[mk4] Auto nie odpala, Immo?
piotrek233
Post autor: piotrek233 » czw cze 14, 2018 11:53
Auto nie odpala, niestety nie mam go przy domu... 1.9 TDI AGR, rok 2000 sterownik wywala, jestem w stanie sam go uruchomić? czy tylko laweta.
Address 01 -------------------------------------------------------
Controller: 038 906 012 K
Component: 1,9l R4 EDC 0000SG 2811
Coding: 00002
Shop #: WSC 01317
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 1J0 907 379 P
Component: ABS 20 IE CAN 0001
Coding: 03304
Shop #: WSC 01317
1 Fault Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 1J0 920 801 E
Component: KOMBI+WEGFAHRS. BOO V25
Coding: 01142
Shop #: WSC 00000
Ident.-Nr. WEGFAHRS.:VWZ6Z0X1273669
1 Fault Found:
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 01317
1 Fault Found:
Address 46 -------------------------------------------------------
Controller: 1J0 959 799 Q
Component: 2H Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 01317
2 Faults Found:
00913 - Window Regulator Switch: Front Right Driver (E81)
27-10 - Implausible Signal - Intermittent
marcin7x5
[mk4] Re: Auto nie odpala, Immo?
Post autor: marcin7x5 » czw cze 14, 2018 15:23
Immo albo ogólnie problem z zasilaniem sterownika. Kontrolka świec żarowych się zapala?
