Nie daj się oszukać, sprawdź VIN i historię
Zły numer, albo brak go w bazie.
Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Re: Nie daj się oszukać, sprawdź VIN i historię
Uprzejmie proszę o sprawdzenie numeru VIN: WVWZZZ1HZTP048393
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1HZTP048393
Model Designation golf cl
Date of production 21.08.1995
Model year 1996
Sales type 1H12F3
Engine code AAM
Transmission code CKX
Axle drive 4A
Interior trim code RB
Roof color B4
Exterior color / Paint Code B4 / B9A
Activated carbon canister 1E1 Activated carbon canister
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional child seat anchors 3B0 Without additional child seat anchor
Additional tires (winter tires) 2WA Without additional tires
Additional tunnel cover 4J1 Floor tray, extension center console
Additional warning lights 9TA Without additional warning lights
Air bag 4UE Air bag for driver and front seat passenger
Antennas 8L1 Bright rod antenna
Anti-theft protection system 7AA Electronic vehicle immobilization device
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Ashtray light 8PB Ashtray light
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Backrest release 3H3 Backrest release for front seat(s)
Batteries J1L Battery 280 A (60 Ah)
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake pad wear indicator 9U0 Without brake pad wear indicator
Brake type, front 1LL Disc brakes, front
Brake type, rear 1KB Drum brakes, rear
Braking systems 1AG Nine-inch power brake
Bumper 2JG Body-colored bumpers
CD changer/CD player 7A0 Without CD changer/CD player
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Catalytic converter control 8KA W/o catalytic converter warning light
Cd enhancing underbody panel 2D0 Without cd enhancing underbody panel
Center high-mounted stop light 8R0 Without center high-mounted stop light
Center rear seat belts 3C1 Static lap belt, center rear
Chassis 2E0 Base chassis
Climatic zones 0Y1 Standard climatic zones
Clutch actuation 1K0 Without clutch actuation
Component part sets with country-specific design requirements B0X Component parts set, complying with vehicle type for Germany, various parts
Components with special surface appearance 6FA Components without special surface appearance
Cruise control 8T0 Without cruise control system (CCS)
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Dashboard 4N1 Padded dashboard
Door and lid locking system 4F0 Mechanical locking system
Door and side pockets, rear 4YA Without stowage box rear (door and side panel)
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YH Door pockets, front
Doors 0A1 2 doors
Drive layout 1X0 Front wheel drive
Engine specifications M8M 4-cylinder gasoline engine 1.8 L/55 kW Monomotronic, cataly. conv. MVEG 2/EU 3D base engine is T5U
Equipment levels A8C Comfort equipment
Exterior noise suppression measures 2B0 Without additional exterior noise suppression
Flame retardent materials 4Q0 No flame retardent materials
Floor coverings 3MQ Ibolours floor covering
Floor mats 0TA Without floor mats
Front fog light/additional headlight 8WA Without front fog light
Front seats Q1A Standard front seats
Front spoiler 5L1 Front spoiler
Front stabilizer 0AA Without front stabilizer
Front turn signal lights 6Z1 Yellow turn signal lights
Front underbody guard 1SA Without additional front underbody guard
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel tank treatment 2LB Fuel tank with special material treatment
Fuel tank vent line 1TB Fuel tank vent line with gravity valve and PVC breather hose
Gearshift boot/cover 6R0 Selector lever cover
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
Generators 8GM Alternator 70 A
Glove compartment 4Z2 Lockable glove compartment door
Hand brake lever handle 6PA Plastic hand brake lever handle
Headlight 8BB Halogen headlight for driving on the right
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heated door lock cylinder 9X0 Without heated door lock cylinder
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AA Manually controlled heating system
Horns 8Y1 Two-tone horn
Identification plates 1EC Special identification plate
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
Interference suppression 8E5 Local interference suppression for FM radio reception
Interior noise suppression measures 3W0 Without additional noise suppression measures for passenger compartment
Key for locking system 8QA Key without LED
Label for brake-proportioning values 0Q0 Without label for brake-proportioning values
Lashing rings/rails for load restraint 6B0 Without lashing rings for load restraint
Left exterior mirror 3BR Left exterior mirror: non-speherical, adjustable from inside
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lighting 9E1 Luggage compartment lighting
Luggage compartment lining 5A2 Comfort trunk lining
Manufacturing sequence differentiation 0FG Mosel manufacturing sequence
Molding roof liner 6NA Unsplit molding roof liner
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Nameplate set 0ND Nameplate set "TDI"
Night vision system 9R0 Without night vision system
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
Partition 3CA Without partition
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H1 Load-sensitive proportioning valve
Protective side molding 4B1 Protective side molding
Radiator grille 6KA Radiator grille
Radios 8AB Radio "alpha"
Reading light 8S1 Reading light front
Rear axle 0N2 Heavy-duty rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q0 Without rear headrests
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seats 3NB Rear seat bench/backrest, completely folding
Rear spoiler 5J0 Without rear spoiler
Rear stabilizer 0BA Without rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 3AD Right exterior mirror: convex, adjustable from inside
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Seat adjustment 3L0 Without special seat adjustment
Seat belt check 9P0 Without seat belt reminder
Seat covering N2J Fabric seat covering
Seat heater 4A0 Without seat heater
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Side and rear windows 4KA Side and rear windows in clear glass
Side assist/lane departure warning 7Y0 Without lane change assistant
Side lights 8F2 Side turn signal lights
Spare wheel/breakdown set 1G6 Space-saving spare wheel
Speaker installation 8RD 2 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E0A No special edition
Special labels/plates 0SA Without special labels/plates
Special registration measures 3M0 Without special measures
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering 1N1 Power steering
Steering column systems 2C0 Standard steering column
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 1MZ Steering wheel for air bag system
Sticker (customized or special edition) 0KA Without stickers and badges
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
Taillight assemblies 8SA Taillight assemblies, standard design
Telephone/telematics 9W0 W/o car phone preparation/installation
Tires H4V Tires 175/70 R14 88H
Trailer hitch 1D0 Without trailer hitch
Transmission shafts 1WB Transmission shafts w/ 100 mm in diameter
Transmission specifications G0E 4-speed automatic transmission
Transmission types/gearshift mechanisms 0G2 Selector lever
Trunk sill protection 2P1 Plastic trunk sill protection
Type approval countries/countries with special requirements B01 Type approval Germany
Vehicle class differentiation units/platform components 0DG Installation differentiation for build status of vehicle class A3 (VW Golf/ Vento/Variant), unit components
Vehicle specifications F0A No special purpose vehicle, standard equipment
Wheel covers 1NE Wheel center cover
Wheels C5Y Alloy wheels
Window regulator 4R0 Mechanical window regulator
Windshield glass type 4GD Clear glass windshield
Windshield wiper intermittent control 8N2 Windshield wiper intermittent control infinitely variable
RAB
Base engine T5U 4-cylinder gasoline engine 1.8 L unit 051.7
Control number (no PR-Family) S8E R-Line support
Control number (no PR-Family) S90
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Tire suppliers V0A Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1HZVB063056
Model Designation golf gti
Date of production 14.10.1996
Model year 1997
Sales type 1H16M4
Engine code AGG
Transmission code DFQ
Axle drive 5S
Interior trim code 35
Roof color D8
Exterior color / Paint Code D8 / P3G
Additional body covers, side 6ED Additional body cover on wheel arch and side sill for bumper without skirt
Antennas 8L3 Roof antenna
Brake type, front 1LN Disc brakes, front
Brake type, rear 1KK Disc brakes, rear
Braking systems 1AC Anti-lock brake system (ABS)
Bumper 2JE Partially painted bumpers
Center high-mounted stop light 8R1 Center high-mounted stop light
Chassis 2E1 "Plus" chassis
Clutch actuation 1K1 Mechanical clutch actuation
Components with special surface appearance 6FE Body-colored exterior mirror housings and tailgate handle
Door and lid locking system 4F1 Central locking system
Doors 0A1 2 doors
Engine specifications M11 4-cylinder gasoline engine 2.0 L/85 kW Simos, catalytic converter and MVEG 2 base engine is T8A
Equipment levels A8H Top sports equipment
Floor mats 0TL Front and rear floor mats (leatherette binding)
Front fog light/additional headlight 8WJ "Highway light"
Front seats Q1X Sports front seats with integrated storage trays
Front spoiler 5L2 Front spoiler
Front stabilizer 0AC Front stabilizer
Front turn signal lights 6Z4 Turn signal lights with dark colored lenses
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q6 Aluminum gearshift knob/handle
Generators 8GD Alternator 90A
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8BU Halogen headlight for driving on the right
Heating and air conditioning system 9AB Manually controlled air conditioning
Interference suppression 8E2 Local interference suppression for FM/AM radio reception
Key for locking system 8QC Key with light
Left exterior mirror 3BS Left exterior mirror: aspherical, electrically adjustable and heated
Manufacturing sequence differentiation 0FC Brussels manufacturing sequence
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 2VZ Nameplate set "GTI" (without model designation)
Navigation device 7Q0 Without navigation device
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B3 Protective side molding
Radiator grille 6KG Radiator grille
Radios 8UZ Radio preparation (for 4 speakers)
Rear seats 3NC Rear seat bench/backrest, split folding
Rear spoiler 5J1 Rear spoiler
Rear stabilizer 0BB Rear stabilizer
Right exterior mirror 3AF Right exterior mirror: convex, electrically adjustable and heated
Seat adjustment 3L3 Manual height adjustment for front seats
Seat covering N2Z Seat covering for special editions
Side air bag 4X0 Without side air bag
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 8F6 Dark colored side turn signal lights
Spare wheel/breakdown set 1G9 Space-saving spare wheel for temporary use, radial tire (5-hole)
Speaker installation 9VE Digital sound package
Special editions E2U GTI "Co-Branding"
Special labels/plates 0SB Labels/plates in German
Steering column systems 2C1 Height adjustable steering column
Steering wheels 2PZ Leather steering wheel for air bag system (rest-of-the-world) (lightweight design)
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Tires H6E All-weather tires
Transmission specifications G0C 5-speed manual transmission
Transmission types/gearshift mechanisms 0G3 Gearshift linkage
Wheel covers 1NL Covers for alloy wheels
Wheels C2M Alloy wheels
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GF Windshield in heat-insulating glass
RCT
Base engine T8A 4-cylinder gasoline engine 2.0 L unit 037.K
Instrument inserts U1L Instrument insert w/ km/h speedometer, clock, tachometer and special color trim
WJ2 Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
VSSZZZ6LZ8R066716
a co powiecie o tym?
może ktoś za drobną opłatą sprawdzić historię serwisową??
- Death_Proof
ksyniu22 pisze:VSSZZZ6LZ8R066716
Kolega Fucker Ci pomoże.
~VAGSTYLE~
Bardzo proszę o sprawdzenie tego numeru vin: WVWZZZ1HZXK000712.
Z góry bardzo dziękuję
Witam Bardzo bym prosił o sprawdzenie numeru WVWZZZ9NZ2Y095888
Dziś planuję zakup. Bardzo proszę o sprawdzenie: WVWZZZ1JZ2W441324
Z góry bardzo dziękuję!
Hodowla [b]YORKOWA FRAJDA[/b] poleca szczeniaczki [b]Yorki[/b] i [b]Chihuahua[/b] z rodowodem.
[url]http://www.yorkowafrajda.za.pl[/url]
Dodaj nas do znajomych na Facebooku:
[url]www.facebook.pl/yorkowafrajda[/url]
Kod: Zaznacz cały
Vehicle Identification No. VSSZZZ6LZ8R066716
Model Designation ibiza sport
Model IB
Date of production 02.10.2007
Model year 2008
Sales type 6L1524
Engine code AXR
Transmission code JXY
Axle drive 5S
Interior trim code 18
Roof color Z4
Exterior color / Paint Code Z4 / C9Z
"Multimedia", video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
Activated carbon canister 1E0 Without activated charcoal canister
Additional dust seals 6U0 Without additional seals outside
Additional instruments 8LA Without additional instruments/switches
Air bag 4UF Driver's and front passenger air bag with front passenger air bag deactivation
Air cleaner (engine) 1L0 Standard air cleaner
Air duct, front area VK0 Air duct, standard
Backrest release 5B0 Backrest release for left front seat right front seat w/ "Easy Entry" funct.
Base engine T5X 4-cylinder diesel engine 1.9 L unit 038.L
Batteries J0N Battery 330 A (61 Ah)
Body measures 5C7 Additional body measures
Body treatment 6J1 Special body treatment
Brackets 3P0 Without bracket for first aid kit and warning triangle
Brake type, front 1LQ Front disc brakes with integrated adapter
Brake type, rear 1KD Disc brakes, rear
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JV Body-colored bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Center rear seat belts 3C7 3-point seat belt for center rear seat
Child seats QA0 Without child seat
Chrome work package QJ1 Chrome work package
Component part sets with country-specific design requirements B0C Component parts set, complying with vehicle type for Belgium, various parts
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Cruise control 8T2 Cruise control system (CCS) electronic
Cup holder 4M5 Cup holder
Customized installation FC0 Without customized installation
Dashboard 4N2 Standard dashboard
Dashboard illumination 7V0 Standard dashboard illumination
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 3LD Door and side trim panel
Doors 0A1 2 doors
Drawers under front seats QN0 Without drawers under front seats
Electric interface for external use UF0 Without electric interface
Emission standard 0GG Emission standard EU4
Engine cover NM0 Without engine cover
Engine specifications MS7 4-cyl. turbo diesel eng. 1.9 L/74 kW TDI pump-jet injection system Base engine is T5X/T21/T71
Equipment levels A8F Sports equipment
Exhaust tailpipe 0P6 Rear exhaust tailpipe
Exterior mirror setting 6XE Exterior mirrors: electrically foldable and electrically adjustable/heated
Exterior noise suppression measures 2B2 Additional exterior noise suppression
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Foot area lining QM1 Foot area lining with cover
Fresh air intake for passenger compartment (with particulate filter) 2V1 Dust and pollen filter
Front fog light/additional headlight 8WD Integrated front fog light
Front license plate bracket 6W0 Without license plate bracket front
Front stabilizer 0AQ Front stabilizer
Fuel filler cap/door, locking option 2W1 Lockable fuel filler cap
Fuel systems 0F9 Cooled fuel system for diesel engine
Gearshift boot/cover 6R1 Leatherette gearshift boot
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C28 Operating permit, alteration
Glove compartment 4Z4 Glove compartment door without light
Grab handles at roof frame 5N3 Folding grab handles
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Heated rear window 8P1 Heated rear window
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Horns 8Y4 High-sounding horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Interior light in driver compartment 9GB Interior light with switch-off delay and door pillar switch
Key for locking system 8QE Key for locking system with remote control
Left exterior mirror 5SJ Left exterior mirror: convex
Left vanity mirror 4SK Left vanity mirror not illuminated with cover and pocket
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Luggage compartment lining 5A6 Full fleece trunk lining
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Manufacturing sequence differentiation 0FD SEAT manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Nameplate set 2VP Nameplate set "TDI" "I"
Owner's manuals 0XN Information kit in French and Dutch
Paint preservative/transit coating 5K1 Paint preservative (wax)
Park distance control 7X0 Without park distance control
Pedal cluster VF0 Standard pedal cluster
Pillar lining 4XC Exterior pillar lining
Platform group class 7PB Platform group class 2
Platform module floor pan, rear 4P2 Rear floor panel module, type 3
Radiator grille 6KL Radiator grille
Radios 8AA Without radio
Reading light 8S0 Without reading light
Rear axle 0N7 Heavy-duty rear axle (design 2)
Rear headrests 3Q6 Three rear headrests
Rear license plate bracket 6P0 Without license plate bracket rear
Rear seat catch 6QA Rear seat catch
Rear spoiler 5J4 Body-colored rear spoiler
Restraint systems, front 4QV 3-point seat belts with electric tensioner and height adjustment, front
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TC Right vanity mirror with cover
Service interval prolongation QG0 Without service interval prolongation
Shock absorption, chassis, front G19 Front shock absorption
Shock absorption, chassis, rear UB1 Rear shock absorption for sports design
Side air bag 4X1 Side air bag front
Side and rear windows 4KX Side and rear windows tinted green hinged quarter window operated manually
Side lights 7R3 Side turn signal lights (white)
Smoking/non-smoking package 9JD Smoking package, ashtray front
Socket 7B0 Without socket
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RE 4 speakers (passive)
Special editions E1J "Formula Sports II"
Special labels/plates 0SG Labels/plates in French
Steering 1N6 Power steering
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering wheels 2PH Leather steering wheel
Taillight assemblies 8SG Standard taillight assemblies (type 2)
Tire pressure warning light 7K0 Without tire pressure warning light
Tires H2J Tires 205/45 R16 83W
Tool kit and jack 1S7 Tool kit and aluminum jack
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Type approval countries/countries with special requirements B02 Type approval Belgium
Upgrading measures GP0 Vehicles w/o special upgrade measures
Vehicle class differentiation units/platform components 0CY Vehicle class differentiation 6L0
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category front axle L39 Suspension range 39 installation control only, no requirement forecast
Weight category rear axle 0YB Weight range 2 installation control only, no requirement forecast
Wheel housing liners KG2 Wheel housing liner front and rear
Wheels CM5 Alloy wheels 6.5J x 16
Window regulator 4R1 Power windows
Windshield wiper arms/blades 9PB Windshield wiper arms/blades with additional guide vanes
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PB3
PF3
Front seats Q4H Comfort sports seats, front Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1HZXK000712
Model Designation golf estate
Date of production 07.05.1998
Model year 1998
Sales type 1H50U4
Engine code AKS
Transmission code DGG
Axle drive 5S
Interior trim code 71
Roof color T3
Exterior color / Paint Code T3 / C6M
Backrest release 3H0 Without backrest release for front seats
Batteries J1P Battery 220 A (44 Ah)
Body style K8D Station Wagon Variant/Avant
Brake type, front 1LY Disc brakes, front
Brake type, rear 1KM Drum brakes, rear
Components with special surface appearance 6FB Body-colored exterior mirror housings
Door and side pockets, rear 4YB Stowage box rear (door and side panel)
Doors 0A2 4 doors
Engine specifications MV9 4-cylinder gasoline engine 1.6 L/74 kW EU 3D base engine is T0C
Front stabilizer 0AF Front stabilizer
Front turn signal lights 6Z2 White turn signal lights
Fuel tank vent line 1TE Fuel tank vent line with gravity valve and second vent line with PVC breather hoses
Gearshift boot/cover 6R3 Rubber gearshift boot
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
General operating permit, alterations C02 Operating permit, alteration
Lashing rings/rails for load restraint 6B1 Lashing rings for load restraint
Luggage compartment cover 3U2 Sliding trunk cover
Luggage compartment floor covering 6SL Tufted trunk floor covering (cut pile)
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Nameplate set 1RX Nameplate set in base trim
Outer rear seat belts 3ZE 3-point seat belts, outer rear with height adjustment and ECE label
Protective side molding 4B2 Body-colored protective side molding
Radios 8AD Radio "gamma"
Rear fog light 8TF Rear fog lights, left and right
Rear headrests 3Q1 Rear headrests
Roof insert/convertible top 3FE Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 3S2 Black roof rails
Seat adjustment 3L1 Manual height adjustment for left front seat
Speaker installation 8RM 8 speakers (passive)
Special editions E1A "Arte"
Sticker (customized or special edition) 0KZ Stickers for special editions
Tires H0L Tires 195/60 R14 H
Trailer hitch 1D2 Trailer hitch, removable and lockable
Transmission shafts 1WA Transmission shafts w/ 90 mm in diameter
Wheels C0L Alloy wheels
PHX
RCR
Base engine T0C 4-cylinder gasoline engine 1.6 L unit 037.M
Control number (no PR-Family) S0B Veh. w/ engineering build status of current model year a. vehicle identification no. of next model year
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ9NZ2Y095888
Model Designation polo tdi
Model PO
Date of production 18.04.2002
Model year 2002
Sales type 9N1324
Engine code AXR
Transmission code EWT
Axle drive 5S
Interior trim code VF
Roof color 7D
Exterior color / Paint Code 7D / B5N
Additional body covers, side 6ER Without additional body covers, but with add. paint
Additional warning lights 9TG Additional warning lights (door area) front
Air duct, front area VK1 Air duct, type 1
Anti-theft protection system 7AH Electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
Batteries J0L Battery 340 A (70 Ah)
Body measures 5C6 Additional body measures
Brake pad wear indicator 9U1 Brake pad wear indicator
Braking systems 1AT Electronic stabilization program (ESP)
CD ROM/DVD/SD card 7QB CD ROM (Germany)
CD changer/CD player 7A2 CD changer
Center sun visor GA1 Center sun visor
Chrome work package QJ3 Chrome package (type 2)
Cup holder 4M0 Without cup holder
Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
Doors 0A2 4 doors
Drawers under front seats QN1 Drawer under left front seat
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GR Emission standard EU3 D4
Exhaust tailpipe 0P0 Rear exhaust tailpipe (standard)
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B3 Additional exterior noise suppression (hood, capsule and dash panel)
Floor mats 0TD Front and rear floor mats
Frame forestructure AC1 Long frame forestructure
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front license plate bracket 6W1 License plate bracket front (large)
Front stabilizer 0AS Front stabilizer
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Generators 8GL Alternator 120 A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Headlight washer system 8X1 Headlight washer system
Heat accumulator system/additional heater 7E6 Electric auxiliary air heater
Heated washer nozzles 9T1 Heated washer nozzles, front
Inserts 5TC Without decorative inserts
Interior light in driver compartment 9GH Interior light with door pillar switches
Left exterior mirror 5SL Left exterior mirror: aspherical
Left vanity mirror 4SD Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 4E5 Tailgate/trunk lid unlocking from outside
Manufacturing sequence differentiation 0FB Pamplona manufacturing sequence
Molding roof liner 6NF Comfort molding roof liner unsplit
Multi-function display/trip computer 9Q2 Multi-function display/on-board computer with check control
Nameplate set 1DG Nameplate set "TDI"
Navigation device 7Q5 Navigation system with black-and-white screen
Owner's manuals 0VC Information kit in German
Pillar lining 4XF Exterior pillar lining design 2
Platform group class 7PA Platform group class 1
Radios 8AY Radio/navigation system
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Right vanity mirror 4TD Right vanity mirror illuminated
Seat covering N7F Partially leather seat covering, fine embossed
Seat heater 4A3 Seat heater for front seats separately controlled
Shock absorption, chassis, front G12 Front shock absorption
Shock absorption, chassis, rear 1JC Rear shock absorption for sports design
Socket 7B2 12-volt socket in luggage boot
Steering 1N2 Power steering electro-hydraulic
Steering wheels 1MR Leather steering wheel
Telephone/telematics 9W8 Car phone preparation
Tires H0U Tires 195/50 R15 V
Vehicle class differentiation units/platform components 0CL Vehicle class differentiation 6Q0- for build status Europe
Weight category front axle L14 Suspension range 14 installation control only, no requirement forecast
Wheels C8M Alloy wheels 6J x 15
Window regulator 4R3 Power windows with comfort operation
Windshield wiper arms/blades 9PE Windshield wiper arms/blades with spoiler wiper blade
PB7
PH3
PJ3
PSF
PTC
PTS
Service interval prolongation QG1 Service interval prolongation
RLB
Control number (no PR-Family) SZ9 Delivery by "Autostadt Wolfsburg"
Tire suppliers V0A Tires w/o specification of tire brand Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ2W441324
Model Designation golf tdi
Date of production 22.11.2001
Model year 2002
Sales type 1J1034
Engine code AXR
Transmission code EUH
Axle drive 5S
Interior trim code 17
Roof color 8E
Exterior color / Paint Code 8E / A7W
Additional warning lights 9TB Additional warning lights (door area)
Anti-theft protection system 7AB Electronic alarm system with vehicle immobilization device (for RoW)
Auxiliary heating 9M0 Without auxiliary/parking heater
Brake type, front 1LS Front disc brakes with integrated adapter
Bumper 2JB Standard bumpers
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E0 Without center armrest front
Chrome work package QJ0 Without aluminum/chrome work package
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Controls (steering wheels/steering column) 4LA Without controls
Door pockets, front 3YQ Door pockets without insert mats
Doors 0A2 4 doors
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z5 Not hot country
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Floor coverings 3MH Dilours floor covering w/o scuff guard
Front stabilizer 0AL Front stabilizer
General operating permit, alterations C23 Operating permit, alteration
Headlight 8JS Twin headlight for driving on the right with clear lens
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Horns 8Y0 Single-tone horn
Inserts 5MA Decorative inserts
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Lumbar support 7P0 Without lumbar support in seat backrests
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZG 3-point seat belts, outer rear with height adjustment
Owner's manuals 0VA Without information kit
Paint coating FB0 Standard paint coating
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Radios 8AS Radio "alpha Europa"
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N1 Standard rear axle
Rear stabilizer 0BC Rear stabilizer
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Rough-road/sports version 2UA Standard design
Shock absorption, chassis, front G28 Front shock absorption
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Special editions E79 "Special"
Steering wheels 1MP Steering wheel for air bag system
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Throttle actuation 0L2 Electric throttle actuation
Tires H6S Tires 195/65 R15 V
Tray 7N0 Without tray on roof liner
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Weight category front axle L09 Suspension range 09 installation control only, no requirement forecast
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheels C3J Cast alloy wheels 6J x 15 offset 38 (1J0 601 025 Q)
PH4
PT1
PTB
Nameplates for sales name QD1 Nameplates for sales name
RAA
Control number (no PR-Family) SA0 Model year change calendar week 45
W52 Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Witam.
Bardzo proszę o sprawdzenie numeru
WVWZZZ9N28Y233175
Z góry dziękuję.
WVWZZZ9N28Y233175
Z góry dziękuję.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ9NZ8Y233175
Date of production 16.05.2008
Model year 2008
Sales type 9N31M4
Engine code BUD
Transmission code JHQ
Axle drive 5S
Interior trim code WV
Roof color Z4
Additional warning lights 9TC Additional reflectors (door area)
Battery/alternator capacity NY0 Standard battery/alternator capacity
Brake type, front 1LR Front disc brakes with integrated adapter
Dashboard 4N0 Standard dashboard
Dashboard illumination 7V1 Standard dashboard illumination
Delivery equipment 2A0 Without delivery equipment
Door and side trim panels 3LX Door and side trim panel
Doors 0A2 4 doors
Drawers under front seats QN3 Drawers under front seats
Engine cover NM1 Engine cover
Engine specifications D4W 4-cyl. gasoline engine 1.4 l/59 kW 16V Base engine is TT1
Equipment levels A8M Executive comfort equipment
First aid kit / warning triangle 1T2 Warning triangle
Foot area lining QM0 Foot area lining without cover
Fuel systems 1A3 Fuel system for carburetor gasoline eng. with injector system without fuel return and modified injection pressure
Fuel tank treatment 2LA Fuel tank without special material treatment
Glove compartment 4Z1 Standard glove compartment
Heating and air conditioning system 9AP Climatic air-conditioning system (semi-automatic)
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Installation differentiation for vehicle components 0EM Installation differentiation for transmission MQ 200 vehicle components
Lockable wheel bolts 1PA Standard wheel bolts
Nameplate set 0QK Nameplate set "1.4"
Owner's manuals 0VZ Information kit in Hungarian
Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
Radios 8UA Radio with CD player
Scuff plates 7M5 Without protective film for scuff plate
Seat covering N0J Knit cut pile seat covering
Shock absorption, chassis, front G27 Front shock absorption
Shock absorption, chassis, rear 1JP Rear shock absorption
Steering wheels 1ME Steering wheel
Tires H2Z Tires 185/60 R14 T
Tray areas package QE1 Tray areas package 1
Type approval countries/countries with special requirements B18 Type approval Hungary
Upgrading measures GP1 Vehicles with special upgrade measures
Weight category front axle L10 Suspension range 10 installation control only, no requirement forecast
Weight category rear axle 0YC Weight range 3 installation control only, no requirement forecast
Wheel covers 1NC Full wheel covers
Wheels C9G Steel wheels 6J x 14 Offset 43 (5-hole)
Window regulator 4R2 Power windows front, mechanical window regulators rear
PE2
PH1
PJ1
PTB
Front seats Q2J Comfort front seats
RBA
Base engine TT1 4-cylinder gasoline engine 1.4 L unit 036.R
Użytkownicy przeglądający to forum: Baidu [Spider] i 8 gości
