Zna ktoś to R32?? - ogłoszenia sprzedaży golfów R
Forum entuzjastów Golfa R, R32
Moderatorzy: G0 Karcio, zlos, VIP
GORAJ
Post autor: GORAJ » wt mar 06, 2012 15:46
xxxPALUCHxxx, jak masz to daj :)
VIN
Post autor: VIN » wt mar 06, 2012 17:01
Ciekawa oferta, po vinie się wszystko zgadza nawet
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZ3D503471
Model Designation	golf r32
Model	GOLF
Date of production	24.04.2003
Model year	2003
Sales type	1J1RZ7
Engine code	BFH
Transmission code	GQV
Axle drive	6S
Interior trim code	JZ
Roof color	C7
Exterior color / Paint Code	C7 /
Activated carbon canister 	1E1 	Activated carbon canister
Additional body covers, side 	6EJ 	Additional body cover on sill without wheel arch
Additional child seat anchors 	3B0 	Without additional child seat anchor
Additional dust seals 	6U0 	Without additional seals outside
Additional tires (winter tires) 	2WA 	Without additional tires
Additional warning lights 	9TB 	Additional warning lights (door area)
Air bag 	4UE 	Air bag for driver and front seat passenger
Antennas 	8L3 	Roof antenna
Anti-theft protection system 	7AP 	Electronic vehicle immobilization device w/ alarm syst., passenger comp. control, backup horn and all door opening
Antifreeze 	1C1 	Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Automatic transmission indicator light 	9FA 	Without automatic transmission indicator light
Auxiliary heating 	9M0 	Without auxiliary/parking heater
Backrest release 	3H9 	Backrest release for front seats with "Easy Entry"
Batteries 	J1L 	Battery 280 A (60 Ah)
Body measures 	5C3 	Body measures for increased safety requirements
Body style 	K8G 	Hatchback
Brackets 	3P1 	Bracket for first aid kit and warning triangle
Brake pad wear indicator 	9U1 	Brake pad wear indicator
Brake type, front 	1ZT 	Disc brakes, front
Brake type, rear 	2EL 	Disc brakes, rear
Braking systems 	1AT 	Electronic stabilization program (ESP)
Breakaway interior mirror 	4L6 	Breakaway interior rear view mirror, automatically dimming
Bumper 	2JF 	Painted bumpers
CD ROM/DVD/SD card 	7QA 	Without CD/DVD for navigation
CD changer/CD player 	7A0 	Without CD changer/CD player
Carrier frequency for radio remote control 	5D1 	Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 	4W0 	Without cassette and CD storage unit
Cd enhancing underbody panel 	2D1 	Complete cd enhancing underbody panel
Center armrest 	6E0 	Without center armrest front
Center rear seat belts 	3C1 	Static lap belt, center rear
Chrome work package 	QJ1 	Chrome work package
Component part sets with country-specific design requirements 	B0F 	Component parts set, complying with vehicle type for Switzerland, various parts
Components with special surface appearance 	6FF 	Body-colored exterior mirror housings and various add-on parts
Controls (steering wheels/steering column) 	4LA 	Without controls
Cruise control 	8T2 	Cruise control system (CCS) electronic
Cup holder 	4M6 	Cup holder
Door and lid locking system 	4K3 	Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 	3LJ 	Door and side trim panel in foam film, insert in leatherette
Door pockets, front 	3YR 	Door pockets with insert mats
Doors 	0A1 	2 doors
Drive layout 	1X1 	Four wheel drive
Electronic map cooling system 	QS0 	Without electronic map cooling system
Emission standard 	0GG 	Emission standard EU4
Engine compartment lighting 	9L0 	Without engine compartment lighting
Engine cooling system 	8Z5 	Not hot country
Engine specifications 	D9J 	6-cyl. gas. eng. 3.2 L/177 kW 24V VR6 base engine is T31/T36/T3D
Equipment levels 	A9R 	Top sports
Exterior mirror setting 	6XN 	Exterior mirrors: electrically adjustable, separately heated
Exterior noise suppression measures 	2B1 	Additional exterior noise suppression
Fire extinguisher 	6A0 	Without fire extinguisher
First aid kit / warning triangle 	1T0 	Without first aid kit and warning triangle
Floor coverings 	3MF 	Dilours floor covering with scuff guard
Floor mats 	0TD 	Front and rear floor mats
Fresh air intake for passenger compartment (with particulate filter) 	2V5 	Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 	8WA 	Without front fog light
Front license plate bracket 	6W1 	License plate bracket front (large)
Front stabilizer 	0AT 	Front stabilizer
Front underbody guard 	1SA 	Without additional front underbody guard
Fuel filler cap/door, locking option 	2W0 	Fuel filler cap
Fuel quantity for initial filling 	1Z0 	Initial standard fuel filling
Fuel systems 	0F2 	Fuel system for carburetor gasoline engine
Fuel tank treatment 	2LB 	Fuel tank with special material treatment
Gearshift boot/cover 	6R2 	Leather gearshift boot
Gearshift knob/handle 	7F3 	Leather/wooden gearshift knob
General operating permit, alterations 	C30 	Operating permit, alteration
Generators 	8GL 	Alternator 120 A
Grab handles at roof frame 	5N6 	Folding grab handles at roof frame soft fold-away
Hand brake lever handle 	6PC 	Leather hand brake lever handle
Headlight 	8JM 	Twin headlight for driving on the right, with integrated high beam
Headlight activation 	8K0 	Without special headlight activation
Headlight washer system 	8X1 	Headlight washer system
Headlight-range adjustment 	8Q2 	Automatic headlight-range adjustment static
Headrests 	3J9 	Headrest for front seat
Heat accumulator system/additional heater 	7E2 	Heated crankcase ventilation system
Heated washer nozzles 	9T0 	Without heated washer nozzles
Heating and air conditioning system 	9AK 	Climatronic with impact pressure control free of cfc
Horns 	8Y1 	Two-tone horn
Identification plates 	1EX 	Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 	0RA 	Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 	2G7 	Filler neck module 1 with insert
Inserts 	5MD 	Decorative aluminum inserts
Installation differentiation for vehicle components 	0EN 	Installation differentiation for transmission MQ 350 vehicle components
Left exterior mirror 	5SC 	Left exterior mirror: aspherical (modified viewing field)
Left vanity mirror 	4SD 	Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 	4E0 	Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 	1PC 	Wheel bolts with anti-theft protection (unlockable)
Luggage compartment cover 	3U1 	Foldable trunk cover
Luggage compartment floor covering 	6SM 	Needle-punched trunk floor covering (Dilours)
Luggage compartment lining 	5A7 	Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 	4U0 	Without luggage nets/pockets on backrests
Lumbar support 	7P0 	Without lumbar support in seat backrests
Manufacturing sequence differentiation 	0FK 	Bratislava manufacturing sequence
Mass damper for steering wheels 	1Q0 	Without mass damper for steering wheel
Multi-function display/trip computer 	9Q1 	Multi-function display/on-board computer
Nameplate set 	2RC 	Nameplate set "R32" (without model designation)
Nameplates for sales name 	QD0 	Without lettering for sales name
Navigation device 	7Q0 	Without navigation device
Outdoor temperature gage 	9Y0 	Without outdoor temperature gage
Outer rear seat belts 	3ZM 	3-point seat belts, outer rear
Owner's manuals 	0XX 	Information kit in German (for export)
Paint coating 	FB0 	Standard paint coating
Paint preservative/transit coating 	5K1 	Paint preservative (wax)
Park distance control 	7X0 	Without park distance control
Partition 	3CA 	Without partition
Platform group class 	7PA 	Platform group class 1
Platform module floor pan, rear 	4P0 	Rear floor panel module, type 1
Preparation for sound combination for rotating emergency light 	9F0 	Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 	9D0 	Without preparation for two-way radio installation
Proportioning valve 	1H0 	Without proportioning valve
Protective side molding 	4B2 	Body-colored protective side molding
Radiator grille 	6KG 	Radiator grille
Radios 	8UT 	Radio "delta" (double-size standard radio)
Reading light 	8S2 	One reading light front, two reading lights rear
Rear axle 	0N5 	Standard rear axle
Rear cargo area 	3GA 	Without cargo area
Rear fog light 	8TC 	Rear fog light for driving on the right
Rear headrests 	3T6 	2 rear headrests height-adjustable
Rear license plate bracket 	6P1 	License plate bracket rear (ECE)
Rear seat catch 	6QA 	Rear seat catch
Rear seats 	3NC 	Rear seat bench/backrest, split folding
Rear stabilizer 	0BU 	Rear stabilizer
Rear window wiper and washer system 	8M1 	Rear window wiper and washer system with intermittent control
Restraint systems, front 	3QT 	3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 	5RC 	Right exterior mirror: convex (modified viewing field)
Right vanity mirror 	4TD 	Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 	3Y0 	Without roll-up sun screen
Roof insert/convertible top 	3FE 	Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 	3S0 	Without roof rails/roof load rack
Rough-road/sports version 	2UA 	Standard design
Seat adjustment 	3L3 	Manual height adjustment for front seats
Seat belt check 	9P0 	Without seat belt reminder
Seat covering 	N0Z 	Alcantara seat covering, side facings and seat insert in full leather
Seat heater 	4A3 	Seat heater for front seats separately controlled
Service interval prolongation 	QG1 	Service interval prolongation
Shock absorption, chassis, front 	G90 	Front shock absorption
Side air bag 	4X3 	Side air bag front with curtain air bag
Side and rear windows 	4KQ 	Side and rear windows in heat-insulating glass (blue)
Side lights 	7R3 	Side turn signal lights (white)
Smoking/non-smoking package 	9JB 	Smoking package, ashtray front and rear
Socket 	7B0 	Without socket
Spare wheel/breakdown set 	1G8 	Breakdown set
Speaker installation 	8RM 	8 speakers (passive)
Special alarm systems 	9A0 	Without taxi alarm system
Special color trim 	0UA 	Without special color trim
Special editions 	E0A 	No special edition
Special labels/plates 	0SB 	Labels/plates in German
Special registration measures 	3M0 	Without special measures
Steering 	QZ6 	Power steering (uprated compression spring a. limited steer. lift mechanism)
Steering column systems 	2C2 	Axial and vertical adjustable steering column (reinforced)
Steering system arrangement 	L0L 	Left-hand drive vehicle
Steering wheels 	1MW 	Leather steering wheel
Sticker (customized or special edition) 	0KA 	Without stickers and badges
Supertone system and tone sequence control 	9J0 	Without supertone system and tone sequence control
TV reception/digital radio reception 	QV0 	W/o TV reception/digital radio reception
Taillight assemblies 	8SB 	Taillight assembly w/ dark colored lens
Telephone/telematics 	9W0 	W/o car phone preparation/installation
Throttle actuation 	0L2 	Electric throttle actuation
Tires 	H3L 	Tires 235/60 R18 ??? front tires 255/55 R18 ??? rear
Tool kit and jack 	1S3 	Tool kit
Trailer hitch 	1D0 	Without trailer hitch
Transmission specifications 	G0L 	6-speed manual transmission for four-wheel drive vehicle
Transmission types/gearshift mechanisms 	0G5 	Gearshift lever
Tray 	7N0 	Without tray on roof liner
Type approval countries/countries with special requirements 	B13 	Type approval Switzerland
Vehicle class differentiation units/platform components 	0CE 	Vehicle class differentiation 1J0
Vehicle specifications 	F0A 	No special purpose vehicle, standard equipment
Vehicle type 	AZ3 	Special chassis package
Washer fluid level indicator 	8W1 	Washer fluid level indicator
Weight category front axle 	L92 	Suspension range 92 installation control only, no requirement forecast
Weight category rear axle 	0YZ 	Without determination of weight category for rear axle
Wheel covers 	1NL 	Covers for alloy wheels
Wheels 	CU7 	Alloy wheels 7.5J x 18
Window regulator 	4R4 	Power windows with comfort operation and circuit breaker
Windshield glass type 	4GT 	Heat-insulating glass windshield
Windshield wiper intermittent control 	8N3 	Windshield wiper intermittent control with rain sensor
 	PL2
 	PS4
Child seats 	QA0 	Without child seat
Front seats 	Q1J 	Sports front seats
 	RDA
Air duct, front area 	VK6 	Air duct, type 6
Base engine 	T3D 	6-cylinder gasoline engine 3.2 L unit 022.E
Instrument inserts 	U0C 	Instrument insert with tachometer clock and km/h speedometer
Shock absorption, chassis, rear 	UB7 	Rear shock absorption for sports design
Tire suppliers 	V0G 	MICHELIN tires
Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Radas
Post autor: Radas » wt mar 06, 2012 20:56
KonradzikIV pisze:było już oglądane przez kolege Radas więc on może się wypowiedzieć na ten temat
dokładnie tak. Byłem widziałem nawet jechałem.
Kolor ciemny granat, szary srodek z normalnymi śladami użytkowania.
Auta tak jak w opisie ma tam jakies odpryski na zderzaku, szybie. W środku nic nie jest powycierane co na moje świadczy o realnym przebiegu 63 tys. Właściciel auto serwisuje wymieniał ostatnio łożyska i jakieś kable czy cewki w ramach akcji serwisowej. Zawieszenie ok, silnik chodzi ładnie, sprzęgło również nigdzie nie ma żadnych stuków zgrzytów czy czegoś innego z wydruku z geometrii robionej w serwisie wynika że auto proste nie zostawia 4 śladów, oponki prawie nówki jeszcze na gwarancji felgi OZ Aristo w stanie bdb. Lekko źle spasowany przód tj do ustawienia lampy maska z błotnikiem, widać że auto musiało się pod coś wsunąć bo faktycznie nie ma śladów na podłużnicy, kielichu czy na zawieszeniu - (na pierwszy rzut oka bo dokładnie nie sprawdzałem trzeba by wjechać na kanał i popatrzeć ale właściciel widać nie ma nic do ukrycia). Właścicielem jest młody gość ale z historii jaką mi przedstawił i pokazał na foto nie jest to jego pierwsze auto powiedzmy sportowe ( RS4, 350Z, Leon Cupra) z resztą bardzo w w porządku gość z którym można pogadać.
Na razie się nie napalać :jezor:
karpi78
Post autor: karpi78 » wt mar 06, 2012 21:13
Z tego co mi wiadomo autko chwilowo zarezerwowane wiec Panowie trzeba sie trochę ostudzić :chytry:
xxxPALUCHxxx
Post autor: xxxPALUCHxxx » wt mar 06, 2012 23:25
GORAJ pisze:xxxPALUCHxxx, jak masz to daj :)
moze i tym rzem komus sie przyda :D
______LET's GOLF______
MIGAJACA KONTROLKA AKUMULATORA / ALTERNATORA -> potrzebuje pomocy :
viewtopic.php?f=140&t=398583
Radas
Post autor: Radas » śr mar 07, 2012 08:07
xxxPALUCHxxx, dokładnie tak jak piszesz obecny właściciel kupił auto 8 miesięcy temu od znajomego z Brzegu może to są fotki z jakiejs tam aukcji wystawionej przez tego drugiego.
karpi78
Re: Zna ktoś to R32?? - ogłoszenia sprzedaży golfów R
Post autor: karpi78 » śr mar 07, 2012 08:31
Radas pisze:xxxPALUCHxxx, dokładnie tak jak piszesz obecny właściciel kupił auto 8 miesięcy temu od znajomego z Brzegu może to są fotki z jakiejs tam aukcji wystawionej przez tego drugiego.
Radas na tych fotach jednak widać że z lusterkami jest coś nie tak ale chyba te od kierowcy jest od zwykłej golfiny czyli dłuższe
Rafit
Post autor: Rafit » śr mar 07, 2012 09:22
No na tych zdjęciach ta R ma ewidentnie lusterka Duże + Małe, a nie eRkowe.
No ale na tych z aukcji już ktoś usunął brak :)
pavo71
Post autor: pavo71 » śr mar 07, 2012 09:59
Zdjecia sa sprzed około poł roku tak ? to ladnie ktos nia jezdziło skoro zrobil ponad 30 tys km :)
Radas
Post autor: Radas » śr mar 07, 2012 18:32
Rafit pisze:No na tych zdjęciach ta R ma ewidentnie lusterka Duże + Małe, a nie eRkowe.
złudzenie też tak myślałem na pierwszy rzut oka, ma dwa ori R
pavo71 pisze:Zdjecia sa sprzed około poł roku tak ? to ladnie ktos nia jezdziło skoro zrobil ponad 30 tys km :)
zdjęcia z 2009 roku kiedy poprzedni właściciel kupił to auto ze Szwajcarii
xxxPALUCHxxx
Post autor: xxxPALUCHxxx » śr mar 07, 2012 18:38
Radas pisze:Zdjecia sa sprzed około poł roku tak ? to ladnie ktos nia jezdziło skoro zrobil ponad 30 tys km :)
to swiadczy tylko o tym ze R32 nadaje sie do jazdy na codzien :jezor:
daniel1d
Post autor: daniel1d » śr mar 07, 2012 18:40
xxxPALUCHxxx pisze:to swiadczy tylko o tym ze R32 nadaje sie do jazdy na codzien :jezor:
A dlaczego ma się nie nadawać :P Ja swoim robiłem po kilka tyś miesięcznie.
www.proturbo.com.pl
Radas
Post autor: Radas » śr mar 07, 2012 18:56
daniel1d pisze:A dlaczego ma się nie nadawać :P Ja swoim robiłem po kilka tyś miesięcznie.
jest moneta jest zabawa hehe
marcinnn1
Post autor: marcinnn1 » śr mar 07, 2012 19:28
ja zawsze myslalem z erka ma duze lusterka w stabdardowym romiarze jak normalny golf tyle ze prawe tez duze a tu sie dowiaduje ze byly jeszcze jakies typowe erkowe srednich rozmiarow tak?
Wróć do „Golf R”
