Nie daj się oszukać, sprawdź VIN i historię
Moderatorzy: palio, jhosef, VIP
Nie daj się oszukać, sprawdź VIN!
a odnosnie servisowania coś sie dowiemy i przebiegu?? sorry ale jestem zielony z tego
Kolego VIN prosba. Dalo by rade odkodowac numer:
WVWZZZ1JZ1D173170
Dzieki i pozdrawiam
WVWZZZ1JZ1D173170
Dzieki i pozdrawiam
"Twoj samochód jest wystarczająco szybki wtedy, gdy stojąc rankiem przed nim boisz się go otworzyć" - Walter Röhl
Re: Nie daj się oszukać, sprawdź VIN!
olsen72 pisze:Witam
WVWZZZ1JZ1D173170
Dzieki i pozdrawiam
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ1D173170
Model Designation golf v6 4motion
Model GOLF
Date of production 29.07.2000
Model year 2001
Sales type 1J13W7
Engine code AUE
Transmission code DRP
Axle drive 6S
Interior trim code VV
Roof color 1D
Exterior color / Paint Code 1D / W5Z
Activated carbon canister 1E1 Activated carbon canister
Additional body covers, side 6EJ Additional body cover on sill without wheel arch
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2WA Without additional tires
Additional tunnel cover 4J1 Floor tray, extension center console
Additional warning lights 9TB Additional warning lights (door area)
Air bag 4UE Air bag for driver and front seat passenger
Antennas 8L3 Roof antenna
Anti-theft protection system 7AH Electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H8 Backrest release for front seats with "Easy Entry" and memory function
Batteries J1L Battery 280 A (60 Ah)
Body measures 5C3 Body measures for increased safety requirements
Body style K8G Hatchback
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1LJ Disc brakes, front
Brake type, rear 2EE Disc brakes, rear
Braking systems 1AT Electronic stabilization program (ESP)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JC Comfort bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A2 CD changer
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E3 Front center armrest
Center rear seat belts 3C7 3-point seat belt for center rear seat
Component part sets with country-specific design requirements B0N Component parts set, complying with vehicle type for Great Britain, various parts
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Controls (steering wheels/steering column) 4LA Without controls
Cruise control 8T2 Cruise control system (CCS) electronic
Cup holder 4M6 Cup holder
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
Door pockets, front 3YR Door pockets with insert mats
Doors 0A1 2 doors
Drive layout 1X1 Four wheel drive
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GG Emission standard EU4
Engine compartment lighting 9L0 Without engine compartment lighting
Engine cooling system 8Z5 Not hot country
Engine guard 1SA Without additional engine guard
Engine specifications D6B 6-cyl. gasoline eng. 2.8 L/150 kW 24V VR6 base engine is T9T
Equipment levels A8F Sports equipment
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B8 Additional exterior noise suppression
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Floor coverings 3MF Dilours floor covering with scuff guard
Floor mats 0TD Front and rear floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 8WD Integrated front fog light
Front license plate bracket 6W1 License plate bracket front (large)
Front stabilizer 0AS Front stabilizer
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F2 Fuel system for carburetor gasoline engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q3 Wooden gearshift knob/handle
General operating permit, alterations C16 Operating permit, alteration
Generators 8GL Alternator 120 A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8JU Twin headlight for driving on the left with clear lens
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X1 Headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E2 Heated crankcase ventilation system
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Inserts 5MG Decorative inserts, burr-walnut
Installation differentiation for vehicle components 0EN Installation differentiation for transmission MQ 350 vehicle components
Left exterior mirror 5SJ Left exterior mirror: convex
Left vanity mirror 4SD Left vanity mirror, illuminated
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment floor covering 6SM Needle-punched trunk floor covering (Dilours)
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Lumbar support 7P4 Manually adjustable lumbar support in front seats
Manufacturing sequence differentiation 0FK Bratislava manufacturing sequence
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 0PV Nameplate set "V6 4MOTION"
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
Park distance control 7X0 Without park distance control
Partition 3CA Without partition
Platform group class 7PA Platform group class 1
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Protective side molding 4B2 Body-colored protective side molding
Radiator grille 6KG Radiator grille
Radios 8AD Radio "gamma"
Reading light 8S2 One reading light front, two reading lights rear
Rear axle 0N1 Standard rear axle
Rear cargo area 3GA Without cargo area
Rear fog light 8TD Rear fog light for driving on the left
Rear headrests 3T3 3 rear headrests height-adjustable
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seat catch 6QA Rear seat catch
Rear seats 3NC Rear seat bench/backrest, split folding
Rear stabilizer 0BT Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 5RV Right exterior mirror: aspherical
Right vanity mirror 4TD Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof insert/convertible top 3FA Without roof insert (standard roof)
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Rough-road/sports version 2UA Standard design
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P0 Without seat belt reminder
Seat covering N2F Part leather seat coverings casual fold
Seat heater 4A3 Seat heater for front seats separately controlled
Shock absorption, chassis, front G88 Front sports shock absorption
Shock absorption, chassis, rear 1JU Rear shock absorption, basic design four wheel drive
Side air bag 4X1 Side air bag front
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Side lights 7R3 Side turn signal lights (white)
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B2 12-volt socket in luggage boot
Spare wheel/breakdown set 1G9 Space-saving spare wheel for temporary use, radial tire (5-hole)
Speaker installation 8RM 8 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special color trim 0UA Without special color trim
Special editions E0A No special edition
Special labels/plates 0SC Labels/plates in English
Special registration measures 3M0 Without special measures
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering QZ2 Power steering for special demands (additional damping valves)
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering system arrangement L0R Right-hand drive vehicle
Steering wheels 2PX Leather trimmed sports steering wheel
Sticker (customized or special edition) 0KA Without stickers and badges
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Telephone/telematics 9W0 W/o car phone preparation/installation
Throttle actuation 0L2 Electric throttle actuation
Tires H6U Tires 205/55 R16 91W
Tool kit and jack 1S7 Tool kit and aluminum jack
Trailer hitch 1D0 Without trailer hitch
Transmission specifications G0L 6-speed manual transmission for four-wheel drive vehicle
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Tray 7N0 Without tray on roof liner
Trunk sill protection 2P0 Without trunk sill protection
Type approval countries/countries with special requirements B09 Type approval Great Britain and Northern Ireland
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L08 Suspension range 08 installation control only, no requirement forecast
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheel covers 1NL Covers for alloy wheels
Wheels CF5 Alloy wheels 6.5J x 16
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GF Windshield in heat-insulating glass
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
P00
PH6
Child seats QA0 Without child seat
Chrome work package QJ0 Without aluminum/chrome work package
Front seats Q2Q RECARO sports seats, front
Nameplates for sales name QD1 Nameplates for sales name
Service interval prolongation QG1 Service interval prolongation
RCA
Base engine T9T 6-cylinder gasoline engine 2.8 L unit 022.A
Instrument inserts U0L Instrument insert with tachometer clock and mph speedometer
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Tire suppliers V0G MICHELIN tires Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Sieniek0916
Mam prośbę o dane o numerze VIN:
WVGZZZ1TZ4W082890
z góry dziekuję
WVGZZZ1TZ4W082890
z góry dziekuję
Sieniek0916 pisze:Witam
WVGZZZ1TZ4W082890
z góry dziekuję
Kod: Zaznacz cały
Vehicle Identification No. WVGZZZ1TZ4W082890
Model Designation touran 2.0
Model TOU
Date of production 26.11.2003
Model year 2004
Sales type 1T1T31
Engine code AZV
Transmission code GNE
Axle drive 6S
Interior trim code FC
Roof color 8E
Exterior color / Paint Code 8E / A7W
Activated carbon canister 1E0 Without activated charcoal canister
Additional body covers, side 6EA Without additional side body covers (stone guard)
Air bag 4UF Driver's and front passenger air bag with front passenger air bag deactivation
Air duct, front area VK0 Air duct, standard
Antennas 8ZH Antenna for AM/FM reception, "diversity"
Anti-theft protection system 7AA Electronic vehicle immobilization device
Auxiliary heating 9M5 Auxiliary heater
Backrest release 3H0 Without backrest release for front seats
Base engine T9G 4-cylinder diesel engine 2.0 L unit 03G.A
Batteries J0L Battery 340 A (70 Ah)
Body style K8P MPV
Brake type, front 1ZE Disc brakes, front (Geomet D)
Brake type, rear 1KF Disc brakes, rear
CD changer/CD player 7A0 Without CD changer/CD player
Center armrest 6E0 Without center armrest front
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Drawers under front seats QN3 Drawers under front seats
Drive layout 1X0 Front wheel drive
Engine specifications MS9 4-cyl. turbo diesel engine 2.0 L/100 kW 16V (TDI) with pump-jet injection system Base engine is T9G/TB3/TQ0/TN0
Equipment levels A8G Sports comfort equipment
Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
First aid kit / warning triangle 1T2 Warning triangle
Floor mats 0TA Without floor mats
Front seat, left 3TF Comfort seat, front left
Front seat, right 3SF Comfort seat, front right
Front stabilizer 0AF Front stabilizer
Fuel systems 0F9 Cooled fuel system for diesel engine
Gearshift boot/cover 6R1 Leatherette gearshift boot
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
General operating permit, alterations C03 Operating permit, alteration
Generators 8GU Alternator 140 A
Glove compartment 4Z1 Standard glove compartment
Hand brake lever handle 6PA Plastic hand brake lever handle
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Headlight washer system 8X0 Without headlight washer system
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Heated washer nozzles 9T0 Without heated washer nozzles
Hinged quarter window 4MA Without rear hinged quarter window
Horns 8Y0 Single-tone horn
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Inserts 5MA Decorative inserts
Instrument inserts U5A Instrument insert, km/h speedometer
Interference suppression 8E2 Local interference suppression for FM/AM radio reception
Left exterior mirror 5SL Left exterior mirror: aspherical
Lock operation for tailgate/trunk lid 4E2 Tailgate/trunk lid release from inside (electrically)
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U7 Luggage compartment cover
Nameplate set 0NB Nameplate set in base trim
Outdoor temperature gage 9Y1 Outdoor temperature gage
Outer rear seat belts 3ZG 3-point seat belts, outer rear with height adjustment
Owner's manuals 0VB Information kit in French
Paint preservative/transit coating 5K5 Transit coating film with additional transport protection measures
Pane type (except windshield) QL3 Heat-insulating glass (green)
Radiator grille 6KJ Radiator grille with chrome-plated strip
Radios 8YL Radio with CD player
Rear axle 0N4 4-link rear suspension
Rear fog light 8TC Rear fog light for driving on the right
Rear seats 5KP 3 separate seats (first row of seats)
Refrigerator 1W8 Without refrigerator
Right exterior mirror 5RQ Right exterior mirror: convex
Roof rails/roof load rack 3S2 Black roof rails
Safety headrest system 3K1 Safety headrest system
Seat belt check 9P1 Seat belt reminder, electric contact in buckle
Seat covering N0Y Seat coverings in flat woven fabric
Seat heater 4A0 Without seat heater
Shock absorption, chassis, front G26 Front shock absorption
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side air bag 4X3 Side air bag front with curtain air bag
Spare wheel/breakdown set 1G8 Breakdown set
Speaker installation 8RE 4 speakers (passive)
Special labels/plates 0SA Without special labels/plates
Steering 1N3 Speed-related variable steering assist (Servotronic)
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2PQ Steering wheel for air bag system
Taillight assemblies 8SA Taillight assemblies, standard design
Tire pressure warning light 7K0 Without tire pressure warning light
Tire suppliers V0A Tires w/o specification of tire brand
Tires HH7 Tires 205/55 R16 91V
Transmission specifications G0K 6-speed manual transmission
Type approval countries/countries with special requirements BA1 Country group Central Europe F, B, NL, L, CH, A
Vehicle class differentiation units/platform components 1CZ Vehicle class differentiation 1T0
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category front axle L24 Suspension range 24 installation control only, no requirement forecast
Weight category rear axle 0YA Weight range 1 installation control only, no requirement forecast
Wheel covers 1NV Full wheel covers
Wheels CM1 Steel wheels 6.5J x 16
Windshield glass type 4GQ Windshield in heat-insulating glass
Windshield wiper arms/blades 9PA Standard windshield wiper arms/blades
PH2
Child seats QA0 Without child seat Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Witam serdecznie.
Czy moge prosic o sprawdzenie tego VIN
WVWZZZ1JZ3W183142
z gory dziekuje
WVWZZZ1JZ3W183142
z gory dziekuje
olivier85 pisze:Witam serdecznie.
WVWZZZ1JZ3W183142
z gory dziekuje
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ3W183142
Model Designation golf tdi
Model GOLF
Date of production 16.08.2002
Model year 2003
Sales type 1J1086
Engine code ASZ
Transmission code ERF
Axle drive 6S
Interior trim code AM
Roof color Z4
Exterior color / Paint Code Z4 / C9Z
Base engine T9J 4-cylinder diesel engine 1.9 L unit 038.K
Body measures 5C0 Without special body measures
Brake type, rear 1KS Disc brakes, rear (Geomet D)
Braking systems 1AJ Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
Bumper 2JB Standard bumpers
Carrier frequency for radio remote control 5D0 Without carrier frequency
Center rear seat belts 3C1 Static lap belt, center rear
Components with special surface appearance 6FE Body-colored exterior mirror housings and tailgate handle
Cruise control 8T0 Without cruise control system (CCS)
Cup holder 4M5 Cup holder
Door and lid locking system 4F1 Central locking system
Door pockets, front 3YQ Door pockets without insert mats
Doors 0A2 4 doors
Emission standard 0GE Emission standard EU3
Engine specifications D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Equipment levels A8C Comfort equipment
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Front stabilizer 0AE Front stabilizer
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
General operating permit, alterations C25 Operating permit, alteration
Headlight 8JS Twin headlight for driving on the right with clear lens
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Identification plates 1FF Special identification plate (Poland)
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lining 5A2 Comfort trunk lining
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Nameplate set 1DG Nameplate set "TDI"
Owner's manuals 0VT Information kit in Polish
Protective side molding 4B1 Protective side molding
Radios 8AA Without radio
Reading light 8S8 2 reading lights
Rear axle 0N5 Standard rear axle
Rear headrests 3Q1 Rear headrests
Rear stabilizer 0BB Rear stabilizer
Seat adjustment 3L1 Manual height adjustment for left front seat
Seat covering N4C Fabric seat covering
Service interval prolongation QG2 No possibility of activating service interval prolongation
Shock absorption, chassis, front G38 Front shock absorption
Shock absorption, chassis, rear UB8 Rear shock absorption
Side air bag 4X0 Without side air bag
Socket 7B0 Without socket
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Special labels/plates 0SB Labels/plates in German
Steering 1N1 Power steering
Steering wheels 1MP Steering wheel for air bag system
Tires H6S Tires 195/65 R15 V
Type approval countries/countries with special requirements B17 Type approval Poland
Weight category front axle L06 Suspension range 06 installation control only, no requirement forecast
Wheel covers 1ND Full wheel covers
Wheels C6E Steel wheels 6J x 15 Offset 38
Windshield glass type 4GC Windshield in heat-insulating glass with sunshield
P04
PH4
PR8
Front seats Q1A Standard front seats Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Witam. prosze o pomoc
WVWZZZ19ZHW376732
WVWZZZ19ZHW376732
vw jetta mk1 coupe EX
vw golf mk2 1.8 automat :) +lpg
Niestety za stare auto, nie ma w bazie.lunatic pisze:Witam. prosze o pomoc
WVWZZZ19ZHW376732
Moge prosic o sprawdzenie jeszcze tego nr vin
WVWZZZ3BZ3P193308
z gory dzieki.
WVWZZZ3BZ3P193308
z gory dzieki.
olivier85 pisze:Moge prosic o sprawdzenie jeszcze tego nr vin
WVWZZZ3BZ3P193308
z gory dzieki.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ3BZ3P193308
Model Designation passat saloon
Model PA
Date of production 29.08.2002
Model year 2003
Sales type 3B3161
Engine code AWX
Transmission code FHN
Axle drive 5S
Interior trim code GC
Roof color Z4
Additional body covers, side 6EP Additional stone guard body covers
Additional child seat anchors 3B4 Child seat anchor for child seat system ISOFIX
Batteries J0R Battery 380 A (80 Ah)
Body style K8B Notchback
Brake type, front 1ZC Disc brakes, front (Geomet D)
Brake type, rear 1KD Disc brakes, rear
CD changer/CD player 7A8 CD changer (front)
Catalytic converter control 8KA W/o catalytic converter warning light
Center rear seat belts 3C3 Lap belt with retractor for the center rear seat
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Door and side trim panels 3LD Door and side trim panel
Double-size standard radio/dual-view display 2T1 Double-sized standard (DIN)
Duty-free tires 1V0 Without duty-free and cost-free tires
Flame retardent materials 4Q0 No flame retardent materials
Floor coverings 3MQ Ibolours floor covering
General operating permit, alterations C06 Operating permit, alteration
Heat accumulator system/additional heater 7E6 Electric auxiliary air heater
Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
Installation parts for engine (engine mount system) 1VG Installation parts for four-cylinder engine
Luggage compartment floor covering 6SD Tufted trunk floor covering (dimensionally stable)
Malfunction display 9HA Without additional malfunction display
Manufacturing sequence differentiation 0FG Mosel manufacturing sequence
Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
Moldings 4ZB Bright moldings
Paint coating FB3 Surface, interior trim, soft-touch paint
Parking light indicator light 8NA Without parking light warning light
Radios 8AR Radio "gamma" with removable operating panel
Reading light 8S4 Two reading lights front, two rear
Rear cargo area 3GK Without additional lower part for luggage compartment floor
Rear seats 3NZ Rear seat bench unsplit, backrest split folding
Safety certificate 0LA Without special plates/stickers/ safety certificates
Seat covering N0U Cut pile seat covering
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Side lights 8F2 Side turn signal lights
Ski bag 3X0 Without load-through provision
Smoking/non-smoking package 9JA Non-smoking package
Socket 7B3 12-volt socket(s)
Transmission shafts 1WD Transmission shaft for tripod joints
Transmission shafts, rear axle 1YA Without transmission shafts f. rear axle
Transmission specifications G0C 5-speed manual transmission
Transmission types/gearshift mechanisms 0G1 Gearshift lever
Vehicle class differentiation units/platform components 0DE Installation differentiation for build status of vehicle class B5 (VW Passat)
Weight category front axle 0JH Weight category front axle weight range 8
Weight category rear axle 0YD Weight range 4 installation control only, no requirement forecast
Wheel covers 1NC Full wheel covers
Wheels C5E Alloy wheels 8.5J x 19
Window regulator 4R3 Power windows with comfort operation
Windshield glass type 4GH Windshield in heat-insulating glass with sunshield
PCW
PH2
Front seats Q2J Comfort front seats
RCH
Hands-free system VX0 Without hands-free system
Tire suppliers V0A Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Re: PROŚBA O SPRAWDZENIE NUMERU VIN
kameln pisze:Witam, prosze o sprawdzenie numeru VIN WVWZZZ1KZAW144415
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1KZAW144415
Model Designation golf 2.0 blue motion
Model GOLF
Date of production 23.09.2009
Model year 2010
Sales type 5K134N
Engine code CBDC
Transmission code LLL
Axle drive 5S
Interior trim code FW
Roof color A1
Exterior color / Paint Code A1 / 041
"Charism" 2H0 Without "drive select"
"Multimedia", video/DVD/notebook connection 9WL Multimedia socket for external audio source
Additional warning lights 9TC Additional reflectors (door area)
Air bag 4UP Driver's and front passenger air bag with knee air bag and front passenger air bag deactivation
Batteries J0N Battery 330 A (61 Ah)
Battery/alternator capacity NY0 Standard battery/alternator capacity
Brake type, front 1ZF Disc brakes, front (Geomet D)
Braking systems 1AC Anti-lock brake system (ABS)
Breakaway interior mirror 4L6 Breakaway interior rear view mirror, automatically dimming
Climatic zones 0Y1 Standard climatic zones
Customized installation FC0 Without customized installation
Delivery equipment 2A0 Without delivery equipment
Doors 0A2 4 doors
Emission standard 7MG Emission standard EU5
Engine specifications D96 4-cyl. turbo dies. eng. 2.0 l/81 kW (4V) TDI common rail Base engine is TG3/TP4/TU3/TL4
Exhaust tailpipe 0P1 Rear side exhaust tailpipe
Fuel systems 0F3 Fuel system for diesel engine
Fuel tank treatment 2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C32 Operating permit, alteration
Headlight activation 8K3 Separate daytime running lights with low beam assistant and "Coming Home" feature
Headlight-range adjustment 8Q4 Headlamp range adjustment with fixed bending light
Headrests 3J1 Height-adjustable headrests for front seats
Inserts 5MB Decorative inserts
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Interior light in foot area 6T1 Interior light in footwell
Lockable wheel bolts 1PE Wheel bolts with anti-theft protection (unlockable)
Multi-function display/trip computer 9Q5 Multi-function display with control
Operating voltage 9Z0 Operating voltage 12V
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
Paint preservative/transit coating 5K7 Transport protection film (minimum protection) with additional transport protection measures
Radiator grille 6KC Radiator grille
Radios 8AE Radio "RCD310 MP3"
Rear headrests 3T2 Three rear headrests
Rear seats 3NU Rear seat bench unsplit, backrest split folding with center armrest
Rear spoiler 5J0 Without rear spoiler
Rear stabilizer 0BE Rear stabilizer
Refrigerator 1W2 Glove compartment cooling system
Rough-road/sports version 2UC Sports version
Safety headrest system 3K0 Without safety headrest system
Scuff plates 7M5 Without protective film for scuff plate
Seat belt check 9P3 Seat belt reminder, electric contact in buckle
Seat covering N3B Fabric seat covering
Shock absorption, chassis, front G02 Front shock absorption
Shock absorption, chassis, rear 1JC Rear shock absorption for sports design
Side and rear windows 4KF Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
Spare wheel/breakdown set 1G6 Space-saving spare wheel
Special labels/plates 0SS Labels/plates in English and French
Start/stop system/regenerative braking 7L3 Without start/stop system without regenerative braking
Steering wheels 2PP Leather multi-function steering wheel
Tires H0R Tires 205/55 R16 91H optimized rolling resistance
Tool kit and jack 1S1 Tool kit and jack
Transmission specifications G0J 5-speed manual transmission different spread of gear ratio
Type approval countries/countries with special requirements B08 Type approval France
Upgrading measures GP1 Vehicles with special upgrade measures
Vehicle class differentiation units/platform components 0HA Vehicle class differentiation 1K0/5K0
Weight category front axle L55 Suspension range 55 installation control only, no requirement forecast
Weight category rear axle 0YB Weight range 2 installation control only, no requirement forecast
Wheels CM5 Alloy wheels 6.5J x 16
Windshield wiper intermittent control 8N3 Windshield wiper intermittent control with rain sensor
PH2
PLA
PU2
Base engine TU3 4-cylinder diesel engine 2.0 l Unit 03L.H
Chrome work package QJ1 Chrome work package
Compass/traffic sign display QR0 Without compass/traffic sign display/ traffic signs recognition
Drawers under front seats QN0 Without drawers under front seats
Electric interface for external use UF0 Without electric interface
Hill hold control UG0 Without hill hold control / hill descent control / comfort driving assist
Marten repeller UM0 Without marten repeller
Pedal cluster VF0 Standard pedal cluster
Pedestrian protection VL1 Extended pedestrian protection measures
RGC
Control number (no PR-Family) S5K Control (in-plant)
MARIUSZW180
Proszę o sprawdzenie historii auta nr vin WV1ZZZ2DZ6H036918
Z góry dziękuje
Z góry dziękuje
