[mk7] Pomoc w diagnozowaniu błędu
puncio1
Post autor: puncio1 » czw kwie 12, 2018 18:11
Koledzy co to za błąd co on oznacza?
Fresh Air Blower Front:
Refrigerant Pressure And Temperature Sender:
1 Fault Found:
1048833 - Function Limitation due to Compressor Shut-Off Request By Engine
B10F0 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 2
Reset counter: 8
Mileage: 22070 km
Date: 2018.04.11
Time: 05:43:15
Voltage terminal 30: 13.7 V
Compressor shut-off requirement: Shut-off of engine control module via CAN (T > 15 sec.)
Wróć do „Volkswagen: Golf - mk7 (2012 - )”
