Nie daj się oszukać, sprawdź VIN i historię
Nie daj się oszukać, sprawdź VIN i historię /czytaj 1 post/
Nie da się rozkodować tego toledo VSSZZZ1MZ4R122334 ?
Witam.
Czy mógłbym prosić o sprawdzenie tego vinu: TMBHS21Z182209947
Dzięki i pozdrawiam
Dzięki i pozdrawiam
Kod: Zaznacz cały
Vehicle Identification No. WV1ZZZ70Z2X095823
Model Designation transp. van
Date of production 16.01.2002
Model year 2002
Sales type 7DA1U2
Engine code AJT
Transmission code EWB
Axle drive 5S
Interior trim code BX
Roof color T7
Exterior color / Paint Code T7 / 902
Activated carbon canister 1E0 Without activated charcoal canister
Additional air-borne noise suppression measures 1J0 Without additional sound absorbing measures
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2WA Without additional tires
Additional ventilation system 7J0 Without additional ventilation system
Air bag 4UC Air bag for driver
Air cleaner (engine) 1L0 Standard air cleaner
Antennas 8L1 Bright rod antenna
Anti-theft protection system 7AA Electronic vehicle immobilization device
Antidrum measures 2N1 Standard anti-drum measures
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Armrests for front seats 4S0 Without armrests for front seats
Auxiliary heating 9M0 Without auxiliary/parking heater
Base engine T7K 5-cylinder diesel engine 2.5 L unit 074.5
Batteries J0R Battery 380 A (80 Ah)
Body style K4A Panel van
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake type, front 1LU Disc brakes, front
Braking systems 1AB Power brake
Bumper 2JB Standard bumpers
C-rails 6L0 Without C-rails
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A0 Without CD changer/CD player
Carrier frequency for radio remote control 5D0 Without carrier frequency
Center high-mounted stop light 8R0 Without center high-mounted stop light
Chassis 2E2 15-inch chassis
Child lock 4H0 W/o child lock in passenger compartment
Climatic zones 0Y1 Standard climatic zones
Clutch actuation 1K2 Hydraulic clutch actuation
Component part sets with country-specific design requirements B0X Component parts set, complying with vehicle type for Germany, various parts
Components with special surface appearance 6FA Components without special surface appearance
Compressor 2AA Without compressor or preparation respectively
Control number (no PR-Family) S2D Control (in-plant)
Cruise control 8T0 Without cruise control system (CCS)
Cup holder 4M0 Without cup holder
Curtains/roller blinds 5G0 Without curtains
Dashboard 4N2 Standard dashboard
Delivery equipment 2A0 Without delivery equipment
Different vehicle equipment 5EA Without different vehicle equipment
Differential lock 1Y0 Without differential lock
Door and lid locking system 4F0 Mechanical locking system
Door and side trim panels 3LN Unpainted door trim panel
Door pockets, front 3YB Door pockets, front
Doors, cab 0D1 Cab doors
Doors, passenger/load compartment, left 5Q0 Without door in load/passenger compartment left (closed side panel)
Doors, passenger/load compartment, right 5R2 Sliding door right in load/passenger compartment
Drive layout 1X0 Front wheel drive
Emission standard 0GE Emission standard EU3
Engine specifications MP2 5-cylinder diesel engine 2.5 L/65 kW TDI base engine is T7K
Equipment levels A8B Basic equipment
Exterior mirror setting 6XA Exterior mirrors: adjustable from outside
Final drive/gear ratio 0ZN Transmission ratio, high geared
Floor coverings in cab 5AC Rubber floor covering in cab
Floor coverings in passenger and load compartment 5BA Without floor covering in passenger/load compartment
Folding table 1U0 Without table
Fourth row of seats 3WA Without bench seat
Frame forestructure AC0 Short frame forestructure
Fresh air unit/air outlet 6LD Fresh air unit with center outlet and recirculation door, without load/ passenger compartment ventilation
Front Assist 6K0 without Front Assist/without city automatic emergency braking
Front fog light/additional headlight 8WA Without front fog light
Front seat, left 3TH Seat in cab, left
Front seat, right 3SH Seat in cab, right
Front side window for load or passenger compartment, left 4DA Without side window aperture in load compartment, front left
Front side window for load or passenger compartment, right 4EA Without side window aperture in load compartment front right
Front stabilizer 0AB Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
General operating permit, alterations C13 Operating permit, alteration
Generators 8GD Alternator 90A
Headlight 8BB Halogen headlight for driving on the right
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 3J4 Headrests for front seats
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AA Manually controlled heating system
Hinges for side and tail gates 5V0 Without hinges for side and tail gates
Hood and trunk stay 5NC Standard tailgate stay
Horns 8Y0 Single-tone horn
Hydraulic pump 2BA Without hydraulic pump
Identification lights, roof 9KA Without identification lights
Identification plates 1EC Special identification plate
Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Interference suppression 8E0 Without interference suppression
Interior light in driver compartment 9GA Interior light with door pillar switches
Interior lights, passenger and load compartment 9CC Two standard interior lights in passenger/load compartment
Interior noise suppression measures 3W6 Additional interior noise suppression
Lashing rings/rails for load restraint 6B1 Lashing rings for load restraint
Leather parts scope 3HA Without leather parts scope
Left exterior mirror 5SL Left exterior mirror: aspherical
Left vanity mirror 4SA Without left vanity mirror
Light assistance system 8G0 Without light assistant
Lock operation for tailgate/trunk lid 4E3 Without tailgate release lever inside
Malfunction display 9HA Without additional malfunction display
Manufacturing sequence differentiation 0FM Poland manufacturing sequence
Mounting fixture for oxygen bottle 5P0 W/o mounting fixture for oxygen bottle
Mud flap 6N0 Without mud flaps
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Nameplate set 0NB Nameplate set in base trim
Navigation device 7Q0 Without navigation device
Owner's manuals 0VC Information kit in German
Paint preservative/transit coating 5K1 Paint preservative (wax)
Partition 3CF Partition without window
Payloads 0J1 Reduced payload
Pickup bodywork/cargo area 5HA Without pickup bodywork/cargo area
Preparation for identification lights 9QA Without identification light preparation
Radios 8AA Without radio
Rear fog light 8TC Rear fog light for driving on the right
Rear gates/tailgate 3RB Trunk lid without window aperture
Rear headrests 3Q0 Without rear headrests
Rear side window for load or passenger compartment, left 4FA W/o side window aperture in load comp. rear left
Rear side window for load or passenger compartment, right 4JA W/o side window aperture in load comp. rear right
Rear stabilizer 0BA Without rear stabilizer
Rear window insert 4HA Without rear window
Rear window wiper and washer system 8M0 W/o rear window wiper and washer system
Refrigerator 1W0 Without refrigerator/glove compartment cooling system
Restraint systems, front 3QC 3-point seat belts, front
Retaining cables for tail and side gates 5T0 Without retaining cables for tailgate
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TA Without right vanity mirror
Roof insert in cab 3EA Without roof insert in cab (closed)
Roof insert in driver's/load compartment 3JA Without roof insert in load and passenger compartment
Roof interior trim 5CL Roof interior trim in cab as comfort molded headlining, in load/passenger compartment with hardboard
Roof turn signal lights 9H0 Without roof turn signal lights
Roof types 3R0 Standard roof
Seat belt check 9P0 Without seat belt reminder
Seat belts for first row of seats passenger compartment 4PA Without seat belts in first row of seats
Seat belts for second row of seats passenger compartment 4RA Without seat belts second row of seats
Seat belts for third row of seats passenger compartment 4VA Without seat belts in third row of seats
Seat covering N0A Woven fabric seat covering
Seat heater 4A0 Without seat heater
Seat storage trays, first row of seats passenger compartment 4G0 W/o storage trays, first row of seats
Seat storage trays, second row of seats passenger compartment 4WA W/o storage trays, second row of seats
Seating comfort 5Y0 Standard seat padding
Second battery/battery installation 8FA Without second battery
Second generator 8HA Without second alternator or preparation
Second heat exchanger 6AA Without second heat exchanger
Second row of seats 3UA Without seats
Service interval prolongation QG1 Service interval prolongation
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Side interior trim, passenger and load compartment 5DA Side trim panel for basic equipment
Socket 7B0 Without socket
Sound combination for rotating emergency light 9LA Without rotating emergency lights
Spare wheel mounts 1B1 Standard spare wheel bracket
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RD 2 speakers (passive)
Special editions E0A No special edition
Special labels/plates 0SB Labels/plates in German
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Stacking panel in load compartment 3E0 W/o stacking panel in load compartment
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2PG Steering wheel
Step illumination 9N0 Without step illumination
Sticker (customized or special edition) 0KA Without stickers and badges
Stowage box 3Z0 Without stowage box
Strip and films all-around 5M0 Without warning strip and films
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
Suspension, chassis 1P0 Standard suspension
Tachograph/logbook 9NA Without tachograph
Tail and side gates 5S0 Without tail and side gate(s)
Telephone/telematics 9W0 W/o car phone preparation/installation
Third row of seats 3VA Without seats
Tire suppliers V0A Tires w/o specification of tire brand
Tires H0Y Tires 165/65 R15 81T reduced rolling resistance
Tool kit and jack 1S1 Tool kit and jack
Top frame and tarpaulin 5GA Without pickup bodywork/tarpaulin
Trailer hitch 1D0 Without trailer hitch
Transmission specifications G0C 5-speed manual transmission
Transmission types/gearshift mechanisms 0G1 Gearshift lever
Tray areas, cab 5FF Console under dashboard, center
Type approval countries/countries with special requirements B01 Type approval Germany
Underseal 5U0 Standard underseal
Vehicle class differentiation units/platform components 0CN Vehicle class differentiation 7D0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Versions FM0 Basic equipment variant
Wheel covers 1NE Wheel center cover
Wheelbases 0E1 Short wheelbase
Wheels C7X Alloy wheels
Window regulator 4R0 Mechanical window regulator
Windows, cab 4CC Cab side window in heat-insulating glass
Windshield glass type 4GF Windshield in heat-insulating glass
Z36 Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1KZ8M280412
Model Designation golf estate
Date of production 08.05.2008
Model year 2008
Sales type 1K5121
Engine code BLS
Transmission code JCR
Axle drive 5S
Interior trim code KU
Roof color 2R
Exterior color / Paint Code 2R / D7X
"Multimedia", video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional child seat anchors 3B4 Child seat anchor for child seat system ISOFIX
Additional tires (winter tires) 7DD Winter tires 195/65 R 15 91H with steel wheel 6J x 15, offset 47 with full wheel cover
Additional warning lights 9TC Additional reflectors (door area)
Air bag 4UF Driver's and front passenger air bag with front passenger air bag deactivation
Antennas 8ZN Antenna
Backrest release 3H2 Backrest release for right front seat
Batteries J0L Battery 340 A (70 Ah)
Battery/alternator capacity NY0 Standard battery/alternator capacity
Body measures 5C0 Without special body measures
Body style K8D Station Wagon Variant/Avant
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1ZM Disc brakes, front (Geomet D)
Brake type, rear 1KF Disc brakes, rear
Braking systems 1AT Electronic stabilization program (ESP)
Breakaway interior mirror 4L6 Breakaway interior rear view mirror, automatically dimming
Bumper 2JC Comfort bumpers
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Center armrest 6E3 Front center armrest
Center rear seat belts 3C7 3-point seat belt for center rear seat
Child seat anchor, front 3G0 Without child seat anchor front (ISOFIX)
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Cruise control 8T2 Cruise control system (CCS) electronic
Customized installation FC0 Without customized installation
Delivery equipment 2A8 Delivery equipment for shipment
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YR Door pockets with insert mats
Doors 0A2 4 doors
Emission standard 7GG Emission standard EU4 DPF
Engine cooling system 8Z5 Not hot country
Engine specifications D3W 4-cyl. turbo diesel engine 1.9 L/77 kW TDI with pump-jet injection system Base engine is T71/TG0/TD0/T5X
Equipment levels A8C Comfort equipment
Exhaust tailpipe 0P0 Rear exhaust tailpipe (standard)
Exterior mirror setting 6XG Exterior mirrors: with memory function, electrically adjustable/heated
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T2 Warning triangle
Floor mats 0TD Front and rear floor mats
Front license plate carrier 6W1 License plate carrier front (large)
Front seat, left 3TF Comfort seat, front left
Front seat, right 3SF Comfort seat, front right
Front stabilizer 0AH Front stabilizer
Fuel systems 0F8 Cooled fuel system for diesel engine
Fuel tank treatment 2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C12 Operating permit, alteration
Generators 8GU Alternator 140 A
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Headlight activation 8K8 Low beam assistant with "Coming Home" function
Headlight washer system 8X1 Headlight washer system
Headrests 3J1 Height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E6 Electric auxiliary air heater
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Inserts 5MA Decorative inserts
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Interior light in foot area 6T1 Interior light in footwell
Left vanity mirror 4SD Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U6 Luggage net
Luggage compartment lining 5A2 Comfort trunk lining
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Lumbar support 7P4 Manually adjustable lumbar support in front seats
Manufacturing sequence differentiation 0FL Mexico manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 0NA Without nameplate set (without model designation)
Operating voltage 9Z0 Operating voltage 12V
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K5 Transit coating film with additional transport protection measures
Park distance control 7X1 Park distance control
Partition 3CX Net partition
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P3 Rear floor panel module, type 4
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Protective side molding 4B0 Without protective side molding
Radios 8AG Radio with CD/MP3
Reading light 8S4 Two reading lights front, two rear
Rear cargo area 3GD Plane rear cargo area
Rear headrests 3T2 Three rear headrests
Rear license plate carrier 6P1 License plate carrier rear (ECE)
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Rear spoiler 5J0 Without rear spoiler
Rear stabilizer 0BG Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Refrigerator 1W2 Glove compartment cooling system
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S2 Black roof rails
Rough-road/sports version 2UA Standard design
Safety headrest system 3K0 Without safety headrest system
Scuff plates 7M5 Without protective film for scuff plate
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P3 Seat belt reminder, electric contact in buckle
Seat covering N3L Circular-knit cut pile seat covering
Seat heater 4A3 Seat heater for front seats separately controlled
Shock absorption, chassis, front G67 Front shock absorption
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side air bag 4X3 Side air bag front with curtain air bag
Side and rear windows 4KF Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
Side lights 7R3 Side turn signal lights (white)
Ski bag 3X0 Without load-through provision
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B2 12-volt socket in luggage boot
Speaker installation 8RM 8 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special labels/plates 2KW Labels/plates in German, French, and Dutch
Special registration measures 3M0 Without special measures
Steering 1N3 Speed-related variable steering assist (Servotronic)
Steering wheels 1MH Leather steering wheel
Tire pressure warning light 7K6 Flat tire indicator
Tires HH7 Tires 205/55 R16 91V
Trunk sill protection 2P1 Plastic trunk sill protection
Upgrading measures GP0 Vehicles w/o special upgrade measures
Vehicle class differentiation units/platform components 0HM Vehicle class differentiation -1KM- Build status corresponds to production in Mexico
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L07 Suspension range 07 installation control only, no requirement forecast
Weight category rear axle 0YG Weight range 7 installation control only, no requirement forecast
Wheel covers 1NY Full wheel covers
Wheels CM1 Steel wheels 6.5J x 16
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield wiper intermittent control/ light/rain sensor 8N3 Windshield wiper intermittent control with rain sensor
P15
PH2
PME
Child seats QA0 Without child seat
Chrome work package QJ1 Chrome work package
Compass/traffic sign display QR0 Without compass/traffic sign display/ traffic signs recognition
Drawers under front seats QN3 Drawers under front seats
Electronic map cooling system QS0 Without electronic map cooling system
Nameplates for sales name QD0 Without lettering for sales name
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
RCL
Air duct, front area VK0 Air duct, standard
Base engine TG0 4-cylinder diesel engine 1.9 L unit 03G.6
Electric interface for external use UF0 Without electric interface
Hill hold control UG0 Without hill hold control / hill descent control / comfort driving assist
Instrument inserts U5A Instrument insert, km/h speedometer
Marten repeller UM0 Without marten repeller
Pedal cluster VF0 Standard pedal cluster
Pedestrian protection VL0 Standard pedestrian protection measures
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
WW1 Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ7MZ5V018409
Model Designation sharan
Date of production 18.11.2004
Model year 2005
Sales type 7M63C3
Engine code ASZ
Transmission code FUX
Axle drive 6S
Interior trim code JV
Roof color 8E
Exterior color / Paint Code 8E / A7W
Anti-theft protection system 9V7 Electronic vehicle immobilization device with anti-theft alarm system and passenger compartment control
Auxiliary heating 9M5 Auxiliary heater
Body style K8P MPV
Bumper 2JG Body-colored bumpers
CD ROM/DVD/SD card 7QB CD ROM (Germany)
Center armrest rear 6D7 With rear armrests
Controls (steering wheels/steering column) 4LA Without controls
Door and lid locking system 4K1 Radio remote controlled central locking
Door and side trim panels 4AB Door and side trim panel partially in leather
Electric safety package 9BC Display and warning tone f. opened doors
Engine specifications D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Equipment levels A8T Executive equipment
Exterior mirror setting 6XE Exterior mirrors: electrically foldable and electrically adjustable/heated
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Floor coverings 3MG Tufted fine cut pile floor covering
Floor mats 0TL Front and rear floor mats (leatherette binding)
Front fog light/additional headlight 8WD Integrated front fog light
Fuel systems 0F3 Fuel system for diesel engine
General operating permit, alterations C26 Operating permit, alteration
Generators 8GL Alternator 120 A
Headlight activation 9C0 Without special headlight activation mode but with "Coming and Leaving Home" feature
Heating and air conditioning system 9AH Climatronic with second evaporator and second heating system
Insert for the filling up of unleaded fuel/fuel type 2G9 Filler neck module 2 with insert
Inserts 5TF Decorative wood inserts
Interior lighting 9ME Comfort interior lighting
Leather parts scope 3HG Leather parts scope
Lockable wheel bolts 1PB Lockable wheel bolts
Luggage compartment cover 3U4 Luggage compartment cover
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Marque-specific/class-specific features 0Z0 VW marque-specific/class-specific features
Navigation device 7Q2 Navigation system with color screen
Protective side molding 4B1 Protective side molding
Radios 8AY Radio/navigation system
Roof rails/roof load rack 3S1 Bright roof rails
Seat covering N7K Alcantara/leather seat covering
Second row of seats 3UL 2 sports seats
Side air bag 4X1 Side air bag front
Side and rear windows 4KH Green tinted side windows, from B-pillar and rear window laminated glass w/ metal layer, man. oper. hinged quarter window
Speaker installation 8RX Passive speakers
Steering wheels 1MR Leather steering wheel
Sun visors 5XC Sun visors with illuminated vanity mirror on driver's and front seat passenger's side
Swiveling front seats 3A0 Without swiveling front seats
Third row of seats 3VP 2 sports seats
Tires H1V Tires 225/45 R17
Top carrier NG0 Without top carrier
Transmission specifications G0M 6-speed manual transmission top speed in fifth gear
Upgrading measures GP1 Vehicles with special upgrade measures
Vehicle class differentiation units/platform components 0DQ Installation differentiation for build status of vehicle class B (MPV) unit components
Wheels CX8 Alloy wheels 7J x 17
Window regulator 4R3 Power windows with comfort operation
Windshield glass type 4GX Windshield in heat-insulating glass, heated
Windshield wiper intermittent control/ light/rain sensor 8N2 Windshield wiper intermittent control infinitely variable
PH5
PI1
PJ7
PW2
Front seats Q1D Sports front seats
Tray areas package QE0 Without tray areas package/box
RHA
Control number (no PR-Family) SZ9 Delivery by "Autostadt Wolfsburg"
Instrument inserts U3M Instrument insert with tachometer trip-odometer, km/h speedometer
WT1 Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Kod: Zaznacz cały
Vehicle Identification No. TMBHS21Z182209947
Model Designation octavia comb.ambiente
Date of production 24.07.2008
Model year 2008
Sales type 1Z5264
Engine code BXE
Axle drive 5S
Interior trim code BK
Roof color 1Z
Exterior color / Paint Code 1Z / F9R
"Charism" 2H0 Without "drive select"
"Multimedia", video/DVD/notebook connection 9WR Installation of audio connection
Adapter (for trailer hitch) ND0 Without adapter
Additional warning lights 9TB Additional warning lights (door area)
Antennas 8L3 Roof antenna
Backrest release 3H0 Without backrest release for front seats
Batteries J0N Battery 330 A (61 Ah)
Brake type, front 1ZF Disc brakes, front (Geomet D)
Brake type, rear 1KD Disc brakes, rear
Braking systems 1AC Anti-lock brake system (ABS)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Breakdown spray GR0 Without emergency tire inflator
Component part sets with country-specific design requirements B1M Component parts set for Czech Republic
Components with special surface appearance 6FB Body-colored exterior mirror housings
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Dashboard 4N1 Padded dashboard
Dashboard illumination 7V0 Standard dashboard illumination
Door and side trim panels 3LT Door and side trim panel
Doors 0A2 4 doors
Doors/trays in trunk 3N2 Stowage box with cover in luggage boot side panel
Emission standard 0GG Emission standard EU4
Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
Floor mats 0TA Without floor mats
Front fog light/additional headlight 8WB Front fog lights
Front seat, left 3TB Standard seat, front left
Front seat, right 3SB Standard seat, front right
Front stabilizer 0AE Front stabilizer
Fuel filler cap/door, locking option 2W3 Fuel filler cap remote unlocking
Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
General operating permit, alterations C00 Operating permit, initial registration
Glove compartment 4Z5 Glove compartment door with light
Hand brake lever handle 6PA Plastic hand brake lever handle
Headlight 8JM Twin headlight for driving on the right, with integrated high beam
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heating and air conditioning system 9AP Climatic air-conditioning system (semi-automatic)
Hood and trunk stay 5NA Hood stay
Inserts 5MD Decorative aluminum inserts
Interior light in driver compartment 9GG Two interior lights with door pillar switches
Interior light in foot area 6T0 Without interior light in footwell
Key for locking system 8QL Key for locking system with remote control
Left vanity mirror 4SB Vanity mirror left
Luggage compartment cover 3U2 Sliding trunk cover
Luggage compartment floor covering 6SA Without trunk floor covering
Luggage compartment lighting 9E3 Luggage compartment lighting
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Nameplate set 1RX Nameplate set in base trim
Outdoor temperature gage 9Y1 Outdoor temperature gage
Owner's manuals 0VT Information kit in Polish
Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
Parking light indicator light 8NB Parking light indicator light
Partition 3CA Without partition
Platform group class 7PB Platform group class 2
Radios 8YH Radio, version 1
Reading light 8S5 Two reading lights front
Rear cargo area 3GA Without cargo area
Rear headrests 3Q6 Three rear headrests
Rear stabilizer 0BD Rear stabilizer
Right vanity mirror 4TB Vanity mirror right
Safety certificate 0LA Without special plates/stickers/ safety certificates
Seat belt check 9P1 Seat belt reminder, electric contact in buckle
Seat covering N2M Fabric seat covering
Shock absorption, chassis, front G02 Front shock absorption
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 7R6 Side turn signal lights in exterior mirrors
Smoking/non-smoking package 9JD Smoking package, ashtray front
Speaker installation 8RE 4 speakers (passive)
Special labels/plates 2KE Labels/plates in Czech and Slovakian
Steering wheels 1MA Steering wheel
Tie down straps/net/pocket 6M5 Trunk net
Tire pressure warning light 7K0 Without tire pressure warning light
Tires H7F Tires 195/65 R15 91H
Tray 7N0 Without tray on roof liner
Type approval countries/countries with special requirements B17 Type approval Poland
Vehicle class differentiation units/platform components 0HF Vehicle class differentiation 1Z0
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category front axle L06 Suspension range 06 installation control only, no requirement forecast
Weight category rear axle 0YF Weight range 6 installation control only, no requirement forecast
Wheel covers 1NN Full wheel covers
Wheels C8V Steel wheels 6J x 15
Windshield wiper intermittent control/ light/rain sensor 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PDC
PG0
PH4
Chrome work package QJ3 Chrome package (type 2)
Drawers under front seats QN2 Drawer under right front seat
Tray areas package QE4 Tray areas package 2
RAB
Base engine T71 4-cylinder diesel engine 1.9 L unit 03G.1
Instrument inserts U4A Instrument insert, km/h speedometer
Tire suppliers V0A Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Re: Nie daj się oszukać, sprawdź VIN i historię /czytaj 1 po
Niestety nie.luckd pisze:Nie da się rozkodować tego toledo VSSZZZ1MZ4R122334 ?
Czy mogę prosić o rozkodowanie tego VINu: WVWZZZ1KZ6W015005
Dziękuję i pozdrawiam wszystkich
Prosiłbym o rozkodowanie VIN : WVWZZZ1HZSP079097
Z góry dziękuje
Z góry dziękuje
Witam prosił bym o rozkodowanie VIN : WVWZZZ1JZYW739497
Bardzo proszę o sprawdzenie poniższych VIN (zależy mi też pod stopniem serwisowania czy przebiegi km są wiarygodne)
TMBJC26Y743964538
TMBWU46Y243892405
WVWZZZ1JZ2D203367
WVWZZZ3BZ2P187455
Odpowiedz prosze przesłać na pw
Z góry wielkie dzięki
TMBJC26Y743964538
TMBWU46Y243892405
WVWZZZ1JZ2D203367
WVWZZZ3BZ2P187455
siema
proszę o sprawdzenie tego vinu
WVWZZZ6EZ3W001873
pozdrawiam
WVWZZZ6EZ3W001873
pozdrawiam
Zakupiony nabytek
Poproszę jeszcze tego:
WVGZZZ1TZ6W206064
WVGZZZ1TZ6W206064
Witam ponoVWnie,
Panie i Panowie mam prośbę jako długo i wielo letni posiadacz aut marki VW (teraz znowu powrót do Golfa
) prosiłbym o rozkodowanie tego numeru VIN - WVWZZZ1JZXD129647
z góry dziękuje.
z góry dziękuje.
[url=http://www.fotosik.pl][img]http://images27.fotosik.pl/138/3791d8d257bf8b24.jpg[/img][/url]
Witam można sprawdzic numer identyfikacji
Golf mkI
1793378320
Golf mkI
1793378320
Jest MKI
http://forum.vwgolf.pl/viewtopic.php?f=86&t=486325" onclick="window.open(this.href);return false;
Robi się drugie MKI
http://forum.vwgolf.pl/viewtopic.php?f=86&t=577885" onclick="window.open(this.href);return false;
Był MkIII
http://forum.vwgolf.pl/viewtopic.php?f=88&t=451235" onclick="window.open(this.href);return false;
Robi się drugie MKI
Był MkIII
prosilbym o rozkodowanie ponizszego numeru VIN>
WVWZZZ1JZ3W308675
Golf 4 1.9 tdi
2003
stan licznika: ok. 199 tys.
Z gory dziekuje za pomoc. Prosilbym o info na PW.
WVWZZZ1JZ3W308675
Golf 4 1.9 tdi
2003
