zmontowanie skrzyni basowej
: pn lis 22, 2010 21:31
od nie dawna jestem posiadaczem głośniczka sony xplod XS-L121P5W
dane:
XS-L121P5W
Speaker Woofer 30 cm (12 in),
cone type
Peak power 1,200 W
Rated power 350 W
Impedance 4 Ω
Sensitivity 89 ± 2dB (1 W, 1 m)
Frequency response 18 – 2,000 Hz
Mass Approx. 4.2 kg (9 lb 5 oz)
per speaker
Supplied accessory Parts for installation
i wzmacniacza również sony xplod XM-GTR2022 (i tu z danymi zaczynają się schody bo nie wiem w które wieżyc)
* Max Power 1200W x 1
* RMS Power output @ 2 ohms: 600W x 2
* RMS Power output @ 4 ohms: 250W x 2
* Variable 50-300Hz low pass filter with 12dB per octave slope
* High level sensing power on
* RCA and speaker level inputs; line level thru-put
* Low boost 0-10dB (40Hz)
* Dimensions: 15.8"W x 2.2"H x 10.8"D
bądź
* GTR Series 2-Channel Class A/B Car Amplifier
* RMS Power Rating:
o 4 ohms: 202 watts x 2 chan.
o 2 ohms: 250 watts x 2 chan.
o Bridged, 4 ohms: 500 watts x 1 chan.
* Max power output: 1200 watts
* OTL Output Transformerless Circuit Pulse power supply
* LED power indicators
* Bass Boost/EQ details (0-10 dB bass boost at 40 Hz)
* 2/1 channel operation
* Speaker-level inputs with signal sensing for automatic turn-on
* Preamp RCA outputs
* 3-Way System Protection circuitry (thermal, overload, and speaker short protection)
* Removable top plate
* Heavy duty aluminum alloy inverted heatsink design for maximum heat dissipation
* Gold-plated RCA level inputs
* Gold-plated screw terminals
* Variable low-pass filter (50-300 Hz, 12 dB/octave)
* CEA-2006 compliant amplifier
* Frequency response: 20-20,000 Hz
* Dimensions: 10-7/8"D x 15-7/8"W x 2-1/4"H
* 4-gauge power and ground wiring is required for installation. Contact us for information regarding a discount on select amplifier kits when purchased together with this amplifier.
* 1-year SonicElectronix.com warranty
bądź
Features:
Class A/B
600W x 2 Max Power Output
202W x 2 into 4 ohms, 20Hz-20kHz, 1.0% THD
Variable 50-300Hz Lo-Pass Filter
-12dB/oct Selectable Slope
250W x 2 into 2 ohms, 20Hz-20kHz, 1.0% THD
Specifications:
Max Power (Watts): 1200
Ad Hoc Power into 4 ohms, THD%: 202
Ad Hoc Power into 2 ohms, THD%: 250
Bridged into 4 ohms, THD%: 500
Signal to noise ratio (dB): 93dBA
Frequency Response (Hz): 5-50kHz
Current Drain at rated output (A): 48A
Width (inch): 15.8
Height (inch): 2.2
Depth (inch): 10.8
i moje pytanie jest takie jaka skrzynie zmontować czy ma być zamknięta bass refleks czy jaka
i jak obliczyć odpowiedni litraż pod ten głośnik
mam skrzynie ale coś z nią jest nie tak a dokładnie z wyjściem powietrza tam gdzie jest ten plastikowy "wyfuk" tak jakoś dziwnie świszczy i wszystko psuje
typ muzyki przeważnie RAP, RNB, ogólnie czarne brzmienia z dobrym basem :]
dane:
XS-L121P5W
cone type
Peak power 1,200 W
Rated power 350 W
Impedance 4 Ω
per speaker
bądź
* RMS Power Rating:
bądź
Features:
Class A/B
Specifications:
Width (inch): 15.8
Height (inch): 2.2
Depth (inch): 10.8
