Nie daj się oszukać, sprawdź VIN i historię
Chcesz kupić, bądź sprowadzić auto..nie wiesz, które wybrać? Napisz o tym tutaj...
Moderatorzy: palio, jhosef, VIP
flexovit
Re: Nie daj się oszukać, sprawdź VIN i historię
Post autor: flexovit » sob lis 10, 2012 00:16
czy ktoś życzliwy pomoże mi rozkodować VIN? Mam golfa z poczatka serii... zastanawiam się ile elementów pominięto na pierwszym montażu... :)
Z góry dziękuje
WVWZZZ1JZWW042895
VIN
Post autor: VIN » sob lis 10, 2012 12:06
Kod: Zaznacz cały
Vehicle Identification No.	WAUZZZ8L921020080
Model Designation	audi a3 1.9 tdi
Date of production	22.04.2002
Model year	2002
Sales type	8L1BGC
Engine code	ASZ
Transmission code	DRW
Axle drive	6S
Interior trim code	EG
Roof color	Q5
Exterior color / Paint Code	Q5 / Z5L
Activated carbon canister 	1E0 	Without activated charcoal canister
Additional child seat anchors 	3B4 	Child seat anchor for child seat system ISOFIX
Additional dust seals 	6U0 	Without additional seals outside
Additional tires (winter tires) 	2WA 	Without additional tires
Air bag 	4UE 	Air bag for driver and front seat passenger
Anti-theft protection system 	7AA 	Electronic vehicle immobilization device
Antifreeze 	1C1 	Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Auxiliary heating 	9M0 	Without auxiliary/parking heater
Backrest release 	3H6 	Backrest release for front seats with "Easy Entry" and add. backrest release on the inner side of right front seat
Base engine 	T9J 	4-cylinder diesel engine 1.9 L unit 038.K
Batteries 	J0L 	Battery 340 A (70 Ah)
Body measures 	5C0 	Without special body measures
Body style 	K8G 	Hatchback
Brake pad wear indicator 	9U1 	Brake pad wear indicator
Brake type, front 	1LE 	Disc brakes, front
Brake type, rear 	1KK 	Disc brakes, rear
Braking systems 	1AT 	Electronic stabilization program (ESP)
Breakaway interior mirror 	4L2 	Dipping breakaway interior rear view mirror
Bumper 	2JB 	Standard bumpers
CD ROM/DVD/SD card 	7QA 	Without CD/DVD for navigation
CD changer/CD player 	7A0 	Without CD changer/CD player
Carrier frequency for radio remote control 	5D1 	Carrier frequency 433.92 MHz-434.42 Mhz
Cd enhancing underbody panel 	2D1 	Complete cd enhancing underbody panel
Center armrest 	6E0 	Without center armrest front
Center rear seat belts 	3C1 	Static lap belt, center rear
Component part sets with country-specific design requirements 	B0A 	Component parts set without country-specific design requirement
Components with special surface appearance 	6FB 	Body-colored exterior mirror housings
Cruise control 	8T0 	Without cruise control system (CCS)
Customized installation 	FC0 	Without customized installation
Door and lid locking system 	4K4 	Radio remote controlled central locking
Doors 	0A1 	2 doors
Drive layout 	1X0 	Front wheel drive
Electronic map cooling system 	QS0 	Without electronic map cooling system
Emission standard 	0GE 	Emission standard EU3
Engine cooling system 	8Z5 	Not hot country
Engine specifications 	D3E 	4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Equipment levels 	A9D 	"Ambition" equipment
Exterior mirror setting 	6XC 	Exterior mirrors: electrically adjustable
Exterior noise suppression measures 	2B3 	Additional exterior noise suppression (hood, capsule and dash panel)
Fire extinguisher 	6A0 	Without fire extinguisher
First aid kit / warning triangle 	1T3 	First aid kit with warning triangle
Fresh air intake for passenger compartment (with particulate filter) 	2V5 	Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 	8WB 	Front fog lights
Front license plate carrier 	6W5 	Front license plate carrier
Front stabilizer 	0AL 	Front stabilizer
Front underbody guard 	1SA 	Without additional front underbody guard
Fuel filler cap/door, locking option 	2W0 	Fuel filler cap
Fuel quantity for initial filling 	1Z0 	Initial standard fuel filling
Fuel systems 	0F9 	Cooled fuel system for diesel engine
Fuel tank treatment 	2LB 	Fuel tank with special material treatment
Gearshift boot/cover 	6R2 	Leather gearshift boot
Gearshift knob/handle 	6Q2 	Leather gearshift knob/handle
General operating permit, alterations 	C18 	Operating permit, alteration
Generators 	8GL 	Alternator 120 A
Hand brake lever handle 	6PA 	Plastic hand brake lever handle
Handling standard production and pre-production series 	FD0 	Standard-production control (deviating in-plant control)
Headlight 	8JH 	Ellipsoidal headlight for driving on the right
Headlight activation 	8K0 	Without special headlight activation
Headlight washer system 	8X0 	Without headlight washer system
Headlight-range adjustment 	8Q1 	Headlight-range adjustment
Heat accumulator system/additional heater 	7E3 	Sheathed type glow plug heater
Heated door lock cylinder 	9X4 	Without heated door lock cylinder with micro switch
Heated washer nozzles 	9T1 	Heated washer nozzles, front
Heating and air conditioning system 	9AK 	Climatronic with impact pressure control free of cfc
Horns 	8Y1 	Two-tone horn
Identification plates 	1EX 	Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 	0RA 	Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 	2G8 	Filler neck module 2 without insert
Inserts 	5TC 	Without decorative inserts
Installation differentiation for vehicle components 	0EN 	Installation differentiation for transmission MQ 350 vehicle components
Instrument inserts 	U2A 	Instrument insert with km/h speedometer, radio-controlled clock, tachometer and trip odometer
Label for central electric 	0W1 	Label for central electric German-speaking countries
Left exterior mirror 	5SL 	Left exterior mirror: aspherical
Lock operation for tailgate/trunk lid 	4E0 	Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 	1PC 	Wheel bolts with anti-theft protection (unlockable)
Lumbar support 	7P0 	Without lumbar support in seat backrests
Manufacturing sequence differentiation 	0FA 	Standard manufacturing sequence
Mud flap 	6N0 	Without mud flaps
Multi-function display/trip computer 	9Q2 	Multi-function display/on-board computer with check control
Navigation device 	7Q0 	Without navigation device
Outdoor temperature gage 	9Y1 	Outdoor temperature gage
Owner's manuals 	0VC 	Information kit in German
Paint preservative/transit coating 	5K3 	Liquid film sealant
Park distance control 	7X0 	Without park distance control
Platform group class 	7PE 	Platform group class 5
Platform module floor pan, rear 	4P0 	Rear floor panel module, type 1
Preparation for two-way radio installation 	9D0 	Without preparation for two-way radio installation
Proportioning valve 	1H0 	Without proportioning valve
Quattro GmbH 	FQ0 	Standard production wheels
Radios 	8UC 	Radio "chorus"
Rear axle 	0N1 	Standard rear axle
Rear fog light 	8TC 	Rear fog light for driving on the right
Rear headrests 	3Q1 	Rear headrests
Rear seats 	3NC 	Rear seat bench/backrest, split folding
Rear spoiler 	5J0 	Without rear spoiler
Rear stabilizer 	0BB 	Rear stabilizer
Rear trim panel 	6V1 	Rear trim panel (ECE)
Rear window wiper and washer system 	8M1 	Rear window wiper and washer system with intermittent control
Right exterior mirror 	5RU 	Right exterior mirror: convex (large viewing field)
Roof insert/convertible top 	3FA 	Without roof insert (standard roof)
Rough-road/sports version 	2UA 	Standard design
Safety certificate 	0LW 	Special plates/stickers/ safety certificates for Germany
Scuff plates 	7M0 	Plastic scuff plates in door apertures
Seat adjustment 	3L3 	Manual height adjustment for front seats
Seat belt check 	9P0 	Without seat belt reminder
Seat covering 	N0E 	Woven fabric seat covering
Seat heater 	4A0 	Without seat heater
Self-collection / special control 	A00 	No self-collection
Shock absorption, chassis, front 	G66 	Front shock absorption
Shock absorption, chassis, rear 	1JK 	Rear shock absorption, sports design
Side air bag 	4X1 	Side air bag front
Side lights 	7R3 	Side turn signal lights (white)
Sill top/sill cover 	5E1 	Without sill top with door cover
Spare wheel/breakdown set 	1G3 	Alloy spare wheel with original equipment tires
Speaker installation 	9VD 	Speaker (active)
Special editions 	E0A 	No special edition
Special labels/plates 	0ST 	Labels/plates in German and French
Steering 	1N6 	Power steering
Steering column systems 	2C5 	Axial and vertical adjustable steering column
Steering system arrangement 	L0L 	Left-hand drive vehicle
Steering wheels 	2PV 	Leather trimmed sports steering wheel
TV reception/digital radio reception 	QV0 	W/o TV reception/digital radio reception
Tachograph/logbook 	9NX 	Without electronic logbook
Telephone/telematics 	9W0 	W/o car phone preparation/installation
Throttle actuation 	0L2 	Electric throttle actuation
Tie down straps/net/pocket 	6M0 	Without tie down straps/net/pocket
Tire suppliers 	V0A 	Tires w/o specification of tire brand
Tires 	H6S 	Tires 195/65 R15 V
Trailer hitch 	1D0 	Without trailer hitch
Transit coating 	NT0 	Transit coating (type 1)
Transmission specifications 	G0K 	6-speed manual transmission
Transmission types/gearshift mechanisms 	0G4 	Cable gearshift
Type approval countries/countries with special requirements 	B01 	Type approval Germany
Type sign 	2Z1 	Type sign at rear and "Quattro" nameplates respectively
Vehicle class differentiation units/platform components 	0CJ 	Vehicle class differentiation 8L0
Vehicle specifications 	F0A 	No special purpose vehicle, standard equipment
Vehicle type 	AZ0 	Vehicle with standard production scope
Washer fluid level indicator 	8W1 	Washer fluid level indicator
Weight category front axle 	L65 	Suspension range 65 installation control only, no requirement forecast
Weight category rear axle 	0YZ 	Without determination of weight category for rear axle
Wheels 	CE7 	Alloy wheels
Window regulator 	4R1 	Power windows
Windshield glass type 	4GH 	Windshield in heat-insulating glass with sunshield
Windshield wiper intermittent control 	8N4 	Windshield wiper intermittent control with potentiometer (four speeds)
 	PSD
Front seats 	Q1D 	Sports front seats
Light package (lighting) 	QQ0 	Without add. lights (interior lighting)
Service interval prolongation 	QG1 	Service interval prolongation
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZ2W151328
Model Designation	golf tdi variant
Date of production	03.07.2001
Model year	2002
Sales type	1J5014
Engine code	ALH
Transmission code	EGR
Axle drive	5S
Interior trim code	32
Roof color	Z4
Exterior color / Paint Code	Z4 / C9Z
Additional body covers, side 	6EA 	Without additional side body covers (stone guard)
Additional child seat anchors 	3B0 	Without additional child seat anchor
Additional warning lights 	9TB 	Additional warning lights (door area)
Air duct, front area 	VK0 	Air duct, standard
Antennas 	8L3 	Roof antenna
Anti-theft protection system 	7AB 	Electronic alarm system with vehicle immobilization device (for RoW)
Automatic transmission indicator light 	9FA 	Without automatic transmission indicator light
Backrest release 	3H0 	Without backrest release for front seats
Body style 	K8D 	Station Wagon Variant/Avant
Brackets 	3P1 	Bracket for first aid kit and warning triangle
Brake type, front 	1LS 	Front disc brakes with integrated adapter
Brake type, rear 	1KP 	Disc brakes, rear
Cassette and CD storage unit 	4W0 	Without cassette and CD storage unit
Chrome work package 	QJ0 	Without aluminum/chrome work package
Components with special surface appearance 	6FE 	Body-colored exterior mirror housings and tailgate handle
Controls (steering wheels/steering column) 	4LA 	Without controls
Cup holder 	4M0 	Without cup holder
Door and lid locking system 	4K3 	Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 	4AF 	Door and side trim panel in foam film and woven fabric
Door pockets, front 	3YQ 	Door pockets without insert mats
Doors 	0A2 	4 doors
Engine compartment lighting 	9L0 	Without engine compartment lighting
Engine specifications 	MD1 	4-cyl. turbo diesel eng. 1.9 L/66 kW TDI base engine is T0W/T0E
Equipment levels 	A8C 	Comfort equipment
Exterior mirror setting 	6XD 	Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 	2B1 	Additional exterior noise suppression
First aid kit / warning triangle 	1T2 	Warning triangle
Floor coverings 	3MF 	Dilours floor covering with scuff guard
Floor mats 	0TA 	Without floor mats
Front fog light/additional headlight 	8WA 	Without front fog light
Front license plate bracket 	6W1 	License plate bracket front (large)
Front stabilizer 	0AE 	Front stabilizer
Fuel systems 	0F3 	Fuel system for diesel engine
Gearshift boot/cover 	6R1 	Leatherette gearshift boot
Gearshift knob/handle 	6Q4 	Comfort gearshift knob/handle
General operating permit, alterations 	C20 	Operating permit, alteration
Grab handles at roof frame 	5N6 	Folding grab handles at roof frame soft fold-away
Headlight 	8JS 	Twin headlight for driving on the right with clear lens
Headrests 	3J7 	Articulated and height-adjustable headrests for front seats
Heated washer nozzles 	9T0 	Without heated washer nozzles
Horns 	8Y0 	Single-tone horn
Insert for the filling up of unleaded fuel/fuel type 	2G5 	Filler neck module 1 without insert
Inserts 	5MA 	Decorative inserts
Installation differentiation for vehicle components 	0EJ 	Installation differentiation for transmission MQ 250 vehicle components
Instrument inserts 	U0C 	Instrument insert with tachometer clock and km/h speedometer
Left vanity mirror 	4SD 	Left vanity mirror, illuminated
Luggage compartment cover 	3U2 	Sliding trunk cover
Luggage compartment floor covering 	6SL 	Tufted trunk floor covering (cut pile)
Luggage compartment lining 	5A7 	Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 	4U0 	Without luggage nets/pockets on backrests
Mass damper for steering wheels 	1Q0 	Without mass damper for steering wheel
Multi-function display/trip computer 	9Q1 	Multi-function display/on-board computer
Nameplate set 	2QK 	Nameplate set "TDI"
Outdoor temperature gage 	9Y0 	Without outdoor temperature gage
Outer rear seat belts 	3ZG 	3-point seat belts, outer rear with height adjustment
Owner's manuals 	0VA 	Without information kit
Paint coating 	FB0 	Standard paint coating
Paint preservative/transit coating 	5K0 	Without surface protection, with additional transit coating
Partition 	3CX 	Net partition
Platform group class 	7PA 	Platform group class 1
Platform module floor pan, rear 	4P3 	Rear floor panel module, type 4
Preparation for sound combination for rotating emergency light 	9F0 	Without sound combination for rotating emergency light and radio antenna preparation
Protective side molding 	4B1 	Protective side molding
Radiator grille 	6KG 	Radiator grille
Radios 	8AS 	Radio "alpha Europa"
Reading light 	8S2 	One reading light front, two reading lights rear
Rear axle 	0N5 	Standard rear axle
Rear cargo area 	3GN 	Variable cargo area concept
Rear license plate bracket 	6P1 	License plate bracket rear (ECE)
Rear seat catch 	6QA 	Rear seat catch
Rear seats 	3NE 	Rear seat bench/backrest, split folding with center armrest
Rear stabilizer 	0BC 	Rear stabilizer
Remote-controlled garage door opener 	VC0 	W/o remote-controlled garage door opener
Restraint systems, front 	3QT 	3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 	5RQ 	Right exterior mirror: convex
Right vanity mirror 	4TD 	Right vanity mirror illuminated
Roll-up sun screen for rear and side windows 	3Y0 	Without roll-up sun screen
Roof rails/roof load rack 	3S2 	Black roof rails
Seat covering 	N2Z 	Seat covering for special editions
Shock absorption, chassis, front 	G09 	Front shock absorption
Shock absorption, chassis, rear 	1JH 	Rear shock absorption
Side and rear windows 	4KC 	Side and rear windows in heat-insulating glass
Smoking/non-smoking package 	9JB 	Smoking package, ashtray front and rear
Socket 	7B0 	Without socket
Spare wheel/breakdown set 	1G2 	Steel spare wheel with original equipment tires
Speaker installation 	8RE 	4 speakers (passive)
Special alarm systems 	9A0 	Without taxi alarm system
Special color trim 	0UA 	Without special color trim
Special editions 	E2M 	"Edition"
Special labels/plates 	0SB 	Labels/plates in German
Special registration measures 	3M0 	Without special measures
Speedometer cable and seal 	8CC 	Speedometer sensor without seal (electronic speedometer sensor)
Steering 	1N1 	Power steering
Steering wheels 	1MP 	Steering wheel for air bag system
Sticker (customized or special edition) 	0KZ 	Stickers for special editions
Supertone system and tone sequence control 	9J0 	Without supertone system and tone sequence control
Taillight assemblies 	8SA 	Taillight assemblies, standard design
Tires 	H6R 	Tires 195/65 R15 T
Tool kit and jack 	1S7 	Tool kit and aluminum jack
Transmission specifications 	G0C 	5-speed manual transmission
Tray 	7N0 	Without tray on roof liner
Vehicle class differentiation units/platform components 	0CE 	Vehicle class differentiation 1J0
Washer fluid level indicator 	8W0 	Without washer fluid level indicator
Weight category front axle 	L20 	Suspension range 20 installation control only, no requirement forecast
Wheel covers 	1NL 	Covers for alloy wheels
Wheels 	C3J 	Cast alloy wheels 6J x 15 offset 38 (1J0 601 025 Q)
Window regulator 	4R4 	Power windows with comfort operation and circuit breaker
Windshield glass type 	4GF 	Windshield in heat-insulating glass
 	PH4
Child seats 	QA0 	Without child seat
Front seats 	Q1A 	Standard front seats
Nameplates for sales name 	QD1 	Nameplates for sales name
 	RAA
Base engine 	T0W 	4-cylinder diesel engine 1.9 L unit 038.B
 	WE2
 	WEJ
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZWW042895
Model Designation	golf 1.4
Date of production	20.01.1998
Model year	1998
Sales type	1J12E4
Engine code	AKQ
Transmission code	DSB
Axle drive	5S
Interior trim code	KL
Roof color	D3
Exterior color / Paint Code	D3 / A5G
Activated carbon canister 	1E1 	Activated carbon canister
Additional body covers, side 	6EJ 	Additional body cover on sill without wheel arch
Batteries 	J1P 	Battery 220 A (44 Ah)
Brake type, front 	1LQ 	Front disc brakes with integrated adapter
Braking systems 	1AC 	Anti-lock brake system (ABS)
Carrier frequency for radio remote control 	5D0 	Without carrier frequency
Catalytic converter control 	8KA 	W/o catalytic converter warning light
Center armrest 	6E3 	Front center armrest
Chassis 	2E0 	Base chassis
Cruise control warning and speed limit system 	6Y0 	Without cruise control warning system
Cup holder 	4M6 	Cup holder
Dashboard illumination 	7V0 	Standard dashboard illumination
Door and lid locking system 	4F1 	Central locking system
Door and side trim panels 	4AR 	Door and side trim panel in foam film and circular-knit
Door pockets, front 	3YR 	Door pockets with insert mats
Doors 	0A2 	4 doors
Engine specifications 	MB6 	4-cyl. gasoline engine 1.4 L/55 kW 16V with multi-point injection, EU 3D base engine is T1Q
Exterior noise suppression measures 	2B2 	Additional exterior noise suppression
Flame retardent materials 	4Q0 	No flame retardent materials
Floor mats 	0TQ 	Front and rear floor mats (polypropylene)
Front license plate carrier 	6W1 	License plate carrier front (large)
Front stabilizer 	0AM 	Front stabilizer
Fuel systems 	0F2 	Fuel system for carburetor gasoline engine
General operating permit, alterations 	C02 	Operating permit, alteration
Generators 	8GM 	Alternator 70 A
Heat accumulator system/additional heater 	7E0 	W/o heat accumulator/auxiliary heating
Heating and air conditioning system 	9AA 	Manually controlled heating system
Insert for the filling up of unleaded fuel/fuel type 	2G7 	Filler neck module 1 with insert
Interference suppression 	8E2 	Local interference suppression for FM/AM radio reception
Key for locking system 	8QC 	Key with light
Label for radio remote control 	7CA 	Without label for radio remote control
Lockable wheel bolts 	1PA 	Standard wheel bolts
Luggage compartment cover 	3U1 	Foldable trunk cover
Luggage compartment floor covering 	6SC 	Tufted trunk floor covering
Luggage compartment lighting 	9E1 	Luggage compartment lighting
Luggage net/pocket on backrest(s) 	4U1 	Luggage nets/pockets on backrests
Molding roof liner 	6NH 	Comfort molding roof liner unsplit roof cutout rear (radio antenna)
Multi-function display/trip computer 	9Q0 	Without multi-function display/ on-board computer
Nameplate set 	0NB 	Nameplate set in base trim
Partition 	3CA 	Without partition
Radios 	8AC 	Radio "beta"
Rear cargo area 	3GA 	Without cargo area
Rear license plate carrier 	6P1 	License plate carrier rear (ECE)
Rear seats 	3NW 	Rear seat bench/backrest, split folding with center armrest
Roof insert/convertible top 	3FE 	Electric slide/tilt sunroof with sun screen/sunblind
Roof rails/roof load rack 	3S0 	Without roof rails/roof load rack
Seat covering 	N0U 	Cut pile seat covering
Shock absorption, chassis, front 	1GA 	Front shock absorption, basic design 1
Shock absorption, chassis, rear 	1JA 	Rear shock absorption, basic design 1
Side lights 	8F2 	Side turn signal lights
Socket 	7B2 	12-volt socket in luggage boot
Start/stop system/regenerative braking 	7L0 	Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Sticker (customized or special edition) 	0KA 	Without stickers and badges
Throttle actuation 	0L0 	Mechanical throttle actuation
Tires 	H5V 	Tires
Transmission shafts 	1WA 	Transmission shafts w/ 90 mm in diameter
Transmission types/gearshift mechanisms 	0G3 	Gearshift linkage
Wheel covers 	1NC 	Full wheel covers
Wheels 	C6D 	Steel wheels 6J x 14 Offset 38
 	PTB
Front seats 	Q2J 	Comfort front seats
 	RBB
Base engine 	T1Q 	4-cylinder gasoline engine 1.4 L unit 036.D (aluminum)
Control number (no PR-Family) 	S3K 	Pool campaign
Weight category front axle 	U20 	Suspension range 119
 	W02
Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
VIN
golfiarzOP pisze:ja rowniez prosze o zdekodowanie wypasu w golfie :P
wvwzzz1gzmw726510
Za stary, nie ma w bazie.
NTxC
Post autor: NTxC » ndz lis 11, 2012 15:47
Witam, proszę uprzejmie o sprawdzenie: WVWZZZ1JZ1D452296
coolerclub
Post autor: coolerclub » ndz lis 11, 2012 21:27
WVWZZZ1JZXW363117
witam, proszę o pomoc w rozkodowaniu vin-u od bory.
pozdrawiam
SKODA OCTAVIA 1.9 TDI AGR
herbu
Post autor: herbu » pn lis 12, 2012 15:13
Bardzo proszę o rozkodowanie VIN:
TMBGP21U132677607
Bardzo dziękuje
Skoda Octavia 1.9TDI PD Obrazek
Marek
Auto: Golf IV Pacific
Silnik: ASZ
Post autor: Marek » pn lis 12, 2012 18:18
Witam prosiłbym o rozkodowanie VIN: WVWZZZ1JZ3B157544
Dziękuje
f707
Post autor: f707 » pn lis 12, 2012 22:10
Witam jestem zainteresowany kupnem auta o tym numerze VIN : Numer VIN WVWZZZ1JZ4D015131
prosiłbym o rozkodowanie :) dzięki z góry :pub: :pub: :pub:
“Zauważyliście, że każdy jadący wolniej od nas to palant, a szybciej - szaleniec”
marcin44
Post autor: marcin44 » wt lis 13, 2012 08:52
Witam, proszę o rozkodowanie nr VIN: VSSZZZ1MZYB024088. Z góry dziękuję.
PZDR
VIN
Post autor: VIN » wt lis 13, 2012 10:42
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZ1D452296
Model Designation	golf 1.6
Date of production	12.02.2001
Model year	2001
Sales type	1J10E4
Engine code	AZD
Transmission code	ERT
Axle drive	5S
Interior trim code	AH
Roof color	1D
Exterior color / Paint Code	1D / W5Z
Additional tunnel cover 	4J1 	Floor tray, extension center console
Base engine 	T27 	4-cylinder gasoline engine 1.6 L unit 036.L
Control number (no PR-Family) 	ST7 	Model year change, calendar week 02
Cup holder 	4M5 	Cup holder
Door and lid locking system 	4F0 	Mechanical locking system
Doors 	0A2 	4 doors
Emission standard 	0GG 	Emission standard EU4
Engine specifications 	D3H 	4-cylinder gas. engine 1.6 L/77 kW (16V) with multi-point injection Base engine is T27/TL0/TT0/TV5
Exterior mirror setting 	6XB 	Exterior mirrors: adjustable from inside
Exterior noise suppression measures 	2B7 	Additional exterior noise suppression
First aid kit / warning triangle 	1T0 	Without first aid kit and warning triangle
General operating permit, alterations 	C19 	Operating permit, alteration
Identification plates 	1FF 	Special identification plate (Poland)
Installation differentiation for vehicle components 	0EB 	Installation differentiation for transmission MQ170 vehicle components
Luggage compartment lining 	5A2 	Comfort trunk lining
Manufacturing sequence differentiation 	0FK 	Bratislava manufacturing sequence
Nameplate set 	0QE 	Nameplate set "1.6"
Radios 	8AA 	Without radio
Rear seats 	3NB 	Rear seat bench/backrest, completely folding
Seat adjustment 	3L1 	Manual height adjustment for left front seat
Seat covering 	N4C 	Fabric seat covering
Service interval prolongation 	QG2 	No possibility of activating service interval prolongation
Shock absorption, chassis, front 	G27 	Front shock absorption
Side air bag 	4X0 	Without side air bag
Tires 	H1T 	All-weather tires 255/55 R19 107H (NAR)
Trunk sill protection 	2P0 	Without trunk sill protection
Type approval countries/countries with special requirements 	B17 	Type approval Poland
Weight category front axle 	L17 	Suspension range 17 installation control only, no requirement forecast
Window regulator 	4R0 	Mechanical window regulator
 	PR4
 	PTB
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZXW363117
Model Designation	bora tdi
Date of production	07.11.1998
Model year	1999
Sales type	1J2244
Engine code	AGR
Transmission code	DQY
Axle drive	5S
Roof color	X1
Exterior color / Paint Code	X1 / B7Z
Body style 	K8B 	Notchback
Brake pad wear indicator 	9U0 	Without brake pad wear indicator
Breakaway interior mirror 	4L6 	Breakaway interior rear view mirror, automatically dimming
Bumper 	2JC 	Comfort bumpers
Component part sets with country-specific design requirements 	B0C 	Component parts set, complying with vehicle type for Belgium, various parts
Components with special surface appearance 	6FF 	Body-colored exterior mirror housings and various add-on parts
Control number (no PR-Family) 	S0C 	Introductory volume
Doors 	0A2 	4 doors
Engine specifications 	M0G 	4-cyl. turbo diesel eng. 1.9 L/66 kW TDI with MVEG 2 base engine is T0W
Flame retardent materials 	4Q1 	Flame retardent materials
Fuel quantity for initial filling 	1Z2 	Increase in initial standard fuel filling
Fuel tank treatment 	2LA 	Fuel tank without special material treatment
General operating permit, alterations 	C06 	Operating permit, alteration
Generators 	8GD 	Alternator 90A
Hand brake lever handle 	6PC 	Leather hand brake lever handle
Headlight 	8BN 	Halogen headlight for driving on the right
Heating and air conditioning system 	9AB 	Manually controlled air conditioning
Luggage compartment cover 	3U0 	Without luggage compartment cover
Luggage compartment floor covering 	6SM 	Needle-punched trunk floor covering (Dilours)
Luggage net/pocket on backrest(s) 	4U5 	Luggage pockets on backrest
Lumbar support 	7P4 	Manually adjustable lumbar support in front seats
Outer rear seat belts 	3ZM 	3-point seat belts, outer rear
Paint preservative/transit coating 	5K1 	Paint preservative (wax)
Platform module floor pan, rear 	4P1 	Rear floor panel module, type 2
Protective side molding 	4B2 	Body-colored protective side molding
Radiator grille 	6KC 	Radiator grille
Rear seat catch 	6QB 	Locking rear seat catch
Rear seats 	3NS 	Rear seat bench/backrest, split folding locking, with center armrest
Rear window wiper and washer system 	8M0 	W/o rear window wiper and washer system
Shock absorption, chassis, front 	1GC 	Front shock absorption, basic design 3
Shock absorption, chassis, rear 	1JD 	Rear shock absorption, basic design 2
Steering wheels 	2PX 	Leather trimmed sports steering wheel
Tie down straps/net/pocket 	6M3 	Trunk net
Tires 	H6U 	Tires 205/55 R16 91W
Transmission shafts 	1WB 	Transmission shafts w/ 100 mm in diameter
Trunk sill protection 	2P2 	Trunk sill protection in stainless steel
Type approval countries/countries with special requirements 	B02 	Type approval Belgium
Wheel covers 	1NU 	Full wheel covers
Wheels 	C9D 	Steel wheels 6.5J x 16
Windshield wiper intermittent control 	8N3 	Windshield wiper intermittent control with rain sensor
 	P15
 	PH1
Service interval prolongation 	QG0 	Without service interval prolongation
Weight category front axle 	U29 	Suspension range 128
 	W02
Kod: Zaznacz cały
Vehicle Identification No.	TMBGP21U132677607
Model Designation	octavia comb.elegance
Date of production	05.06.2002
Model year	2003
Sales type	1U5384
Engine code	AHF
Transmission code	EGS
Axle drive	5S
Interior trim code	BE
Roof color	D7
Exterior color / Paint Code	D7 / F5U
Braking systems 	1AJ 	Anti-spin regulation (ABS/ASR/EDL) with electronic differential lock (EDL)
Breakaway interior mirror 	4L0 	Non-dipping breakaway inside rear view mirror
Breakdown spray 	GR0 	Without emergency tire inflator
Cd enhancing underbody panel 	2D0 	Without cd enhancing underbody panel
Center high-mounted stop light 	8R1 	Center high-mounted stop light
Child bench seat 	3V0 	Without child bench seat
Dashboard 	4N1 	Padded dashboard
Doors 	0A2 	4 doors
Electric safety package 	9BC 	Display and warning tone f. opened doors
Emission standard 	0GD 	Emission standard EU2 MVEG 2
Engine specifications 	MF4 	4-cyl. turbo diesel eng. 1.9 L/81 kW TDI MVEG 2 base engine is T8U
Equipment levels 	A8D 	Luxury equipment
Fresh air intake for passenger compartment (with particulate filter) 	2V1 	Dust and pollen filter
Front fog light/additional headlight 	8WD 	Integrated front fog light
Front license plate carrier 	6W0 	Without license plate carrier front
Gearshift knob/handle 	6Q1 	Plastic gearshift knob/handle
General operating permit, alterations 	C00 	Operating permit, initial registration
Glove compartment 	4Z3 	Lockable glove compartment door, with light
Headlight washer system 	8X1 	Headlight washer system
Heated door lock cylinder 	9X0 	Without heated door lock cylinder
Key for locking system 	8QK 	Key for locking system
Left exterior mirror 	3BS 	Left exterior mirror: aspherical, electrically adjustable and heated
Left vanity mirror 	4SC 	Left vanity mirror with cover
Mud flap 	6N1 	Mud flaps rear
Owner's manuals 	0VT 	Information kit in Polish
Parking light indicator light 	8NA 	Without parking light warning light
Platform group class 	7PB 	Platform group class 2
Platform module floor pan, rear 	4P2 	Rear floor panel module, type 3
Radiator grille 	6KA 	Radiator grille
Reading light 	8S4 	Two reading lights front, two rear
Right exterior mirror 	3AF 	Right exterior mirror: convex, electrically adjustable and heated
Right vanity mirror 	4TC 	Right vanity mirror with cover
Seat belt check 	9P1 	Seat belt reminder, electric contact in buckle
Seat covering 	N2M 	Fabric seat covering
Shock absorption, chassis, front 	G33 	Front shock absorption
Ski bag 	3X0 	Without load-through provision
Speaker installation 	8RM 	8 speakers (passive)
Special labels/plates 	2KP 	Labels/plates in Polish and English
Tie down straps/net/pocket 	6M2 	Load safety net
Tires 	H3E 	Tires 195/65 R15 V (black)
Vehicle class differentiation units/platform components 	0CH 	Vehicle class differentiation 1U0
Weight category front axle 	L09 	Suspension range 09 installation control only, no requirement forecast
Wheels 	C6F 	Alloy wheels 6J x 15
Windshield glass type 	4GC 	Windshield in heat-insulating glass with sunshield
 	PHA
Base engine 	T8U 	4-cylinder diesel engine 1.9 L unit 038.G
Front seats 	Q4H 	Comfort sports seats, front
Instrument inserts 	U1A 	Instrument insert with km/h speedometer, clock, tachometer and trip odometer
VIN
Post autor: VIN » wt lis 13, 2012 10:44
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZ3B157544
Date of production	09.04.2003
Model year	2003
Sales type	1J1086
Engine code	ASZ
Transmission code	ERF
Axle drive	6S
Interior trim code	82
Roof color	8E
Exterior color / Paint Code	8E / A7W
Brake type, front 	1ZE 	Disc brakes, front (Geomet D)
Brake type, rear 	1KS 	Disc brakes, rear (Geomet D)
Chrome work package 	QJ1 	Chrome work package
Doors 	0A2 	4 doors
Floor coverings 	3MH 	Dilours floor covering w/o scuff guard
Floor mats 	0TD 	Front and rear floor mats
Front seats 	Q4P 	Sports front seats
General operating permit, alterations 	C28 	Operating permit, alteration
Inserts 	5TX 	Decorative inserts for special edition
Manufacturing sequence differentiation 	0FC 	Brussels manufacturing sequence
Nameplate set 	1DG 	Nameplate set "TDI"
Owner's manuals 	0VB 	Information kit in French
Reading light 	8S8 	2 reading lights
Shock absorption, chassis, front 	G38 	Front shock absorption
Shock absorption, chassis, rear 	UB8 	Rear shock absorption
Special editions 	E3G 	"Pacific"
Weight category front axle 	L06 	Suspension range 06 installation control only, no requirement forecast
Wheels 	CB2 	Cast alloy wheels 6.5J x 16 offset 42 (1C0 601 025 H)
 	W4T
 	WKA
 	WRA
Kod: Zaznacz cały
Vehicle Identification No.	WVWZZZ1JZ4D015131
Date of production	30.09.2003
Model year	2004
Sales type	1J1086
Engine code	ASZ
Transmission code	FMH
Axle drive	6S
Interior trim code	76
Roof color	8E
CD changer/CD player 	7A3 	CD player
Component part sets with country-specific design requirements 	B0J 	Component parts set, complying with vehicle type for Italy, various parts
Doors 	0A2 	4 doors
Emission standard 	0GZ 	Emission standard EU3, diesel with EOBD
General operating permit, alterations 	C32 	Operating permit, alteration
Owner's manuals 	0VG 	Information kit in Italian
Radios 	8AQ 	Radio "beta" with removable operating panel
Special editions 	E5E 	"Last Edition"
Special labels/plates 	0SK 	Labels/plates in Italian
Taillight assemblies 	8SB 	Taillight assembly w/ dark colored lens
Type approval countries/countries with special requirements 	B14 	Type approval Italy (San Marino, Vatican City)
Wheels 	C3K 	Cast alloy wheels 6.5J x 16 BBS, one-piece, offset 42
 	PH2
 	RBH
 	W2T
 	W4T
 	WLE
Kod: Zaznacz cały
Vehicle Identification No.	VSSZZZ1MZYB024088
Model Designation	toledo sport
Date of production	19.07.1999
Model year	2000
Sales type	1M25P4
Engine code	AGN
Transmission code	EBD
Axle drive	5S
Roof color	2F
Exterior color / Paint Code	2F /
Additional tunnel cover 	4J2 	Floor tray, extension center console
Braking systems 	1AH 	Electronic differential lock (EDL)
Bumper 	2JF 	Painted bumpers
CD changer/CD player 	7A1 	CD changer preparation
Doors 	0A2 	4 doors
Emission standard 	0GF 	Emission standard D3 EU3D
Engine specifications 	MQ8 	4-cyl. gasoline engine 1.8 L/92 kW 20V EU 3D base engine is T0V
Equipment levels 	A8F 	Sports equipment
Exterior mirror setting 	6XE 	Exterior mirrors: electrically foldable and electrically adjustable/heated
Gearshift knob/handle 	6Q5 	Sports gearshift knob
General operating permit, alterations 	C03 	Operating permit, alteration
Headlight 	8BB 	Halogen headlight for driving on the right
Headphone port, rear 	8MB 	Headphone port rear
Heated rear window 	8P1 	Heated rear window
Insert for the filling up of unleaded fuel/fuel type 	2G9 	Filler neck module 2 with insert
Interior light in driver compartment 	9GA 	Interior light with door pillar switches
Key for locking system 	8QE 	Key for locking system with remote control
Luggage compartment cover 	3U4 	Luggage compartment cover
Luggage net/pocket on backrest(s) 	4U3 	Luggage net on backrest, right seat
Molding roof liner 	6NA 	Unsplit molding roof liner
Nameplate set 	0QG 	Nameplate set "20V"
Owner's manuals 	0VF 	Information kit in English
Radios 	8YE 	Radio for comfort-class vehicle
Rear fog light 	8TF 	Rear fog lights, left and right
Rear headrests 	3Q6 	Three rear headrests
Rear license plate carrier 	6P0 	Without license plate carrier rear
Seat covering 	N2C 	Fabric seat covering
Shock absorption, chassis, front 	1GL 	Front shock absorption, sports design 2
Shock absorption, chassis, rear 	1JC 	Rear shock absorption for sports design
Side lights 	8F6 	Dark colored side turn signal lights
Special labels/plates 	0SC 	Labels/plates in English
Tool kit and jack 	1S1 	Tool kit and jack
Trailer hitch 	1D3 	Trailer hitch
Trunk sill protection 	2P1 	Plastic trunk sill protection
Vehicle class differentiation units/platform components 	0CK 	Vehicle class differentiation 1M0
Wheels 	C7F 	Alloy wheels
 	PE1
 	RB2
Base engine 	T0V 	4-cylinder gasoline engine 1.8 L unit 06A.A
Control number (no PR-Family) 	SV8 	Oil change for GTI Nigeria
Wheels 	V23 	Alloy wheels
myszoskoczek
Post autor: myszoskoczek » śr lis 14, 2012 09:15
Prosiłbym o sprawdzenie:
WWZZZ1JZXW677188
Z góry dzięki :)
ZZR
Post autor: ZZR » śr lis 14, 2012 19:07
Uprzejmie proszę o sprawdzenie:
WVWZZZ1GZMB095488
dzięki L^
.: Nie lataj szybciej, niż potrafi Twój Anioł Stróż :.
rozcak_69
Post autor: rozcak_69 » śr lis 14, 2012 20:47
Witam; proszę o sprawdzenie Golf GTI 2.0
WVWZZZ1KZ6W022442
dziękuje i pozdrawiam
Wróć do „Chcę kupić auto”
