elektryczny problem
elektryczny problem
Ostatnio moje auto zaczęło kopać przy wysiadaniu i to dość mocno. Po przeskanowaniu vcds'em wywaliło mi błędy takie jak poniżej. Jakieś pomysły jak na taką kulminację jak w totku?
Address 01: Engine Labels: 06A-906-033-BGU.lbl
Part No: 06A 906 033 CA
Component: SIMOS71 1.6l 2VG 5755
Revision: --H03--- Serial number: VWZ7Z0D0361555
Coding: 0000071
1 Fault Found:
19617 - Linear Oxygen (Lambda) Sensor B1 S1; Pump Current Wire: Open Circuit
P3161 - 008 - Implausible Signal - MIL ON
Freeze Frame:
RPM: 1408 /min
Bin. Bits: 00001000
Voltage: 4.960 V
Voltage: 0.000 V
RPM: 1280 /min
Bin. Bits: 00100000
Voltage: 5.100 V
Voltage: 0.000 V
Readiness: 0000 0000
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
1 Fault Found:
00470 - Combination comfort Databus in Single Wire
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 125028 km
Time Indication: 0
Date: 2000.00.00
Time: 17:48:50
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX1.lbl
Part No: 1K0 959 701 G
Component: Tuers
Coding: 0000054
Shop #: WSC 01392 785 00200
VCID: 326F1EFBD10B
1 Fault Found:
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX1.lbl
Part No: 1K0 959 702 G
Component: Tuersteuergeraet 09 0147
Coding: 0000054
VCID: 33611BFF2E11
1 Fault Found:
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
VCID: 306B14F3DF07
1 Fault Found:
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
VCID: 316D11F7D40D
1 Fault Found:
Coding: 0000071
1 Fault Found:
Freeze Frame:
RPM: 1408 /min
Bin. Bits: 00001000
Voltage: 4.960 V
Voltage: 0.000 V
RPM: 1280 /min
Bin. Bits: 00100000
Voltage: 5.100 V
Voltage: 0.000 V
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 237
Mileage: 125028 km
Time Indication: 0
Date: 2000.00.00
Time: 17:48:50
Component: Tuers
Coding: 0000054
VCID: 326F1EFBD10B
1 Fault Found:
Coding: 0000054
VCID: 33611BFF2E11
1 Fault Found:
Coding: 0000016
VCID: 306B14F3DF07
1 Fault Found:
Coding: 0000016
VCID: 316D11F7D40D
1 Fault Found:
elektryczny problem
00470 - Grupowa magistrala danych układu komfortu w jednoprzewodowym trybie pracy. Przyczyną powstawania takiej usterki jest najczęściej uszkodzenie któregoś z przewodów magistrali CAN komfortu, lub niesprawność jednego z modułów podłączonych do sieci CAN.
Nie wiem czy to może być powód "kopania" ale jedyny błąd jaki masz to ten który Ci podałem.
elektryczny problem
Podpowiesz mi jak fizycznie szukać usterki? na razie wiem, że mogę sprawdzić kable w drzwiach czy nie są połamane itp. ale jeśli to nie to, to jak sprawdzić moduł? Czy mogę vcds'em mogę przejrzeć któreś konkretne grupy albo wykonać jakieś testy?
elektryczny problem
Nie znam sie na tym tak dobrze, ale vcds raczej tego nie wykryje. A masz jakies problemy z tym modulem? Nie dziala Ci centralka, szyby, czy cos? Jesli wszystko dziala to raczej nic sie ńie dzieje a auta czasem kopia pradem
elektryczny problem
Czasem samochody sie elektryzuja, kiedyś miałem Astre i potrafił tak kopać po paluchach że ręka odskakiwała. Od dawna tak masz? Tapicerka welurowa zapewne w aucie? Zalóż odrgomnik w aucie i nie bedzie problemu.
elektryczny problem
już założyłem ale zdarza się, że jeszcze lubi kopnąć, zastanawia mnie tylko nagromadzenie tych samych błędów we wszystkich drzwiach...
elektryczny problem
Witam.
Powiem że od ok. 2 tyg. mam golfa V i też mnie zastanawia że co wychodzę to mnie kopnie lub żonę jak wyjdzie pierwsza
Ale pod kompa nie podłączałem,nawet mi przez myśl nie przeszło że coś może być nie tak...
A wszystko działa ok.
Pewnie muszę kupić ten odgromnik i będzie po problemie
