czy ktoś życzliwy pomoże mi rozkodować VIN? Mam golfa z poczatka serii... zastanawiam się ile elementów pominięto na pierwszym montażu...
Z góry dziękuje
WVWZZZ1JZWW042895
Kod: Zaznacz cały
Vehicle Identification No. WAUZZZ8L921020080
Model Designation audi a3 1.9 tdi
Date of production 22.04.2002
Model year 2002
Sales type 8L1BGC
Engine code ASZ
Transmission code DRW
Axle drive 6S
Interior trim code EG
Roof color Q5
Exterior color / Paint Code Q5 / Z5L
Activated carbon canister 1E0 Without activated charcoal canister
Additional child seat anchors 3B4 Child seat anchor for child seat system ISOFIX
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2WA Without additional tires
Air bag 4UE Air bag for driver and front seat passenger
Anti-theft protection system 7AA Electronic vehicle immobilization device
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H6 Backrest release for front seats with "Easy Entry" and add. backrest release on the inner side of right front seat
Base engine T9J 4-cylinder diesel engine 1.9 L unit 038.K
Batteries J0L Battery 340 A (70 Ah)
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1LE Disc brakes, front
Brake type, rear 1KK Disc brakes, rear
Braking systems 1AT Electronic stabilization program (ESP)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JB Standard bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A0 Without CD changer/CD player
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E0 Without center armrest front
Center rear seat belts 3C1 Static lap belt, center rear
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Components with special surface appearance 6FB Body-colored exterior mirror housings
Cruise control 8T0 Without cruise control system (CCS)
Customized installation FC0 Without customized installation
Door and lid locking system 4K4 Radio remote controlled central locking
Doors 0A1 2 doors
Drive layout 1X0 Front wheel drive
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GE Emission standard EU3
Engine cooling system 8Z5 Not hot country
Engine specifications D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Equipment levels A9D "Ambition" equipment
Exterior mirror setting 6XC Exterior mirrors: electrically adjustable
Exterior noise suppression measures 2B3 Additional exterior noise suppression (hood, capsule and dash panel)
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T3 First aid kit with warning triangle
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 8WB Front fog lights
Front license plate carrier 6W5 Front license plate carrier
Front stabilizer 0AL Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F9 Cooled fuel system for diesel engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C18 Operating permit, alteration
Generators 8GL Alternator 120 A
Hand brake lever handle 6PA Plastic hand brake lever handle
Handling standard production and pre-production series FD0 Standard-production control (deviating in-plant control)
Headlight 8JH Ellipsoidal headlight for driving on the right
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Heated door lock cylinder 9X4 Without heated door lock cylinder with micro switch
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G8 Filler neck module 2 without insert
Inserts 5TC Without decorative inserts
Installation differentiation for vehicle components 0EN Installation differentiation for transmission MQ 350 vehicle components
Instrument inserts U2A Instrument insert with km/h speedometer, radio-controlled clock, tachometer and trip odometer
Label for central electric 0W1 Label for central electric German-speaking countries
Left exterior mirror 5SL Left exterior mirror: aspherical
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Mud flap 6N0 Without mud flaps
Multi-function display/trip computer 9Q2 Multi-function display/on-board computer with check control
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y1 Outdoor temperature gage
Owner's manuals 0VC Information kit in German
Paint preservative/transit coating 5K3 Liquid film sealant
Park distance control 7X0 Without park distance control
Platform group class 7PE Platform group class 5
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Quattro GmbH FQ0 Standard production wheels
Radios 8UC Radio "chorus"
Rear axle 0N1 Standard rear axle
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q1 Rear headrests
Rear seats 3NC Rear seat bench/backrest, split folding
Rear spoiler 5J0 Without rear spoiler
Rear stabilizer 0BB Rear stabilizer
Rear trim panel 6V1 Rear trim panel (ECE)
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Right exterior mirror 5RU Right exterior mirror: convex (large viewing field)
Roof insert/convertible top 3FA Without roof insert (standard roof)
Rough-road/sports version 2UA Standard design
Safety certificate 0LW Special plates/stickers/ safety certificates for Germany
Scuff plates 7M0 Plastic scuff plates in door apertures
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P0 Without seat belt reminder
Seat covering N0E Woven fabric seat covering
Seat heater 4A0 Without seat heater
Self-collection / special control A00 No self-collection
Shock absorption, chassis, front G66 Front shock absorption
Shock absorption, chassis, rear 1JK Rear shock absorption, sports design
Side air bag 4X1 Side air bag front
Side lights 7R3 Side turn signal lights (white)
Sill top/sill cover 5E1 Without sill top with door cover
Spare wheel/breakdown set 1G3 Alloy spare wheel with original equipment tires
Speaker installation 9VD Speaker (active)
Special editions E0A No special edition
Special labels/plates 0ST Labels/plates in German and French
Steering 1N6 Power steering
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2PV Leather trimmed sports steering wheel
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Tachograph/logbook 9NX Without electronic logbook
Telephone/telematics 9W0 W/o car phone preparation/installation
Throttle actuation 0L2 Electric throttle actuation
Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
Tire suppliers V0A Tires w/o specification of tire brand
Tires H6S Tires 195/65 R15 V
Trailer hitch 1D0 Without trailer hitch
Transit coating NT0 Transit coating (type 1)
Transmission specifications G0K 6-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Type approval countries/countries with special requirements B01 Type approval Germany
Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
Vehicle class differentiation units/platform components 0CJ Vehicle class differentiation 8L0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L65 Suspension range 65 installation control only, no requirement forecast
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheels CE7 Alloy wheels
Window regulator 4R1 Power windows
Windshield glass type 4GH Windshield in heat-insulating glass with sunshield
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PSD
Front seats Q1D Sports front seats
Light package (lighting) QQ0 Without add. lights (interior lighting)
Service interval prolongation QG1 Service interval prolongation Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ2W151328
Model Designation golf tdi variant
Date of production 03.07.2001
Model year 2002
Sales type 1J5014
Engine code ALH
Transmission code EGR
Axle drive 5S
Interior trim code 32
Roof color Z4
Exterior color / Paint Code Z4 / C9Z
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional child seat anchors 3B0 Without additional child seat anchor
Additional warning lights 9TB Additional warning lights (door area)
Air duct, front area VK0 Air duct, standard
Antennas 8L3 Roof antenna
Anti-theft protection system 7AB Electronic alarm system with vehicle immobilization device (for RoW)
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Backrest release 3H0 Without backrest release for front seats
Body style K8D Station Wagon Variant/Avant
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake type, front 1LS Front disc brakes with integrated adapter
Brake type, rear 1KP Disc brakes, rear
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Chrome work package QJ0 Without aluminum/chrome work package
Components with special surface appearance 6FE Body-colored exterior mirror housings and tailgate handle
Controls (steering wheels/steering column) 4LA Without controls
Cup holder 4M0 Without cup holder
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YQ Door pockets without insert mats
Doors 0A2 4 doors
Engine compartment lighting 9L0 Without engine compartment lighting
Engine specifications MD1 4-cyl. turbo diesel eng. 1.9 L/66 kW TDI base engine is T0W/T0E
Equipment levels A8C Comfort equipment
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B1 Additional exterior noise suppression
First aid kit / warning triangle 1T2 Warning triangle
Floor coverings 3MF Dilours floor covering with scuff guard
Floor mats 0TA Without floor mats
Front fog light/additional headlight 8WA Without front fog light
Front license plate bracket 6W1 License plate bracket front (large)
Front stabilizer 0AE Front stabilizer
Fuel systems 0F3 Fuel system for diesel engine
Gearshift boot/cover 6R1 Leatherette gearshift boot
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
General operating permit, alterations C20 Operating permit, alteration
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Headlight 8JS Twin headlight for driving on the right with clear lens
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heated washer nozzles 9T0 Without heated washer nozzles
Horns 8Y0 Single-tone horn
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Inserts 5MA Decorative inserts
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Left vanity mirror 4SD Left vanity mirror, illuminated
Luggage compartment cover 3U2 Sliding trunk cover
Luggage compartment floor covering 6SL Tufted trunk floor covering (cut pile)
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 2QK Nameplate set "TDI"
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZG 3-point seat belts, outer rear with height adjustment
Owner's manuals 0VA Without information kit
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
Partition 3CX Net partition
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P3 Rear floor panel module, type 4
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Protective side molding 4B1 Protective side molding
Radiator grille 6KG Radiator grille
Radios 8AS Radio "alpha Europa"
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N5 Standard rear axle
Rear cargo area 3GN Variable cargo area concept
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seat catch 6QA Rear seat catch
Rear seats 3NE Rear seat bench/backrest, split folding with center armrest
Rear stabilizer 0BC Rear stabilizer
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof rails/roof load rack 3S2 Black roof rails
Seat covering N2Z Seat covering for special editions
Shock absorption, chassis, front G09 Front shock absorption
Shock absorption, chassis, rear 1JH Rear shock absorption
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B0 Without socket
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RE 4 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E2M "Edition"
Special labels/plates 0SB Labels/plates in German
Special registration measures 3M0 Without special measures
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Steering 1N1 Power steering
Steering wheels 1MP Steering wheel for air bag system
Sticker (customized or special edition) 0KZ Stickers for special editions
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
Taillight assemblies 8SA Taillight assemblies, standard design
Tires H6R Tires 195/65 R15 T
Tool kit and jack 1S7 Tool kit and aluminum jack
Transmission specifications G0C 5-speed manual transmission
Tray 7N0 Without tray on roof liner
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category front axle L20 Suspension range 20 installation control only, no requirement forecast
Wheel covers 1NL Covers for alloy wheels
Wheels C3J Cast alloy wheels 6J x 15 offset 38 (1J0 601 025 Q)
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GF Windshield in heat-insulating glass
PH4
Child seats QA0 Without child seat
Front seats Q1A Standard front seats
Nameplates for sales name QD1 Nameplates for sales name
RAA
Base engine T0W 4-cylinder diesel engine 1.9 L unit 038.B
WE2
WEJ Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZWW042895
Model Designation golf 1.4
Date of production 20.01.1998
Model year 1998
Sales type 1J12E4
Engine code AKQ
Transmission code DSB
Axle drive 5S
Interior trim code KL
Roof color D3
Exterior color / Paint Code D3 / A5G
Activated carbon canister 1E1 Activated carbon canister
Additional body covers, side 6EJ Additional body cover on sill without wheel arch
Batteries J1P Battery 220 A (44 Ah)
Brake type, front 1LQ Front disc brakes with integrated adapter
Braking systems 1AC Anti-lock brake system (ABS)
Carrier frequency for radio remote control 5D0 Without carrier frequency
Catalytic converter control 8KA W/o catalytic converter warning light
Center armrest 6E3 Front center armrest
Chassis 2E0 Base chassis
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Cup holder 4M6 Cup holder
Dashboard illumination 7V0 Standard dashboard illumination
Door and lid locking system 4F1 Central locking system
Door and side trim panels 4AR Door and side trim panel in foam film and circular-knit
Door pockets, front 3YR Door pockets with insert mats
Doors 0A2 4 doors
Engine specifications MB6 4-cyl. gasoline engine 1.4 L/55 kW 16V with multi-point injection, EU 3D base engine is T1Q
Exterior noise suppression measures 2B2 Additional exterior noise suppression
Flame retardent materials 4Q0 No flame retardent materials
Floor mats 0TQ Front and rear floor mats (polypropylene)
Front license plate carrier 6W1 License plate carrier front (large)
Front stabilizer 0AM Front stabilizer
Fuel systems 0F2 Fuel system for carburetor gasoline engine
General operating permit, alterations C02 Operating permit, alteration
Generators 8GM Alternator 70 A
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heating and air conditioning system 9AA Manually controlled heating system
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Interference suppression 8E2 Local interference suppression for FM/AM radio reception
Key for locking system 8QC Key with light
Label for radio remote control 7CA Without label for radio remote control
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lighting 9E1 Luggage compartment lighting
Luggage net/pocket on backrest(s) 4U1 Luggage nets/pockets on backrests
Molding roof liner 6NH Comfort molding roof liner unsplit roof cutout rear (radio antenna)
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Nameplate set 0NB Nameplate set in base trim
Partition 3CA Without partition
Radios 8AC Radio "beta"
Rear cargo area 3GA Without cargo area
Rear license plate carrier 6P1 License plate carrier rear (ECE)
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Roof insert/convertible top 3FE Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Seat covering N0U Cut pile seat covering
Shock absorption, chassis, front 1GA Front shock absorption, basic design 1
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side lights 8F2 Side turn signal lights
Socket 7B2 12-volt socket in luggage boot
Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Sticker (customized or special edition) 0KA Without stickers and badges
Throttle actuation 0L0 Mechanical throttle actuation
Tires H5V Tires
Transmission shafts 1WA Transmission shafts w/ 90 mm in diameter
Transmission types/gearshift mechanisms 0G3 Gearshift linkage
Wheel covers 1NC Full wheel covers
Wheels C6D Steel wheels 6J x 14 Offset 38
PTB
Front seats Q2J Comfort front seats
RBB
Base engine T1Q 4-cylinder gasoline engine 1.4 L unit 036.D (aluminum)
Control number (no PR-Family) S3K Pool campaign
Weight category front axle U20 Suspension range 119
W02 Za stary, nie ma w bazie.golfiarzOP pisze:ja rowniez prosze o zdekodowanie wypasu w golfie
wvwzzz1gzmw726510
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ1D452296
Model Designation golf 1.6
Date of production 12.02.2001
Model year 2001
Sales type 1J10E4
Engine code AZD
Transmission code ERT
Axle drive 5S
Interior trim code AH
Roof color 1D
Exterior color / Paint Code 1D / W5Z
Additional tunnel cover 4J1 Floor tray, extension center console
Base engine T27 4-cylinder gasoline engine 1.6 L unit 036.L
Control number (no PR-Family) ST7 Model year change, calendar week 02
Cup holder 4M5 Cup holder
Door and lid locking system 4F0 Mechanical locking system
Doors 0A2 4 doors
Emission standard 0GG Emission standard EU4
Engine specifications D3H 4-cylinder gas. engine 1.6 L/77 kW (16V) with multi-point injection Base engine is T27/TL0/TT0/TV5
Exterior mirror setting 6XB Exterior mirrors: adjustable from inside
Exterior noise suppression measures 2B7 Additional exterior noise suppression
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
General operating permit, alterations C19 Operating permit, alteration
Identification plates 1FF Special identification plate (Poland)
Installation differentiation for vehicle components 0EB Installation differentiation for transmission MQ170 vehicle components
Luggage compartment lining 5A2 Comfort trunk lining
Manufacturing sequence differentiation 0FK Bratislava manufacturing sequence
Nameplate set 0QE Nameplate set "1.6"
Radios 8AA Without radio
Rear seats 3NB Rear seat bench/backrest, completely folding
Seat adjustment 3L1 Manual height adjustment for left front seat
Seat covering N4C Fabric seat covering
Service interval prolongation QG2 No possibility of activating service interval prolongation
Shock absorption, chassis, front G27 Front shock absorption
Side air bag 4X0 Without side air bag
Tires H1T All-weather tires 255/55 R19 107H (NAR)
Trunk sill protection 2P0 Without trunk sill protection
Type approval countries/countries with special requirements B17 Type approval Poland
Weight category front axle L17 Suspension range 17 installation control only, no requirement forecast
Window regulator 4R0 Mechanical window regulator
PR4
PTB
Front seats Q1A Standard front seats Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZXW363117
Model Designation bora tdi
Date of production 07.11.1998
Model year 1999
Sales type 1J2244
Engine code AGR
Transmission code DQY
Axle drive 5S
Roof color X1
Exterior color / Paint Code X1 / B7Z
Body style K8B Notchback
Brake pad wear indicator 9U0 Without brake pad wear indicator
Breakaway interior mirror 4L6 Breakaway interior rear view mirror, automatically dimming
Bumper 2JC Comfort bumpers
Component part sets with country-specific design requirements B0C Component parts set, complying with vehicle type for Belgium, various parts
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Control number (no PR-Family) S0C Introductory volume
Doors 0A2 4 doors
Engine specifications M0G 4-cyl. turbo diesel eng. 1.9 L/66 kW TDI with MVEG 2 base engine is T0W
Flame retardent materials 4Q1 Flame retardent materials
Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
Fuel tank treatment 2LA Fuel tank without special material treatment
General operating permit, alterations C06 Operating permit, alteration
Generators 8GD Alternator 90A
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8BN Halogen headlight for driving on the right
Heating and air conditioning system 9AB Manually controlled air conditioning
Luggage compartment cover 3U0 Without luggage compartment cover
Luggage compartment floor covering 6SM Needle-punched trunk floor covering (Dilours)
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Lumbar support 7P4 Manually adjustable lumbar support in front seats
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Paint preservative/transit coating 5K1 Paint preservative (wax)
Platform module floor pan, rear 4P1 Rear floor panel module, type 2
Protective side molding 4B2 Body-colored protective side molding
Radiator grille 6KC Radiator grille
Rear seat catch 6QB Locking rear seat catch
Rear seats 3NS Rear seat bench/backrest, split folding locking, with center armrest
Rear window wiper and washer system 8M0 W/o rear window wiper and washer system
Shock absorption, chassis, front 1GC Front shock absorption, basic design 3
Shock absorption, chassis, rear 1JD Rear shock absorption, basic design 2
Steering wheels 2PX Leather trimmed sports steering wheel
Tie down straps/net/pocket 6M3 Trunk net
Tires H6U Tires 205/55 R16 91W
Transmission shafts 1WB Transmission shafts w/ 100 mm in diameter
Trunk sill protection 2P2 Trunk sill protection in stainless steel
Type approval countries/countries with special requirements B02 Type approval Belgium
Wheel covers 1NU Full wheel covers
Wheels C9D Steel wheels 6.5J x 16
Windshield wiper intermittent control 8N3 Windshield wiper intermittent control with rain sensor
P15
PH1
Service interval prolongation QG0 Without service interval prolongation
Weight category front axle U29 Suspension range 128
W02 Kod: Zaznacz cały
Vehicle Identification No. TMBGP21U132677607
Model Designation octavia comb.elegance
Date of production 05.06.2002
Model year 2003
Sales type 1U5384
Engine code AHF
Transmission code EGS
Axle drive 5S
Interior trim code BE
Roof color D7
Exterior color / Paint Code D7 / F5U
Braking systems 1AJ Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
Breakaway interior mirror 4L0 Non-dipping breakaway inside rear view mirror
Breakdown spray GR0 Without emergency tire inflator
Cd enhancing underbody panel 2D0 Without cd enhancing underbody panel
Center high-mounted stop light 8R1 Center high-mounted stop light
Child bench seat 3V0 Without child bench seat
Dashboard 4N1 Padded dashboard
Doors 0A2 4 doors
Electric safety package 9BC Display and warning tone f. opened doors
Emission standard 0GD Emission standard EU2 MVEG 2
Engine specifications MF4 4-cyl. turbo diesel eng. 1.9 L/81 kW TDI MVEG 2 base engine is T8U
Equipment levels A8D Luxury equipment
Fresh air intake for passenger compartment (with particulate filter) 2V1 Dust and pollen filter
Front fog light/additional headlight 8WD Integrated front fog light
Front license plate carrier 6W0 Without license plate carrier front
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
General operating permit, alterations C00 Operating permit, initial registration
Glove compartment 4Z3 Lockable glove compartment door, with light
Headlight washer system 8X1 Headlight washer system
Heated door lock cylinder 9X0 Without heated door lock cylinder
Key for locking system 8QK Key for locking system
Left exterior mirror 3BS Left exterior mirror: aspherical, electrically adjustable and heated
Left vanity mirror 4SC Left vanity mirror with cover
Mud flap 6N1 Mud flaps rear
Owner's manuals 0VT Information kit in Polish
Parking light indicator light 8NA Without parking light warning light
Platform group class 7PB Platform group class 2
Platform module floor pan, rear 4P2 Rear floor panel module, type 3
Radiator grille 6KA Radiator grille
Reading light 8S4 Two reading lights front, two rear
Right exterior mirror 3AF Right exterior mirror: convex, electrically adjustable and heated
Right vanity mirror 4TC Right vanity mirror with cover
Seat belt check 9P1 Seat belt reminder, electric contact in buckle
Seat covering N2M Fabric seat covering
Shock absorption, chassis, front G33 Front shock absorption
Ski bag 3X0 Without load-through provision
Speaker installation 8RM 8 speakers (passive)
Special labels/plates 2KP Labels/plates in Polish and English
Tie down straps/net/pocket 6M2 Load safety net
Tires H3E Tires 195/65 R15 V (black)
Vehicle class differentiation units/platform components 0CH Vehicle class differentiation 1U0
Weight category front axle L09 Suspension range 09 installation control only, no requirement forecast
Wheels C6F Alloy wheels 6J x 15
Windshield glass type 4GC Windshield in heat-insulating glass with sunshield
PHA
Base engine T8U 4-cylinder diesel engine 1.9 L unit 038.G
Front seats Q4H Comfort sports seats, front
Instrument inserts U1A Instrument insert with km/h speedometer, clock, tachometer and trip odometer
Tire suppliers V0A Tires w/o specification of tire brand Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ3B157544
Date of production 09.04.2003
Model year 2003
Sales type 1J1086
Engine code ASZ
Transmission code ERF
Axle drive 6S
Interior trim code 82
Roof color 8E
Exterior color / Paint Code 8E / A7W
Brake type, front 1ZE Disc brakes, front (Geomet D)
Brake type, rear 1KS Disc brakes, rear (Geomet D)
Chrome work package QJ1 Chrome work package
Doors 0A2 4 doors
Floor coverings 3MH Dilours floor covering w/o scuff guard
Floor mats 0TD Front and rear floor mats
Front seats Q4P Sports front seats
General operating permit, alterations C28 Operating permit, alteration
Inserts 5TX Decorative inserts for special edition
Manufacturing sequence differentiation 0FC Brussels manufacturing sequence
Nameplate set 1DG Nameplate set "TDI"
Owner's manuals 0VB Information kit in French
Reading light 8S8 2 reading lights
Shock absorption, chassis, front G38 Front shock absorption
Shock absorption, chassis, rear UB8 Rear shock absorption
Special editions E3G "Pacific"
Weight category front axle L06 Suspension range 06 installation control only, no requirement forecast
Wheels CB2 Cast alloy wheels 6.5J x 16 offset 42 (1C0 601 025 H)
W4T
WKA
WRA Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ4D015131
Date of production 30.09.2003
Model year 2004
Sales type 1J1086
Engine code ASZ
Transmission code FMH
Axle drive 6S
Interior trim code 76
Roof color 8E
CD changer/CD player 7A3 CD player
Component part sets with country-specific design requirements B0J Component parts set, complying with vehicle type for Italy, various parts
Doors 0A2 4 doors
Emission standard 0GZ Emission standard EU3, diesel with EOBD
General operating permit, alterations C32 Operating permit, alteration
Owner's manuals 0VG Information kit in Italian
Radios 8AQ Radio "beta" with removable operating panel
Special editions E5E "Last Edition"
Special labels/plates 0SK Labels/plates in Italian
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Type approval countries/countries with special requirements B14 Type approval Italy (San Marino, Vatican City)
Wheels C3K Cast alloy wheels 6.5J x 16 BBS, one-piece, offset 42
PH2
RBH
W2T
W4T
WLE Kod: Zaznacz cały
Vehicle Identification No. VSSZZZ1MZYB024088
Model Designation toledo sport
Date of production 19.07.1999
Model year 2000
Sales type 1M25P4
Engine code AGN
Transmission code EBD
Axle drive 5S
Roof color 2F
Exterior color / Paint Code 2F /
Additional tunnel cover 4J2 Floor tray, extension center console
Braking systems 1AH Electronic differential lock (EDL)
Bumper 2JF Painted bumpers
CD changer/CD player 7A1 CD changer preparation
Doors 0A2 4 doors
Emission standard 0GF Emission standard D3 EU3D
Engine specifications MQ8 4-cyl. gasoline engine 1.8 L/92 kW 20V EU 3D base engine is T0V
Equipment levels A8F Sports equipment
Exterior mirror setting 6XE Exterior mirrors: electrically foldable and electrically adjustable/heated
Gearshift knob/handle 6Q5 Sports gearshift knob
General operating permit, alterations C03 Operating permit, alteration
Headlight 8BB Halogen headlight for driving on the right
Headphone port, rear 8MB Headphone port rear
Heated rear window 8P1 Heated rear window
Insert for the filling up of unleaded fuel/fuel type 2G9 Filler neck module 2 with insert
Interior light in driver compartment 9GA Interior light with door pillar switches
Key for locking system 8QE Key for locking system with remote control
Luggage compartment cover 3U4 Luggage compartment cover
Luggage net/pocket on backrest(s) 4U3 Luggage net on backrest, right seat
Molding roof liner 6NA Unsplit molding roof liner
Nameplate set 0QG Nameplate set "20V"
Owner's manuals 0VF Information kit in English
Radios 8YE Radio for comfort-class vehicle
Rear fog light 8TF Rear fog lights, left and right
Rear headrests 3Q6 Three rear headrests
Rear license plate carrier 6P0 Without license plate carrier rear
Seat covering N2C Fabric seat covering
Shock absorption, chassis, front 1GL Front shock absorption, sports design 2
Shock absorption, chassis, rear 1JC Rear shock absorption for sports design
Side lights 8F6 Dark colored side turn signal lights
Special labels/plates 0SC Labels/plates in English
Tool kit and jack 1S1 Tool kit and jack
Trailer hitch 1D3 Trailer hitch
Trunk sill protection 2P1 Plastic trunk sill protection
Vehicle class differentiation units/platform components 0CK Vehicle class differentiation 1M0
Wheels C7F Alloy wheels
PE1
RB2
Base engine T0V 4-cylinder gasoline engine 1.8 L unit 06A.A
Control number (no PR-Family) SV8 Oil change for GTI Nigeria
Wheels V23 Alloy wheels
