Nie daj się oszukać, sprawdź VIN i historię
VIN
Re: Nie daj się oszukać, sprawdź VIN!
Post autor: VIN » ndz sty 23, 2011 21:17
kubik78 pisze:Proszę o sprawdzenie
WVWZZZ1HZWB066232
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1HZWB066232
Model Designation	golf tdi
Model	GO
Date of production	08.12.1997
Model year	1998
Sales type	1H1024
Engine code	ALE
Transmission code	ASD
Axle drive	5S
Interior trim code	71
Roof color	B4
Exterior color / Paint Code	B4 / B9A
Activated carbon canister 	1E0 	Without activated charcoal canister
Additional body covers, side 	6EA 	Without additional side body covers (stone guard)
Additional child seat anchors 	3B0 	Without additional child seat anchor
Additional tires (winter tires) 	2WA 	Without additional tires
Additional tunnel cover 	4J1 	Floor tray, extension center console
Additional warning lights 	9TA 	Without additional warning lights
Air bag 	4UE 	Air bag for driver and front seat passenger
Antennas 	8L1 	Bright rod antenna
Anti-theft protection system 	7AA 	Electronic vehicle immobilization device
Antifreeze 	1C1 	Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Ashtray light 	8PB 	Ashtray light
Automatic transmission indicator light 	9FA 	Without automatic transmission indicator light
Backrest release 	3H0 	Without backrest release for front seats
Batteries 	J0N 	Battery 330 A (61 Ah)
Body measures 	5C0 	Without special body measures
Body style 	K8G 	Hatchback
Brackets 	3P1 	Bracket for first aid kit and warning triangle
Brake pad wear indicator 	9U0 	Without brake pad wear indicator
Brake type, front 	1LY 	Disc brakes, front
Brake type, rear 	1KB 	Drum brakes, rear
Braking systems 	1AC 	Anti-lock brake system (ABS)
Bumper 	2JG 	Body-colored bumpers
CD changer/CD player 	7A0 	Without CD changer/CD player
Cassette and CD storage unit 	4W0 	Without cassette and CD storage unit
Catalytic converter control 	8KA 	W/o catalytic converter warning light
Cd enhancing underbody panel 	2D0 	Without cd enhancing underbody panel
Center high-mounted stop light 	8R1 	Center high-mounted stop light
Center rear seat belts 	3C1 	Static lap belt, center rear
Chassis 	2E0 	Base chassis
Climatic zones 	0Y1 	Standard climatic zones
Clutch actuation 	1K2 	Hydraulic clutch actuation
Component part sets with country-specific design requirements 	B0X 	Component parts set, complying with vehicle type for Germany, various parts
Components with special surface appearance 	6FE 	Body-colored exterior mirror housings and tailgate handle
Cruise control 	8T0 	Without cruise control system (CCS)
Cruise control warning and speed limit system 	6Y0 	Without cruise control warning system
Dashboard 	4N1 	Padded dashboard
Door and lid locking system 	4F0 	Mechanical locking system
Door and side pockets, rear 	4YB 	Stowage box rear (door and side panel)
Door and side trim panels 	4AF 	Door and side trim panel in foam film and woven fabric
Door pockets, front 	3YH 	Door pockets, front
Doors 	0A2 	4 doors
Drive layout 	1X0 	Front wheel drive
Engine guard 	1SA 	Without additional engine guard
Engine specifications 	M9Z 	4-cyl. turbo diesel engine 1.9 L/66 kW TDI with central EGR extraction base engine is T2F
Equipment levels 	A8C 	Comfort equipment
Exterior noise suppression measures 	2B5 	Additional exterior noise suppression
Flame retardent materials 	4Q0 	No flame retardent materials
Floor coverings 	3MQ 	Ibolours floor covering
Floor mats 	0TA 	Without floor mats
Front fog light/additional headlight 	8WH 	Front fog lamp and cornering lamp
Front spoiler 	5L1 	Front spoiler
Front stabilizer 	0AJ 	Front stabilizer
Front turn signal lights 	6Z2 	White turn signal lights
Fuel quantity for initial filling 	1Z0 	Initial standard fuel filling
Fuel tank treatment 	2LA 	Fuel tank without special material treatment
Fuel tank vent line 	1TB 	Fuel tank vent line with gravity valve and PVC breather hose
Gearshift boot/cover 	6R3 	Rubber gearshift boot
Gearshift knob/handle 	6Q4 	Comfort gearshift knob/handle
General operating permit, alterations 	C00 	Operating permit, initial registration
Generators 	8GL 	Alternator 120 A
Glove compartment 	4Z2 	Lockable glove compartment door
Hand brake lever handle 	6PA 	Plastic hand brake lever handle
Headlight 	8BB 	Halogen headlight for driving on the right
Headlight activation 	8K0 	Without special headlight activation
Headlight washer system 	8X0 	Without headlight washer system
Headlight-range adjustment 	8Q1 	Headlight-range adjustment
Headrests 	3J7 	Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 	7E3 	Sheathed type glow plug heater
Heated washer nozzles 	9T0 	Without heated washer nozzles
Heating and air conditioning system 	9AA 	Manually controlled heating system
Horns 	8Y1 	Two-tone horn
Identification plates 	1EX 	Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 	0RA 	Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 	2G0 	Without insert for the filling up of fuel
Interference suppression 	8E0 	Without interference suppression
Interior noise suppression measures 	3W0 	Without additional noise suppression measures for passenger compartment
Key for locking system 	8QA 	Key without LED
Label for brake-proportioning values 	0Q0 	Without label for brake-proportioning values
Lashing rings/rails for load restraint 	6B0 	Without lashing rings for load restraint
Left exterior mirror 	3BS 	Left exterior mirror: aspherical, electrically adjustable and heated
Lock operation for tailgate/trunk lid 	4E0 	Tailgate/trunk lid unlocking from outside
Luggage compartment cover 	3U1 	Foldable trunk cover
Luggage compartment floor covering 	6SC 	Tufted trunk floor covering
Luggage compartment lighting 	9E1 	Luggage compartment lighting
Luggage compartment lining 	5A2 	Comfort trunk lining
Manufacturing sequence differentiation 	0FC 	Brussels manufacturing sequence
Molding roof liner 	6NA 	Unsplit molding roof liner
Multi-function display/trip computer 	9Q0 	Without multi-function display/ on-board computer
Nameplate set 	2QY 	Nameplate set "TDI" in base trim
Navigation device 	7Q0 	Without navigation device
Night vision system 	9R0 	Without night vision system
Outer rear seat belts 	3ZE 	3-point seat belts, outer rear with height adjustment and ECE label
Paint preservative/transit coating 	5K0 	Without surface protection, with additional transit coating
Partition 	3CA 	Without partition
Preparation for sound combination for rotating emergency light 	9F0 	Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 	9D0 	Without preparation for two-way radio installation
Proportioning valve 	1H0 	Without proportioning valve
Protective side molding 	4B2 	Body-colored protective side molding
Radiator grille 	6KA 	Radiator grille
Radios 	8AS 	Radio "alpha Europa"
Reading light 	8S1 	Reading light front
Rear axle 	0N2 	Heavy-duty rear axle
Rear cargo area 	3GA 	Without cargo area
Rear fog light 	8TC 	Rear fog light for driving on the right
Rear headrests 	3Q0 	Without rear headrests
Rear license plate bracket 	6P1 	License plate bracket rear (ECE)
Rear seats 	3NB 	Rear seat bench/backrest, completely folding
Rear spoiler 	5J0 	Without rear spoiler
Rear stabilizer 	0BA 	Without rear stabilizer
Rear window wiper and washer system 	8M1 	Rear window wiper and washer system with intermittent control
Restraint systems, front 	3QT 	3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 	3AF 	Right exterior mirror: convex, electrically adjustable and heated
Roof insert/convertible top 	3FE 	Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 	3S0 	Without roof rails/roof load rack
Seat adjustment 	3L0 	Without special seat adjustment
Seat belt check 	9P0 	Without seat belt reminder
Seat covering 	N2Z 	Seat covering for special editions
Seat heater 	4A0 	Without seat heater
Shock absorption/suspension, chassis 	1BA 	Standard suspension/shock absorption
Side air bag 	4X0 	Without side air bag
Side and rear windows 	4KC 	Side and rear windows in heat-insulating glass
Side assist/lane departure warning 	7Y0 	Without lane change assistant
Side lights 	8F6 	Dark colored side turn signal lights
Spare wheel/breakdown set 	1G6 	Space-saving spare wheel
Speaker installation 	8RD 	2 speakers (passive)
Special alarm systems 	9A0 	Without taxi alarm system
Special color trim 	0UA 	Without special color trim
Special editions 	E1A 	"Arte"
Special labels/plates 	0SB 	Labels/plates in German
Special registration measures 	3M0 	Without special measures
Speedometer cable and seal 	8CC 	Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 	7L0 	Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering 	1N1 	Power steering
Steering column systems 	2C0 	Standard steering column
Steering system arrangement 	L0L 	Left-hand drive vehicle
Steering wheels 	2PY 	Steering wheel for air bag system (RoW) (lightweight design)
Sticker (customized or special edition) 	0KZ 	Stickers for special editions
Supertone system and tone sequence control 	9J0 	Without supertone system and tone sequence control
Taillight assemblies 	8SB 	Taillight assembly w/ dark colored lens
Telephone/telematics 	9W0 	W/o car phone preparation/installation
Tires 	H4V 	Tires 175/70 R14 88H
Trailer hitch 	1D0 	Without trailer hitch
Transmission shafts 	1WB 	Transmission shafts w/ 100 mm in diameter
Transmission specifications 	G0C 	5-speed manual transmission
Transmission types/gearshift mechanisms 	0G4 	Cable gearshift
Trunk sill protection 	2P1 	Plastic trunk sill protection
Type approval countries/countries with special requirements 	B01 	Type approval Germany
Vehicle class differentiation units/platform components 	0DG 	Installation differentiation for build status of vehicle class A3 (VW Golf/ Vento/Variant), unit components
Vehicle specifications 	F0A 	No special purpose vehicle, standard equipment
Wheel covers 	1NC 	Full wheel covers
Wheels 	C8E 	Steel wheels 6J x 14
Window regulator 	4R5 	Power windows with comfort operation and circuit breaker, mechanical window regulators rear
Windshield glass type 	4GF 	Windshield in heat-insulating glass
Windshield wiper intermittent control 	8N2 	Windshield wiper intermittent control infinitely variable
 	PN1
Front seats 	Q1A 	Standard front seats
 	RAK
Base engine 	T2F 	4-cylinder diesel engine 1.9 L unit 028.C
Instrument inserts 	U1L 	Instrument insert w/ km/h speedometer, clock, tachometer and special color trim
Tire suppliers 	V0A 	Tires w/o specification of tire brand
Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
djarek4
Post autor: djarek4 » wt sty 25, 2011 11:58
Witam czy można sprawdzić numer vin WVWZZZ3BZVE040284 z góry dzieki Arek
VIN
Post autor: VIN » wt sty 25, 2011 15:24
djarek4 pisze:Witam czy można sprawdzić numer vin WVWZZZ3BZVE040284 z góry dzieki Arek
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ3BZVE040284
Model Designation	passat saloon
Model	PA
Date of production	17.12.1996
Model year	1997
Sales type	3B2355
Engine code	AFN
Transmission code	DHF
Axle drive	5S
Interior trim code	HX
Roof color	J8
Exterior color / Paint Code	J8 / N5Y
Additional body covers, side 	6EP 	Additional stone guard body covers
Additional dust seals 	6U0 	Without additional seals outside
Additional tires (winter tires) 	2XB 	Winter tires 195/65 R 15 91H with steel wheel 6J x 15, offset 45 (5-hole) without full wheel cover (C0V)
Batteries 	J0R 	Battery 380 A (80 Ah)
Body style 	K8B 	Notchback
Brake type, front 	1LB 	Disc brakes, front
Bumper 	2JB 	Standard bumpers
CD ROM/DVD/SD card 	7QA 	Without CD/DVD for navigation
Carrier frequency for radio remote control 	5D0 	Without carrier frequency
Center armrest 	6E3 	Front center armrest
Center rear seat belts 	3C3 	Lap belt with retractor for the center rear seat
Component part sets with country-specific design requirements 	B0A 	Component parts set without country-specific design requirement
Cup holder 	4M6 	Cup holder
Dashboard illumination 	7V0 	Standard dashboard illumination
Door and lid locking system 	4F1 	Central locking system
Door and side trim panels 	3LC 	Door and side trim panel in foam film and woven fabric
Duty-free tires 	1V0 	Without duty-free and cost-free tires
Engine cooling system 	8Z5 	Not hot country
Engine specifications 	M6N 	4-cyl. turbo diesel eng. 1.9 L/81 kW TDI with MVEG 2 base engine is T1R
Equipment levels 	A8S 	Standard equipment
Exterior mirror setting 	6XD 	Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 	2B1 	Additional exterior noise suppression
First aid kit / warning triangle 	1T2 	Warning triangle
Front fog light/additional headlight 	8WD 	Integrated front fog light
Front license plate bracket 	6W1 	License plate bracket front (large)
Gearshift boot/cover 	6R2 	Leather gearshift boot
Gearshift knob/handle 	6Q2 	Leather gearshift knob/handle
General operating permit, alterations 	C01 	Operating permit, alteration
Hand brake lever handle 	6PC 	Leather hand brake lever handle
Headlight 	8JM 	Twin headlight for driving on the right, with integrated high beam
Heated door lock cylinder 	9X0 	Without heated door lock cylinder
Heated washer nozzles 	9T1 	Heated washer nozzles, front
Heating and air conditioning system 	9AB 	Manually controlled air conditioning
Inserts 	5MD 	Decorative aluminum inserts
Installation parts for engine (engine mount system) 	1VG 	Installation parts for four-cylinder engine
Interference suppression 	8E2 	Local interference suppression for FM/AM radio reception
Label for radio remote control 	7CA 	Without label for radio remote control
Left exterior mirror 	5SL 	Left exterior mirror: aspherical
Left vanity mirror 	4SD 	Left vanity mirror, illuminated
Lockable wheel bolts 	1PA 	Standard wheel bolts
Luggage compartment floor covering 	6SD 	Tufted trunk floor covering (dimensionally stable)
Luggage net/pocket on backrest(s) 	4U1 	Luggage nets/pockets on backrests
Lumbar support 	7P4 	Manually adjustable lumbar support in front seats
Malfunction display 	9HA 	Without additional malfunction display
Manufacturing sequence differentiation 	0FA 	Standard manufacturing sequence
Moldings 	4ZE 	Black moldings
Nameplate set 	2VP 	Nameplate set "TDI" "I"
Outdoor temperature gage 	9Y0 	Without outdoor temperature gage
Parking light indicator light 	8NA 	Without parking light warning light
Protective side molding 	4B1 	Protective side molding
Radios 	8AC 	Radio "beta"
Reading light 	8S4 	Two reading lights front, two rear
Rear cargo area 	3GK 	Without additional lower part for luggage compartment floor
Rear headrests 	3Q1 	Rear headrests
Rear seat catch 	6QB 	Locking rear seat catch
Rear seats 	3NZ 	Rear seat bench unsplit, backrest split folding
Right exterior mirror 	5RQ 	Right exterior mirror: convex
Right vanity mirror 	4TD 	Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 	3Y0 	Without roll-up sun screen
Roof insert/convertible top 	3FA 	Without roof insert (standard roof)
Safety certificate 	0LA 	Without special plates/stickers/ safety certificates
Seat adjustment 	3L3 	Manual height adjustment for front seats
Seat covering 	N0N 	Woven fabric seat covering
Seat heater 	4A3 	Seat heater for front seats separately controlled
Side air bag 	4X1 	Side air bag front
Side lights 	8F2 	Side turn signal lights
Ski bag 	3X0 	Without load-through provision
Socket 	7B0 	Without socket
Spare wheel/breakdown set 	1G2 	Steel spare wheel with original equipment tires
Speaker installation 	8RE 	4 speakers (passive)
Special editions 	E0A 	No special edition
Steering wheels 	2PX 	Leather trimmed sports steering wheel
Sticker (customized or special edition) 	0KA 	Without stickers and badges
Taillight assemblies 	8SA 	Taillight assemblies, standard design
Tires 	H6S 	Tires 195/65 R15 V
Transmission types/gearshift mechanisms 	0G1 	Gearshift lever
Vehicle class differentiation units/platform components 	0DE 	Installation differentiation for build status of vehicle class B5 (VW Passat)
Weight category front axle 	0JZ 	Without determination of weight category for front axle
Weight category rear axle 	0YZ 	Without determination of weight category for rear axle
Wheels 	C0V 	Steel wheels 6J x 15
Window regulator 	4R3 	Power windows with comfort operation
 	PH1
Front seats 	Q4H 	Comfort sports seats, front
 	RBB
Base engine 	T1R 	4-cylinder diesel engine 1.9 L unit 028.R
Instrument inserts 	U0C 	Instrument insert with tachometer clock and km/h speedometer
:popcorn:
aresek
Post autor: aresek » wt sty 25, 2011 18:18
Witam, proszę o sprawdzenie vw golf po nr vin. Bardzo zależy mi na informacji odnośnie wymiany rozrzadu. Naprawa była wykonywana w ASo vw. wvwzzz1jzyw226426 Z góry bardzo dziękuje!
Kamil83
Post autor: Kamil83 » śr sty 26, 2011 01:49
Hejka, właśnie zakupiłem swojego pierwszego VW i bardzo bym prosił o sprawdzenie po nr VIN (WVWZZZ1JZWB035362) z jakim kolorem wyjechał z fabryki i z jakim wyposażeniem. Z góry dziękuję
Fajnie być częścią stada VW
Golf IV 1.6sr AKL 98r. 74kw + sekwencyjna instalacja lpg BRC
VIN
Post autor: VIN » śr sty 26, 2011 10:45
Kamil83 pisze:Hejka, właśnie zakupiłem swojego pierwszego VW i bardzo bym prosił o sprawdzenie po nr VIN (WVWZZZ1JZWB035362) z jakim kolorem wyjechał z fabryki i z jakim wyposażeniem. Z góry dziękuję
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZWB035362
Model Designation	golf 1.6
Model	GOLF
Date of production	23.03.1998
Model year	1998
Sales type	1J12J4
Engine code	AKL
Transmission code	DLP
Axle drive	5S
Interior trim code	KM
Roof color	G9
Exterior color / Paint Code	G9 / C3K
Activated carbon canister 	1E1 	Activated carbon canister
Additional body covers, side 	6EJ 	Additional body cover on sill without wheel arch
Additional warning lights 	9TB 	Additional warning lights (door area)
Antennas 	8L3 	Roof antenna
Anti-theft protection system 	7AB 	Electronic alarm system with vehicle immobilization device (for RoW)
Auxiliary heating 	9M0 	Without auxiliary/parking heater
Batteries 	J1L 	Battery 280 A (60 Ah)
Brake type, front 	1LQ 	Front disc brakes with integrated adapter
Brake type, rear 	1KK 	Disc brakes, rear
Breakaway interior mirror 	4L2 	Dipping breakaway interior rear view mirror
Carrier frequency for radio remote control 	5D1 	Carrier frequency 433.92 MHz-434.42 Mhz
Cd enhancing underbody panel 	2D1 	Complete cd enhancing underbody panel
Door and lid locking system 	4K3 	Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 	4AR 	Door and side trim panel in foam film and circular-knit
Door pockets, front 	3YR 	Door pockets with insert mats
Doors 	0A2 	4 doors
Engine compartment lighting 	9L0 	Without engine compartment lighting
Engine specifications 	ME8 	4-cylinder gasoline engine 1.6 L/74 kW with multi-point injection, EU 3D base engine is T6H
Floor mats 	0TQ 	Front and rear floor mats (polypropylene)
Fresh air intake for passenger compartment (with particulate filter) 	2V5 	Fresh air intake system with activated charcoal canister
Front stabilizer 	0AM 	Front stabilizer
Fuel systems 	0F2 	Fuel system for carburetor gasoline engine
Fuel tank treatment 	2LB 	Fuel tank with special material treatment
Gearshift boot/cover 	6R1 	Leatherette gearshift boot
General operating permit, alterations 	C03 	Operating permit, alteration
Generators 	8GD 	Alternator 90A
Grab handles at roof frame 	5N6 	Folding grab handles at roof frame soft fold-away
Headlight 	8JS 	Twin headlight for driving on the right with clear lens
Headlight washer system 	8X1 	Headlight washer system
Heat accumulator system/additional heater 	7E0 	W/o heat accumulator/auxiliary heating
Heating and air conditioning system 	9AK 	Climatronic with impact pressure control free of cfc
Insert for the filling up of unleaded fuel/fuel type 	2G7 	Filler neck module 1 with insert
Inserts 	5MA 	Decorative inserts
Key for locking system 	8QE 	Key for locking system with remote control
Luggage compartment lining 	5A7 	Comfort trunk lining with service lid/ cover
Molding roof liner 	6NH 	Comfort molding roof liner unsplit roof cutout rear (radio antenna)
Multi-function display/trip computer 	9Q1 	Multi-function display/on-board computer
Nameplate set 	0QE 	Nameplate set "1.6"
Outer rear seat belts 	3ZG 	3-point seat belts, outer rear with height adjustment
Paint preservative/transit coating 	5K1 	Paint preservative (wax)
Platform module floor pan, rear 	4P0 	Rear floor panel module, type 1
Radiator grille 	6KG 	Radiator grille
Reading light 	8S2 	One reading light front, two reading lights rear
Rear axle 	0N1 	Standard rear axle
Rear seat catch 	6QA 	Rear seat catch
Rear seats 	3NW 	Rear seat bench/backrest, split folding with center armrest
Rear stabilizer 	0BC 	Rear stabilizer
Seat covering 	N0U 	Cut pile seat covering
Shock absorption, chassis, front 	1GA 	Front shock absorption, basic design 1
Shock absorption, chassis, rear 	1JA 	Rear shock absorption, basic design 1
Smoking/non-smoking package 	9JB 	Smoking package, ashtray front and rear
Socket 	7B2 	12-volt socket in luggage boot
Steering column systems 	2C5 	Axial and vertical adjustable steering column
Steering wheels 	1MP 	Steering wheel for air bag system
Throttle actuation 	0L0 	Mechanical throttle actuation
Tie down straps/net/pocket 	6M0 	Without tie down straps/net/pocket
Tires 	H1T 	Tires 175/80 R14 88H
Tool kit and jack 	1S7 	Tool kit and aluminum jack
Transmission types/gearshift mechanisms 	0G3 	Gearshift linkage
Vehicle class differentiation units/platform components 	0CE 	Vehicle class differentiation 1J0
Washer fluid level indicator 	8W1 	Washer fluid level indicator
Wheels 	C6D 	Steel wheels 6J x 14 Offset 38
Window regulator 	4R4 	Power windows with comfort operation and circuit breaker
Windshield wiper intermittent control 	8N4 	Windshield wiper intermittent control with potentiometer (four speeds)
 	PH2
 	PT1
 	PTB
Base engine 	T6H 	4-cylinder gasoline engine 1.6 L unit 06A.F (aluminum )
Front seats 	Q2J 	Comfort front seats
 	RBB
Control number (no PR-Family) 	S3K 	Pool campaign
Control number (no PR-Family) 	S4Q 	Plant employee leasing for Poland
Weight category front axle 	U22 	Suspension range 121
djarek4
Post autor: djarek4 » śr sty 26, 2011 18:39
Proszę o sprawdzenie numeru Vin WVWZZZ3Bzvp113563 z góry dziękuje i pozdrawiam Arek
VIN
Post autor: VIN » śr sty 26, 2011 19:54
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ3BZVP113563
Model	PA
Date of production	12.04.1997
Model year	1997
Sales type	3B2335
Engine code	AHU
Transmission code	DHL
Axle drive	5S
Interior trim code	GP
Roof color	G2
Exterior color / Paint Code	G2 / Y3D
Base engine 	T0T 	4-cylinder diesel engine 1.9 L unit 028.M
Brake type, front 	1LZ 	Front disc brakes, standard ventilation
Component part sets with country-specific design requirements 	B0B 	Component parts set, complying with vehicle type for Austria, various parts
Door and side trim panels 	3LD 	Door and side trim panel
Engine specifications 	M0T 	4-cyl. turbo diesel engine 1.9 L/66 kW direct injection base engine is T0T
Front fog light/additional headlight 	8WA 	Without front fog light
Gearshift knob/handle 	6Q1 	Plastic gearshift knob/handle
General operating permit, alterations 	C04 	Operating permit, alteration
Headlight 	8BG 	Twin-headlight for driving on the right, with integrated high beam
Manufacturing sequence differentiation 	0FG 	Mosel manufacturing sequence
Nameplate set 	2QK 	Nameplate set "TDI"
Outdoor temperature gage 	9Y1 	Outdoor temperature gage
Radios 	8AA 	Without radio
Speaker installation 	8RM 	8 speakers (passive)
Steering wheels 	2PQ 	Steering wheel for air bag system
Tires 	H6R 	Tires 195/65 R15 T
Type approval countries/countries with special requirements 	B12 	Type approval Austria
konrad79
Post autor: konrad79 » czw sty 27, 2011 15:57
Prosiłbym o sprawdzenie takiego vinu ,kolega chcę kupić ten samochód i jesteśmy ciekawi czy ma moze jakąś historię WVWZZZ1JZ1D650968
Vincent27
Post autor: Vincent27 » czw sty 27, 2011 19:19
Prosze o sprawdzenie tego num. Z góry dzięki
WVWZZZ1HZSW338325
Lead
Post autor: Lead » sob sty 29, 2011 16:43
Hej witam!
Słuchajcie mam okazję kupić ładnego MK4 z pakietem generation. Mam VIN, jeśli dało by się sprawdzić co i jak to byłbym BARDZO wdzięczny.
Pozdrawiam i z góry SERDECZNIE DZIĘKUJĘ.
WVWZZZ1JZYW506825
zanus
Post autor: zanus » sob sty 29, 2011 23:40
Witam, proszę o rozkodowanie passata 3bg vin WVWZZZ3BZ1P279948
Jlz
Post autor: Jlz » ndz sty 30, 2011 15:11
Proszę o sprawdzenie VIN
WVWZZZ1JZ3W183142
aerandin
Post autor: aerandin » ndz sty 30, 2011 19:24
Hej.
Czy możecie dla mnie sprawdzić ten VIN:
WVWZZZ1HZTW044036
Chcę się upewnić czy jest to zwykły Golf, czy Golf GTI :)
A dodatkowe informacje jak najbardziej mile widziane.
Wróć do „Chcę kupić auto”
Użytkownicy przeglądający to forum: Bing [Bot] i 12 gości
