Niepoprawny numer, na końcu powinno być 6 cyfr numeru seryjnego pojazduoczek29 pisze:Proszę o rozkodowanie
VIN: WVWZZZ1KZ6W16260
Nie daj się oszukać, sprawdź VIN i historię
Moderatorzy: palio, jhosef, VIP
Re: Nie daj się oszukać, sprawdź VIN i historię
Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
- olozwirski
- 2 SLOW 2 PLAY
prosilbym o sprawdzenie vinu jesli jest taka mozliwosc..
WVWZZZ1JZYU002563
z gory dzieki
pozdrawiam
WVWZZZ1JZYU002563
z gory dzieki
pozdrawiam
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZYU002563
Model Designation golf 2.0
Date of production 26.05.1999
Model year 1999
Sales type 1J12B4
Engine code AQY
Transmission code EGC
Axle drive 5S
Interior trim code KL
Roof color X1
Exterior color / Paint Code X1 / B7Z
Activated carbon canister 1E1 Activated carbon canister
Additional body covers, side 6EJ Additional body cover on sill without wheel arch
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2WA Without additional tires
Additional tunnel cover 4J1 Floor tray, extension center console
Additional warning lights 9TB Additional warning lights (door area)
Air bag 4UE Air bag for driver and front seat passenger
Antennas 8L3 Roof antenna
Anti-theft protection system 7AA Electronic vehicle immobilization device
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H9 Backrest release for front seats with "Easy Entry"
Base engine T6Y 4-cylinder gasoline engine 2.0 L unit 06A.D
Batteries J1L Battery 280 A (60 Ah)
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake pad wear indicator 9U0 Without brake pad wear indicator
Brake type, front 1LS Front disc brakes with integrated adapter
Brake type, rear 1KK Disc brakes, rear
Braking systems 1AH Electronic differential lock (EDL)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JB Standard bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A0 Without CD changer/CD player
Carrier frequency for radio remote control 5D0 Without carrier frequency
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E3 Front center armrest
Center rear seat belts 3C1 Static lap belt, center rear
Chassis 2E0 Base chassis
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Components with special surface appearance 6FE Body-colored exterior mirror housings and tailgate handle
Cruise control 8T0 Without cruise control system (CCS)
Cup holder 4M6 Cup holder
Door and lid locking system 4F1 Central locking system
Door and side trim panels 4AR Door and side trim panel in foam film and circular-knit
Door pockets, front 3YR Door pockets with insert mats
Doors 0A1 2 doors
Drive layout 1X0 Front wheel drive
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z5 Not hot country
Engine specifications ML1 4-cylinder gasoline engine 2.0 L/85 kW multi-point injection, EU 4/D4 base engine is T6Y
Equipment levels A8C Comfort equipment
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B7 Additional exterior noise suppression
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Flame retardent materials 4Q1 Flame retardent materials
Floor mats 0TQ Front and rear floor mats (polypropylene)
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 8WD Integrated front fog light
Front license plate carrier 6W1 License plate carrier front (large)
Front stabilizer 0AM Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F2 Fuel system for carburetor gasoline engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift boot/cover 6R1 Leatherette gearshift boot
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
General operating permit, alterations C08 Operating permit, alteration
Generators 8GD Alternator 90A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Hand brake lever handle 6PA Plastic hand brake lever handle
Headlight 8JS Twin headlight for driving on the right with clear lens
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AB Manually controlled air conditioning
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Inserts 5MA Decorative inserts
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Key for locking system 8QC Key with light
Left exterior mirror 5SL Left exterior mirror: aspherical
Left vanity mirror 4SD Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lighting 9E1 Luggage compartment lighting
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Lumbar support 7P4 Manually adjustable lumbar support in front seats
Manufacturing sequence differentiation 0FV South Africa manufacturing sequence
Molding roof liner 6NH Comfort molding roof liner unsplit roof cutout rear (radio antenna)
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Nameplate set 1DB Nameplate set "2.0"
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Paint preservative/transit coating 5K1 Paint preservative (wax)
Park distance control 7X0 Without park distance control
Partition 3CA Without partition
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B1 Protective side molding
Radiator grille 6KG Radiator grille
Radios 8AC Radio "beta"
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N1 Standard rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q1 Rear headrests
Rear license plate carrier 6P1 License plate carrier rear (ECE)
Rear seat catch 6QA Rear seat catch
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Rear stabilizer 0BC Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P0 Without seat belt reminder
Seat covering N0U Cut pile seat covering
Seat heater 4A0 Without seat heater
Service interval prolongation QG0 Without service interval prolongation
Shock absorption, chassis, front 1GC Front shock absorption, basic design 3
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side air bag 4X1 Side air bag front
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 8F2 Side turn signal lights
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B2 12-volt socket in luggage boot
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RE 4 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E0A No special edition
Special labels/plates 0SB Labels/plates in German
Special registration measures 3M0 Without special measures
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering 1N1 Power steering
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 1MP Steering wheel for air bag system
Sticker (customized or special edition) 0KA Without stickers and badges
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
Taillight assemblies 8SA Taillight assemblies, standard design
Telephone/telematics 9W0 W/o car phone preparation/installation
Throttle actuation 0L0 Mechanical throttle actuation
Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
Tires H6S Tires 195/65 R15 V
Tool kit and jack 1S7 Tool kit and aluminum jack
Trailer hitch 1D0 Without trailer hitch
Transmission shafts 1WB Transmission shafts w/ 100 mm in diameter
Transmission specifications G0C 5-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Trunk sill protection 2P0 Without trunk sill protection
Type approval countries/countries with special requirements B01 Type approval Germany
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheel covers 1ND Full wheel covers
Wheels C6E Steel wheels 6J x 15 Offset 38
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GF Windshield in heat-insulating glass
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PTA
Front seats Q2J Comfort front seats
RBA
Control number (no PR-Family) S0B Veh. w/ engineering build status of current model year a. vehicle identification no. of next model year
Control number (no PR-Family) S9Q Extension TV tuner Japan
Control number (no PR-Family) ST7 Model year change, calendar week 02
Control number (no PR-Family) SX6 Control of vehicles according to change request V98K07 (hood lock)
Tire suppliers V0A Tires w/o specification of tire brand
Weight category front axle U27 Suspension range 126
W02
WD3 Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
JohnnyCash
Prosiłbym o rozkodowanie VIN: WVWZZZ1JZ2B098794
Z góry dzięki
Z góry dzięki
Cześć,
Mam ładnego mkIV na oku, prosiłbym o sprawdzenie VIN:
WVWZZZ1JZ3W440277
Wielkie dzięki
WVWZZZ1JZ3W440277
Wielkie dzięki
Witam, znajomy upatrzył skodę octavię i tu moja prośba o sprawdzenie VIN'u:
TMBCS21Z262231849
Z góry dzięki !!
TMBCS21Z262231849
Z góry dzięki !!
- Micjusz
- I LOVE GERMAN CARS
Witam. Szukam informacji na temat polo nr VIN WVWZZZ9NZ3Y197595
Dzięki
Dzięki
Było:
Golf II Fire&Ice 1991, MK3 1.8AAM - 1993, MK2 1.3NZ - 1991, BMW E34 2.8 - 1992
Jest:
Bora - 1999, ETZ 150 - 1991, Komar 2352 - 1979
Jest:
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ2B098794
Model Designation golf tdi
Date of production 10.01.2002
Model year 2002
Sales type 1J1114
Engine code ALH
Transmission code EGR
Axle drive 5S
Interior trim code 32
Roof color 8E
Exterior color / Paint Code 8E / A7W
Activated carbon canister 1E0 Without activated charcoal canister
Additional body covers, side 6EA Without additional side body covers (stone guard)
Air duct, front area VK0 Air duct, standard
Anti-theft protection system 7AB Electronic alarm system with vehicle immobilization device (for RoW)
Backrest release 3H0 Without backrest release for front seats
Batteries J0L Battery 340 A (70 Ah)
Brake pad wear indicator 9U1 Brake pad wear indicator
Braking systems 1AC Anti-lock brake system (ABS)
Bumper 2JC Comfort bumpers
CD changer/CD player 7A3 CD player
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Center armrest 6E0 Without center armrest front
Component part sets with country-specific design requirements B0J Component parts set, complying with vehicle type for Italy, various parts
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Controls (steering wheels/steering column) 4LA Without controls
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Doors 0A2 4 doors
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GE Emission standard EU3
Engine specifications MD1 4-cyl. turbo diesel eng. 1.9 L/66 kW TDI base engine is T0W/T0E
Equipment levels A8M Executive comfort equipment
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Floor coverings 3MH Dilours floor covering w/o scuff guard
Floor mats 0TD Front and rear floor mats
Front fog light/additional headlight 8WA Without front fog light
Front stabilizer 0AL Front stabilizer
Fuel systems 0F3 Fuel system for diesel engine
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C24 Operating permit, alteration
Generators 8GL Alternator 120 A
Hand brake lever handle 6PC Leather hand brake lever handle
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FC Brussels manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 2QK Nameplate set "TDI"
Outer rear seat belts 3ZG 3-point seat belts, outer rear with height adjustment
Owner's manuals 0VA Without information kit
Paint coating FB0 Standard paint coating
Platform group class 7PA Platform group class 1
Protective side molding 4B2 Body-colored protective side molding
Radios 8AR Radio "gamma" with removable operating panel
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Rough-road/sports version 2UA Standard design
Seat covering N2Z Seat covering for special editions
Shock absorption, chassis, front G28 Front shock absorption
Side lights 7R3 Side turn signal lights (white)
Socket 7B0 Without socket
Speaker installation 8RM 8 speakers (passive)
Special editions E50 "GTI USA"
Special labels/plates 0SK Labels/plates in Italian
Steering wheels 2PX Leather trimmed sports steering wheel
Sticker (customized or special edition) 0KZ Stickers for special editions
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Throttle actuation 0L2 Electric throttle actuation
Tires H6U Tires 205/55 R16 91W
Tray 7N0 Without tray on roof liner
Type approval countries/countries with special requirements B14 Type approval Italy (San Marino, Vatican City)
Vehicle type AZ0 Vehicle with standard production scope
Weight category front axle L09 Suspension range 09 installation control only, no requirement forecast
Wheel covers 1NL Covers for alloy wheels
Wheels C7Y Alloy wheels 6.5J x 16
Windshield glass type 4GC Windshield in heat-insulating glass with sunshield
PH3
Child seats QA0 Without child seat
Chrome work package QJ1 Chrome work package
Front seats Q4H Comfort sports seats, front
Nameplates for sales name QD1 Nameplates for sales name
Service interval prolongation QG1 Service interval prolongation
RCH
Base engine T0W 4-cylinder diesel engine 1.9 L unit 038.B
W4U
WE1
WGQ Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ3W440277
Date of production 21.01.2003
Model year 2003
Sales type 1J1386
Engine code ASZ
Transmission code ERF
Axle drive 6S
Interior trim code RD
Roof color Z4
Exterior color / Paint Code Z4 / C9Z
Anti-theft protection system 7AP Electronic vehicle immobilization device w/ alarm syst., passenger comp. control, backup horn and all door opening
Brake type, front 1ZE Disc brakes, front (Geomet D)
Brake type, rear 1KS Disc brakes, rear (Geomet D)
Braking systems 1AT Electronic stabilization program (ESP)
CD ROM/DVD/SD card 7QK CD ROM (Italy)
Doors 0A2 4 doors
Engine specifications D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Equipment levels A8F Sports equipment
First aid kit / warning triangle 1T2 Warning triangle
Front stabilizer 0AE Front stabilizer
Fuel systems 0F9 Cooled fuel system for diesel engine
General operating permit, alterations C27 Operating permit, alteration
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Installation differentiation for vehicle components 0EN Installation differentiation for transmission MQ 350 vehicle components
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Multi-function display/trip computer 9Q2 Multi-function display/on-board computer with check control
Nameplate set 1DG Nameplate set "TDI"
Navigation device 7Q5 Navigation system with black-and-white screen
Owner's manuals 0VG Information kit in Italian
Radios 8AY Radio/navigation system
Rear axle 0N5 Standard rear axle
Rear stabilizer 0BB Rear stabilizer
Seat covering N2P Fabric seat covering
Shock absorption, chassis, front G38 Front shock absorption
Shock absorption, chassis, rear UB8 Rear shock absorption
Transmission specifications G0K 6-speed manual transmission
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L06 Suspension range 06 installation control only, no requirement forecast
Wheels CF5 Alloy wheels 6.5J x 16
PH6
Chrome work package QJ0 Without aluminum/chrome work package
Front seats Q4P Sports front seats
RLB
Base engine T9J 4-cylinder diesel engine 1.9 L unit 038.K
Control number (no PR-Family) SA0 Model year change calendar week 45
W4U
WBH
WE3 Kod: Zaznacz cały
Vehicle Identification No. TMBCS21Z262231849
Model Designation octavia ambiente
Date of production 24.02.2006
Model year 2006
Sales type 1Z3264
Engine code BKC
Transmission code GQQ
Axle drive 5S
Interior trim code BK
Roof color 1Z
Exterior color / Paint Code 1Z / F9R
Adapter (for trailer hitch) ND0 Without adapter
Additional child seat anchors 3B4 Child seat anchor for child seat system ISOFIX
Air bag 4UF Driver's and front passenger air bag with front passenger air bag deactivation
Base engine T71 4-cylinder diesel engine 1.9 L unit 03G.1
Batteries J0N Battery 330 A (61 Ah)
Battery/alternator capacity NY0 Standard battery/alternator capacity
Body style K8B Notchback
Brake type, front 1ZM Disc brakes, front (Geomet D)
Brake type, rear 1KD Disc brakes, rear
Breakdown spray GR0 Without emergency tire inflator
Center rear seat belts 3C7 3-point seat belt for center rear seat
Child seat anchor, front 3G0 Without child seat anchor front (ISOFIX)
Chrome work package QJ3 Chrome package (type 2)
Climatic zones 0Y1 Standard climatic zones
Component part sets with country-specific design requirements B1M Component parts set for Czech Republic
Components with special surface appearance 6FB Body-colored exterior mirror housings
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Dashboard illumination 7V0 Standard dashboard illumination
Door and side trim panels 3LT Door and side trim panel
Doors 0A2 4 doors
Doors/trays in trunk 3N0 Without stowage box in luggage boot
Drawers under front seats QN2 Drawer under right front seat
Emission standard 0GG Emission standard EU4
Engine specifications D3W 4-cyl. turbo diesel engine 1.9 L/77 kW TDI with pump-jet injection system Base engine is T71/TG0/TD0/T5X
Exhaust tailpipe 0P0 Rear exhaust tailpipe (standard)
Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
Floor mats 0TA Without floor mats
Front fog light/additional headlight 8WB Front fog lights
Front seat, left 3TB Standard seat, front left
Front seat, right 3SB Standard seat, front right
Front stabilizer 0AD Front stabilizer
Fuel filler cap/door, locking option 2W3 Fuel filler cap remote unlocking
Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
Fuel systems 0F8 Cooled fuel system for diesel engine
Fuel tank treatment 2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
General operating permit, alterations C00 Operating permit, initial registration
Generators 8GU Alternator 140 A
Glove compartment 4Z5 Glove compartment door with light
Headlight 8JM Twin headlight for driving on the right, with integrated high beam
Heat accumulator system/additional heater 7E6 Electric auxiliary air heater
Heating and air conditioning system 9AP Climatic air-conditioning system (semi-automatic)
Hill hold control UG0 Without hill hold control / hill descent control / comfort driving assist
Hood and trunk stay 5NA Hood stay
Identification lights, roof 9KA Without identification lights
Inserts 5MD Decorative aluminum inserts
Instrument inserts U5A Instrument insert, km/h speedometer
Interior light in driver compartment 9GG Two interior lights with door pillar switches
Interior light in foot area 6T0 Without interior light in footwell
Key for locking system 8QL Key for locking system with remote control
Left vanity mirror 4SB Vanity mirror left
Luggage compartment floor covering 6SA Without trunk floor covering
Luggage compartment lighting 9E3 Luggage compartment lighting
Mud flap 6N0 Without mud flaps
Nameplate set 1RX Nameplate set in base trim
Outdoor temperature gage 9Y1 Outdoor temperature gage
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
Owner's manuals 0VT Information kit in Polish
Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
Park distance control 7X1 Park distance control
Parking light indicator light 8NB Parking light indicator light
Pedal cluster VF0 Standard pedal cluster
Pedestrian protection VL0 Standard pedestrian protection measures
Platform group class 7PB Platform group class 2
Platform module floor pan, rear 4P3 Rear floor panel module, type 4
Radios 8AA Without radio
Reading light 8S5 Two reading lights front
Rear headrests 3Q6 Three rear headrests
Rear stabilizer 0BD Rear stabilizer
Refrigerator 1W2 Glove compartment cooling system
Right vanity mirror 4TB Vanity mirror right
Roof rails/roof load rack 3S4 Preparation for roof load rack
Safety certificate 0LA Without special plates/stickers/ safety certificates
Safety headrest system 3K0 Without safety headrest system
Seat belt check 9P1 Seat belt reminder, electric contact in buckle
Seat covering N2M Fabric seat covering
Shock absorption, chassis, front G02 Front shock absorption
Side lights 7R6 Side turn signal lights in exterior mirrors
Ski bag 3X0 Without load-through provision
Smoking/non-smoking package 9JD Smoking package, ashtray front
Special labels/plates 2KE Labels/plates in Czech and Slovakian
Steering 1N3 Speed-related variable steering assist (Servotronic)
Steering wheels 1MA Steering wheel
Tire pressure warning light 7K0 Without tire pressure warning light
Tires H7F Tires 195/65 R15 91H
Tool kit and jack 1S1 Tool kit and jack
Type approval countries/countries with special requirements B17 Type approval Poland
Vehicle class differentiation units/platform components 0HF Vehicle class differentiation 1Z0
Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
Wheel covers 1NN Full wheel covers
Wheels C8V Steel wheels 6J x 15
PDC
PH4
Tray areas package QE4 Tray areas package 2 Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ9NZ3Y197595
Model Designation polo
Date of production 27.01.2003
Model year 2003
Sales type 9N10D4
Engine code AZQ
Transmission code GKU
Axle drive 5S
Interior trim code AU
Roof color 7D
Exterior color / Paint Code 7D / B5N
Additional warning lights 9TA Without additional warning lights
Air cleaner (engine) 1L0 Standard air cleaner
Backrest release 3H3 Backrest release for front seat(s)
Body measures 5C6 Additional body measures
Body treatment 6J1 Special body treatment
Brackets 3P6 Bracket for first aid kit
Brake type, front 1LQ Front disc brakes with integrated adapter
Brake type, rear 1KB Drum brakes, rear
Braking systems 1AN Anti-lock brake system (ABS)
Bumper 2JF Painted bumpers
Cd enhancing underbody panel 2D0 Without cd enhancing underbody panel
Center high-mounted stop light 8R1 Center high-mounted stop light
Center sun visor GA0 Without center sun visor
Components with special surface appearance 6FA Components without special surface appearance
Cup holder 4M5 Cup holder
Dashboard 4N0 Standard dashboard
Dashboard illumination 7V2 Dashboard illumination, not dimmable
Door and side trim panels 3LA Door and side trim panel in woven fabric
Doors 0A1 2 doors
Engine cover NM1 Engine cover
Engine specifications MA5 3-cyl. gasoline engine 1.2 L/47 kW 12V base engine is T70
Exterior noise suppression measures 2B0 Without additional exterior noise suppression
Frame forestructure AC1 Long frame forestructure
Fresh air intake for passenger compartment (with particulate filter) 2V1 Dust and pollen filter
Front stabilizer 0AQ Front stabilizer
Fuel systems 1A1 Fuel sys. for carburetor gasoline eng. w/ injector system without fuel return
Fuel tank treatment 2LA Fuel tank without special material treatment
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
General operating permit, alterations C04 Operating permit, alteration
Glove compartment 4Z1 Standard glove compartment
Grab handles at roof frame 5N2 Folding grab handles at roof frame
Headlight 8BB Halogen headlight for driving on the right
Heated rear window 8P1 Heated rear window
Horns 8Y4 High-sounding horn
Inserts 5TC Without decorative inserts
Installation differentiation for vehicle components 0EM Installation differentiation for transmission MQ 200 vehicle components
Interior light in driver compartment 9GA Interior light with door pillar switches
Left vanity mirror 4SC Left vanity mirror with cover
Lock operation for tailgate/trunk lid 4E5 Tailgate/trunk lid unlocking from outside
Luggage compartment lighting 9E0 Without trunk lighting
Luggage compartment lining 5A6 Full fleece trunk lining
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Manufacturing sequence differentiation 0FB Pamplona manufacturing sequence
Molding roof liner 6NA Unsplit molding roof liner
Nameplate set 0NY Nameplate set "1.2"
Owner's manuals 0VB Information kit in French
Pillar lining 4XC Exterior pillar lining
Platform module floor pan, rear 4P2 Rear floor panel module, type 3
Radiator grille 6KA Radiator grille
Rear axle 0N2 Heavy-duty rear axle
Rear seats 3NC Rear seat bench/backrest, split folding
Restraint systems, front 4QV 3-point seat belts with electric tensioner and height adjustment, front
Right vanity mirror 4TC Right vanity mirror with cover
Seat covering N4C Fabric seat covering
Shock absorption, chassis, front G09 Front shock absorption
Shock absorption, chassis, rear 1JL Rear shock absorption
Special labels/plates 0SG Labels/plates in French
Steering 1N2 Power steering electro-hydraulic
Steering wheels 2PQ Steering wheel for air bag system
Taillight assemblies 8SG Standard taillight assemblies (type 2)
Tires H8P Tires 165/70 R14 81T
Trunk sill protection 2P1 Plastic trunk sill protection
Type approval countries/countries with special requirements B08 Type approval France
Vehicle class differentiation units/platform components 0CL Vehicle class differentiation 6Q0- for build status Europe
Weight category front axle L03 Suspension range 03 installation control only, no requirement forecast
Weight category rear axle 0YA Weight range 1 installation control only, no requirement forecast
Wheel covers 1NC Full wheel covers
Wheel housing liners KG2 Wheel housing liner front and rear
Wheels C0D Steel wheels 5J x 14
Window regulator 4R1 Power windows
Windshield wiper arms/blades 9PE Windshield wiper arms/blades with spoiler wiper blade
P08
PAS
PB1
PF0
PH1
PR1
Base engine T70 3-cylinder gasoline engine 1.2 L unit 03E.A (aluminum)
Drawers under front seats QN3 Drawers under front seats
Foot area lining QM0 Foot area lining without cover
Front seats Q1A Standard front seats
Tire suppliers V0A Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1HZRW426425
Model Designation golf cl
Date of production 17.02.1994
Model year 1994
Sales type 1H12H4
Engine code ABS
Transmission code CHB
Axle drive 5S
Interior trim code 17
Roof color 00
Exterior color / Paint Code 90 / 041
Air bag 4UA Without air bag
Antennas 8L1 Bright rod antenna
Anti-theft protection system 7AD Anti-theft alarm system and passenger compartment control
Ashtray light 8PB Ashtray light
Batteries J1P Battery 220 A (44 Ah)
Brake type, front 1LM Disc brakes, front
Braking systems 1AB Power brake
Cassette and CD storage unit 4W1 Cassette storage unit
Catalytic converter control 8KA W/o catalytic converter warning light
Center high-mounted stop light 8R0 Without center high-mounted stop light
Clutch actuation 1K1 Mechanical clutch actuation
Door and side pockets, rear 4YA Without stowage box rear (door and side panel)
Door pockets, front 3YH Door pockets, front
Doors 0A1 2 doors
Engine specifications M5G 4-cylinder gasoline engine 1.8 L/66 kW Monomotronic, catalytic converter base engine is T5C
Flame retardent materials 4Q0 No flame retardent materials
Floor coverings 3MQ Ibolours floor covering
Front passenger seat adjustment from the rear 4V0 Without front passenger seat adjustment from the rear
Front spoiler 5L1 Front spoiler
Front stabilizer 0AB Front stabilizer
Front turn signal lights 6Z1 Yellow turn signal lights
Fuel tank vent line 1TB Fuel tank vent line with gravity valve and PVC breather hose
Gearshift boot/cover 6R3 Rubber gearshift boot
Generators 8GM Alternator 70 A
Glove compartment 4Z3 Lockable glove compartment door, with light
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AA Manually controlled heating system
Identification plates 1EC Special identification plate
Insert for the filling up of unleaded fuel/fuel type 2G1 Insert for the filling up of unleaded fuel
Interference suppression 8E2 Local interference suppression for FM/AM radio reception
Interior noise suppression measures 3W0 Without additional noise suppression measures for passenger compartment
Label for brake-proportioning values 0Q0 Without label for brake-proportioning values
Lashing rings/rails for load restraint 6B0 Without lashing rings for load restraint
Left exterior mirror 3BR Left exterior mirror: non-speherical, adjustable from inside
Left vanity mirror 4SA Without left vanity mirror
Luggage compartment lining 5A2 Comfort trunk lining
Night vision system 9R0 Without night vision system
Park distance control 8A0 Park distance control, front and rear with rear view camera
Proportioning valve 1H1 Load-sensitive proportioning valve
Reading light 8S1 Reading light front
Rear headrests 3Q0 Without rear headrests
Rear spoiler 5J0 Without rear spoiler
Rear stabilizer 0BA Without rear stabilizer
Restraint systems, front 3QC 3-point seat belts, front
Right exterior mirror 3AD Right exterior mirror: convex, adjustable from inside
Roof insert/convertible top 3FE Electric slide/tilt sunroof with sun screen/sunblind
Seat adjustment 3L1 Manual height adjustment for left front seat
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Side assist/lane departure warning 7Y0 Without lane change assistant
Spare wheel/breakdown set 1G6 Space-saving spare wheel
Special editions E7N "Freestyle"
Steering column systems 2C1 Height adjustable steering column
Steering wheels 1ME Steering wheel
Tires H0G Tires 185/60 R14 H
Transmission types/gearshift mechanisms 0G3 Gearshift linkage
Vehicle class differentiation units/platform components 0DG Installation differentiation for build status of vehicle class A3 (VW Golf/ Vento/Variant), unit components
Vehicle class differentiation units/platform components 0MA Vehicle class differentiation -4V0-
Wheel covers 1NG Center wheel trim
Wheels C5Y Alloy wheels
Window regulator 4R0 Mechanical window regulator
Windshield wiper intermittent control 8N2 Windshield wiper intermittent control infinitely variable
PD3
RBL
Base engine T5C 4-cylinder gasoline engine 1.8 L unit 051.2
Control number (no PR-Family) S6G Region
W3R Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Witam. Prosiłbym o sprawdzenie VIN: WAUZZZ8LZWA070950
Pozdraiwam.
Pozdraiwam.
Witam mam do sprawdzenia dwa Tourany, mogę prosić o pomoc, przede wszystkim zależy mi żeby potwierdzić przebieg
WVGZZZ1TZBW055955 - prezebieg około 30000
WVGZZZ1TZAW106976 - przebieg około 60000
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 58 gości
