load restraint
Luggage compartment cover 	3U2 	Sliding trunk cover
Luggage compartment floor covering 	6SL 	Tufted trunk floor covering (cut pile)
Manufacturing sequence differentiation 	0FA 	Standard manufacturing sequence
Nameplate set 	1RX 	Nameplate set in base trim
Outer rear seat belts 	3ZE 	3-point seat belts, outer rear with height adjustment and ECE label
Protective side molding 	4B2 	Body-colored protective side molding
Radios 	8AD 	Radio "gamma"
Rear fog light 	8TF 	Rear fog lights, left and right
Rear headrests 	3Q1 	Rear headrests
Roof insert/convertible top 	3FE 	Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 	3S2 	Black roof rails
Seat adjustment 	3L1 	Manual height adjustment for left front seat
Speaker installation 	8RM 	8 speakers (passive)
Special editions 	E1A 	"Arte"
Sticker (customized or special edition) 	0KZ 	Stickers for special editions
Tires 	H0L 	Tires 195/60 R14 H
Trailer hitch 	1D2 	Trailer hitch, removable and lockable
Transmission shafts 	1WA 	Transmission shafts w/ 90 mm in diameter
Wheels 	C0L 	Alloy wheels
 	PHX
 	RCR
Base engine 	T0C 	4-cylinder gasoline engine 1.6 L unit 037.M
Control number (no PR-Family) 	S0B 	Veh. w/ engineering build status of current model year a. vehicle identification no. of next model year
VIN
Post autor: VIN » pn cze 04, 2012 18:02
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ9NZ2Y095888
Model Designation	polo tdi
Model	PO
Date of production	18.04.2002
Model year	2002
Sales type	9N1324
Engine code	AXR
Transmission code	EWT
Axle drive	5S
Interior trim code	VF
Roof color	7D
Exterior color / Paint Code	7D / B5N
Additional body covers, side 	6ER 	Without additional body covers, but with add. paint
Additional warning lights 	9TG 	Additional warning lights (door area) front
Air duct, front area 	VK1 	Air duct, type 1
Anti-theft protection system 	7AH 	Electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
Batteries 	J0L 	Battery 340 A (70 Ah)
Body measures 	5C6 	Additional body measures
Brake pad wear indicator 	9U1 	Brake pad wear indicator
Braking systems 	1AT 	Electronic stabilization program (ESP)
CD ROM/DVD/SD card 	7QB 	CD ROM (Germany)
CD changer/CD player 	7A2 	CD changer
Center sun visor 	GA1 	Center sun visor
Chrome work package 	QJ3 	Chrome package (type 2)
Cup holder 	4M0 	Without cup holder
Door and side trim panels 	3LJ 	Door and side trim panel in foam film, insert in leatherette
Doors 	0A2 	4 doors
Drawers under front seats 	QN1 	Drawer under left front seat
Electronic map cooling system 	QS0 	Without electronic map cooling system
Emission standard 	0GR 	Emission standard EU3 D4
Exhaust tailpipe 	0P0 	Rear exhaust tailpipe (standard)
Exterior mirror setting 	6XD 	Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 	2B3 	Additional exterior noise suppression (hood, capsule and dash panel)
Floor mats 	0TD 	Front and rear floor mats
Frame forestructure 	AC1 	Long frame forestructure
Fresh air intake for passenger compartment (with particulate filter) 	2V5 	Fresh air intake system with activated charcoal canister
Front license plate bracket 	6W1 	License plate bracket front (large)
Front stabilizer 	0AS 	Front stabilizer
Fuel filler cap/door, locking option 	2W0 	Fuel filler cap
Generators 	8GL 	Alternator 120 A
Grab handles at roof frame 	5N6 	Folding grab handles at roof frame soft fold-away
Headlight washer system 	8X1 	Headlight washer system
Heat accumulator system/additional heater 	7E6 	Electric auxiliary air heater
Heated washer nozzles 	9T1 	Heated washer nozzles, front
Inserts 	5TC 	Without decorative inserts
Interior light in driver compartment 	9GH 	Interior light with door pillar switches
Left exterior mirror 	5SL 	Left exterior mirror: aspherical
Left vanity mirror 	4SD 	Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 	4E5 	Tailgate/trunk lid unlocking from outside
Manufacturing sequence differentiation 	0FB 	Pamplona manufacturing sequence
Molding roof liner 	6NF 	Comfort molding roof liner unsplit
Multi-function display/trip computer 	9Q2 	Multi-function display/on-board computer with check control
Nameplate set 	1DG 	Nameplate set "TDI"
Navigation device 	7Q5 	Navigation system with black-and-white screen
Owner's manuals 	0VC 	Information kit in German
Pillar lining 	4XF 	Exterior pillar lining design 2
Platform group class 	7PA 	Platform group class 1
Radios 	8AY 	Radio/navigation system
Rear seats 	3NW 	Rear seat bench/backrest, split folding with center armrest
Right vanity mirror 	4TD 	Right vanity mirror illuminated
Seat covering 	N7F 	Partially leather seat covering, fine embossed
Seat heater 	4A3 	Seat heater for front seats separately controlled
Shock absorption, chassis, front 	G12 	Front shock absorption
Shock absorption, chassis, rear 	1JC 	Rear shock absorption for sports design
Socket 	7B2 	12-volt socket in luggage boot
Steering 	1N2 	Power steering electro-hydraulic
Steering wheels 	1MR 	Leather steering wheel
Telephone/telematics 	9W8 	Car phone preparation
Tires 	H0U 	Tires 195/50 R15 V
Vehicle class differentiation units/platform components 	0CL 	Vehicle class differentiation 6Q0- for build status Europe
Weight category front axle 	L14 	Suspension range 14 installation control only, no requirement forecast
Wheels 	C8M 	Alloy wheels 6J x 15
Window regulator 	4R3 	Power windows with comfort operation
Windshield wiper arms/blades 	9PE 	Windshield wiper arms/blades with spoiler wiper blade
 	PB7
 	PH3
 	PJ3
 	PSF
 	PTC
 	PTS
Service interval prolongation 	QG1 	Service interval prolongation
 	RLB
Control number (no PR-Family) 	SZ9 	Delivery by "Autostadt Wolfsburg"
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZ2W441324
Model Designation	golf tdi
Date of production	22.11.2001
Model year	2002
Sales type	1J1034
Engine code	AXR
Transmission code	EUH
Axle drive	5S
Interior trim code	17
Roof color	8E
Exterior color / Paint Code	8E / A7W
Additional warning lights 	9TB 	Additional warning lights (door area)
Anti-theft protection system 	7AB 	Electronic alarm system with vehicle immobilization device (for RoW)
Auxiliary heating 	9M0 	Without auxiliary/parking heater
Brake type, front 	1LS 	Front disc brakes with integrated adapter
Bumper 	2JB 	Standard bumpers
Cd enhancing underbody panel 	2D1 	Complete cd enhancing underbody panel
Center armrest 	6E0 	Without center armrest front
Chrome work package 	QJ0 	Without aluminum/chrome work package
Component part sets with country-specific design requirements 	B0A 	Component parts set without country-specific design requirement
Controls (steering wheels/steering column) 	4LA 	Without controls
Door pockets, front 	3YQ 	Door pockets without insert mats
Doors 	0A2 	4 doors
Engine compartment lighting 	9L0 	Without engine compartment lighting
Engine cooling system 	8Z5 	Not hot country
Exterior noise suppression measures 	2B1 	Additional exterior noise suppression
Floor coverings 	3MH 	Dilours floor covering w/o scuff guard
Front stabilizer 	0AL 	Front stabilizer
General operating permit, alterations 	C23 	Operating permit, alteration
Headlight 	8JS 	Twin headlight for driving on the right with clear lens
Heat accumulator system/additional heater 	7E3 	Sheathed type glow plug heater
Horns 	8Y0 	Single-tone horn
Inserts 	5MA 	Decorative inserts
Luggage net/pocket on backrest(s) 	4U0 	Without luggage nets/pockets on backrests
Lumbar support 	7P0 	Without lumbar support in seat backrests
Outdoor temperature gage 	9Y0 	Without outdoor temperature gage
Outer rear seat belts 	3ZG 	3-point seat belts, outer rear with height adjustment
Owner's manuals 	0VA 	Without information kit
Paint coating 	FB0 	Standard paint coating
Platform module floor pan, rear 	4P0 	Rear floor panel module, type 1
Radios 	8AS 	Radio "alpha Europa"
Reading light 	8S2 	One reading light front, two reading lights rear
Rear axle 	0N1 	Standard rear axle
Rear stabilizer 	0BC 	Rear stabilizer
Remote-controlled garage door opener 	VC0 	W/o remote-controlled garage door opener
Roll-up sun screen for rear and side windows 	3Y0 	Without roll-up sun screen
Rough-road/sports version 	2UA 	Standard design
Shock absorption, chassis, front 	G28 	Front shock absorption
Shock absorption, chassis, rear 	1JA 	Rear shock absorption, basic design 1
Smoking/non-smoking package 	9JB 	Smoking package, ashtray front and rear
Special editions 	E79 	"Special"
Steering wheels 	1MP 	Steering wheel for air bag system
TV reception/digital radio reception 	QV0 	W/o TV reception/digital radio reception
Throttle actuation 	0L2 	Electric throttle actuation
Tires 	H6S 	Tires 195/65 R15 V
Tray 	7N0 	Without tray on roof liner
Vehicle class differentiation units/platform components 	0CE 	Vehicle class differentiation 1J0
Weight category front axle 	L09 	Suspension range 09 installation control only, no requirement forecast
Weight category rear axle 	0YZ 	Without determination of weight category for rear axle
Wheels 	C3J 	Cast alloy wheels 6J x 15 offset 38 (1J0 601 025 Q)
 	PH4
 	PT1
 	PTB
Nameplates for sales name 	QD1 	Nameplates for sales name
 	RAA
Control number (no PR-Family) 	SA0 	Model year change calendar week 45
 	W52
volder
Post autor: volder » wt cze 05, 2012 15:28
Witam.
Bardzo proszę o sprawdzenie numeru
WVWZZZ9N28Y233175
Z góry dziękuję.
VIN
Post autor: VIN » wt cze 05, 2012 15:37
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ9NZ8Y233175
Date of production	16.05.2008
Model year	2008
Sales type	9N31M4
Engine code	BUD
Transmission code	JHQ
Axle drive	5S
Interior trim code	WV
Roof color	Z4
Additional warning lights 	9TC 	Additional reflectors (door area)
Battery/alternator capacity 	NY0 	Standard battery/alternator capacity
Brake type, front 	1LR 	Front disc brakes with integrated adapter
Dashboard 	4N0 	Standard dashboard
Dashboard illumination 	7V1 	Standard dashboard illumination
Delivery equipment 	2A0 	Without delivery equipment
Door and side trim panels 	3LX 	Door and side trim panel
Doors 	0A2 	4 doors
Drawers under front seats 	QN3 	Drawers under front seats
Engine cover 	NM1 	Engine cover
Engine specifications 	D4W 	4-cyl. gasoline engine 1.4 l/59 kW 16V Base engine is TT1
Equipment levels 	A8M 	Executive comfort equipment
First aid kit / warning triangle 	1T2 	Warning triangle
Foot area lining 	QM0 	Foot area lining without cover
Fuel systems 	1A3 	Fuel system for carburetor gasoline eng. with injector system without fuel return and modified injection pressure
Fuel tank treatment 	2LA 	Fuel tank without special material treatment
Glove compartment 	4Z1 	Standard glove compartment
Heating and air conditioning system 	9AP 	Climatic air-conditioning system (semi-automatic)
Insert for the filling up of unleaded fuel/fuel type 	2G7 	Filler neck module 1 with insert
Installation differentiation for vehicle components 	0EM 	Installation differentiation for transmission MQ 200 vehicle components
Lockable wheel bolts 	1PA 	Standard wheel bolts
Nameplate set 	0QK 	Nameplate set "1.4"
Owner's manuals 	0VZ 	Information kit in Hungarian
Paint preservative/transit coating 	5K7 	Transport protection film (minimum protection) with additional transport protection measures
Radios 	8UA 	Radio with CD player
Scuff plates 	7M5 	Without protective film for scuff plate
Seat covering 	N0J 	Knit cut pile seat covering
Shock absorption, chassis, front 	G27 	Front shock absorption
Shock absorption, chassis, rear 	1JP 	Rear shock absorption
Steering wheels 	1ME 	Steering wheel
Tires 	H2Z 	Tires 185/60 R14 T
Tray areas package 	QE1 	Tray areas package 1
Type approval countries/countries with special requirements 	B18 	Type approval Hungary
Upgrading measures 	GP1 	Vehicles with special upgrade measures
Weight category front axle 	L10 	Suspension range 10 installation control only, no requirement forecast
Weight category rear axle 	0YC 	Weight range 3 installation control only, no requirement forecast
Wheel covers 	1NC 	Full wheel covers
Wheels 	C9G 	Steel wheels 6J x 14 Offset 43 (5-hole)
Window regulator 	4R2 	Power windows front, mechanical window regulators rear
 	PE2
 	PH1
 	PJ1
 	PTB
Front seats 	Q2J 	Comfort front seats
 	RBA
Base engine 	TT1 	4-cylinder gasoline engine 1.4 L unit 036.R
Wróć do „Chcę kupić auto”
Użytkownicy przeglądający to forum: W3C [Validator] i 22 gości
