Brak mocy w ALH
WiRaGe
Post autor: WiRaGe » sob lip 28, 2007 11:09
Caveman pisze:16485 - Mass Air Flow Sensor (G70): Implausible Signal
no ewidentnie przepływonierz
http://forum.vwgolf.pl/viewtopic.php?p=1255847
[img]http://img503.imageshack.us/img503/8563/img1681ew7.jpg[/img][img]http://img503.imageshack.us/img503/6577/img1679ik0mn9.jpg[/img]
ksionc
Post autor: ksionc » sob lip 28, 2007 15:24
dobrze by bylo jeszcze sprawdzic jak dziala przeplywka podczas jazdy, tylko juz dobrze nie pamietam w ktorym to jest bloku.
Mody mode on in one point najn ti di aj endzajn
Caveman
Post autor: Caveman » sob lip 28, 2007 16:12
wklejam log'a ale jest to samo jak na forum powyzej
Friday,27,July,2007,23:40:58
038 906 012 M,, 1.9l R4 EDC 0000SG 2813,
,Group A:,'010,,,,Group B:,'011,,,,Group C:,'021
,,MAF Sensor,Atmos. Pressure,Manifold Pressure,Throttle,,Engine speed,Specified MAP,Actual MAP,D.cycle MAP v.,,Mass Air / Rev.,Mass Air / Rev.,Duty Cycle,Bin. Bits
,TIME,230-370 mg/H,Sensor-f96-,MAP sensor-G71-,%Throttle,TIME,rpm,1850-1950 mbar,1700-2080 mbar,45-95%,TIME,,,,
Marker,STAMP, mg/str, mbar, mbar,%,STAMP, /min, mbar, mbar, %,STAMP, mg/str, mg/str, %,
,0.41,5.0,999.6,1030.2,0.0,0.83,903,999.6,1030.2,24.7,0.00,270.0,5.0,19.9, 010 111
,1.66,5.0,999.6,1030.2,0.0,2.08,903,999.6,1030.2,24.7,1.25,265.0,5.0,19.9, 010 111
,2.88,5.0,999.6,1030.2,0.0,3.28,903,999.6,1030.2,24.7,2.48,270.0,5.0,19.9, 010 111
,13.62,5.0,999.6,1071.0,3.1,14.02,903,999.6,1060.8,24.7,13.22,435.0,5.0,19.9, 000 100
,14.82,5.0,999.6,1050.6,0.0,15.22,903,999.6,1040.4,24.7,14.42,285.0,5.0,19.9, 010 100
,16.02,5.0,999.6,1040.4,4.7,16.42,1008,999.6,1040.4,24.7,15.62,275.0,5.0,19.9, 010 100
,17.22,5.0,999.6,1060.8,24.3,17.62,1176,1050.6,1091.4,24.7,16.82,345.0,5.0,19.9, 000 100
,18.42,5.0,999.6,1091.4,37.3,18.82,1344,1101.6,1111.8,37.1,18.02,635.0,5.0,19.9, 000 100
,19.62,0.0,999.6,1203.6,51.8,20.02,1932,1601.4,1295.4,29.9,19.22,415.0,0.0,19.9, 000 000
,20.82,0.0,999.6,1479.0,79.2,21.22,2373,1948.2,1540.2,27.1,20.42,650.0,0.0,19.9, 000 000
,22.02,0.0,999.6,1652.4,100.0,22.42,2667,1876.8,1693.2,39.0,21.62,795.0,0.0,4.8, 000 000
,23.22,550.0,999.6,1560.6,70.6,23.63,3276,1662.6,1621.8,57.4,22.82,725.0,0.0,19.9, 000 000
,24.42,550.0,999.6,1754.4,75.7,24.82,4410,1448.4,1662.6,74.5,24.02,850.0,550.0,4.8, 000 000
,25.62,550.0,999.6,1305.6,72.2,26.02,2730,1948.2,1591.2,41.8,25.22,850.0,550.0,4.8, 010 100
,26.82,550.0,999.6,1907.4,98.0,27.20,3150,1948.2,1907.4,56.6,26.42,800.0,550.0,4.8, 000 000
,28.02,550.0,999.6,1887.0,100.0,28.42,3570,1948.2,1887.0,56.2,27.62,815.0,550.0,4.8, 000 000
,29.22,550.0,999.6,1866.6,100.0,29.62,3948,1948.2,1876.8,57.0,28.82,850.0,550.0,4.8, 000 000
,30.42,550.0,999.6,1315.8,2.0,30.82,2520,1734.0,1285.2,24.7,30.02,850.0,550.0,4.8, 010 100
,31.62,550.0,999.6,1825.8,96.1,32.02,2709,1948.2,1938.0,56.6,31.22,790.0,550.0,4.8, 000 000
,32.82,550.0,999.6,1897.2,95.7,33.22,2898,1948.2,1866.6,53.4,32.42,790.0,550.0,4.8, 000 000
,34.05,550.0,999.6,1866.6,95.3,34.47,3066,1948.2,1876.8,53.0,33.62,795.0,550.0,4.8, 000 000
,35.28,550.0,999.6,1907.4,96.9,35.70,3234,1948.2,1917.6,54.6,34.88,800.0,550.0,4.8, 000 000
,36.50,550.0,999.6,1938.0,98.0,36.90,3381,1948.2,1938.0,55.4,36.10,810.0,550.0,4.8, 000 000
,37.70,550.0,999.6,1897.2,97.6,38.10,3528,1948.2,1897.2,53.4,37.30,815.0,550.0,4.8, 000 000
,38.90,550.0,999.6,1917.6,97.6,39.30,3654,1948.2,1917.6,54.2,38.50,835.0,550.0,4.8, 000 000
,40.10,550.0,999.6,1938.0,97.3,40.50,3549,1060.8,1611.6,53.0,39.70,850.0,550.0,4.8, 000 000
,41.30,550.0,999.6,1499.4,96.1,41.70,2709,1948.2,1785.0,53.0,40.90,805.0,550.0,4.8, 000 100
,42.50,550.0,999.6,1958.4,95.3,42.90,2793,1948.2,1917.6,55.0,42.10,785.0,550.0,4.8, 000 000
,43.70,550.0,999.6,1856.4,96.9,44.10,2856,1948.2,1846.2,52.2,43.30,795.0,550.0,4.8, 000 000
,44.90,550.0,999.6,1846.2,97.3,45.30,2940,1948.2,1856.4,50.2,44.50,795.0,550.0,4.8, 000 000
,46.10,550.0,999.6,1876.8,97.6,46.50,3003,1948.2,1887.0,51.0,45.70,800.0,550.0,4.8, 000 000
,47.30,550.0,999.6,1907.4,96.5,47.70,3087,1948.2,1897.2,50.6,46.90,800.0,550.0,4.8, 000 000
Grześko
Post autor: Grześko » sob lip 28, 2007 21:32
No niestety, albo przepływka nie łączy, albo padnięta na maxa.
Komputer podstawia wartość 550, żeby można było dalej jechać. Taka wartość zapewnia, że nie dostanie za dużo paliwa, nie będzie kopcił a jechać powinien.
Caveman
Post autor: Caveman » ndz lip 29, 2007 17:18
wlasnie szukam na eBay czegos normalnego jak Bosh czy Pierburg ale znajduje chinski szajs ktos wie czy warto to kupic?
damcio151
Post autor: damcio151 » ndz lip 29, 2007 22:19
Caveman pisze:wlasnie szukam na eBay czegos normalnego jak Bosh czy Pierburg ale znajduje chinski szajs ktos wie czy warto to kupic?
nie warto , jeżeli przepływka to tylko pierburga
ksionc
Post autor: ksionc » czw sie 02, 2007 11:06
nie ma co brać chińszczyzny bo albo padnie po miesiącu albo będzie podawała od początku złą wartość.
Caveman
Post autor: Caveman » sob sie 11, 2007 18:52
A jakimi wartosciami powinna sie charakteryzowac nowa przeplywka?
Moja to 0281 002 216
[ Dodano: 28 Sie 2007 18:26 ]
Mowisz ewidentnie przeplywomierz, fakt chcialo mi sie go rozebrac i platynka byla peknieta. Ok, kupilem nowy. I teraz mam:
1 Fault Found:
17552 - Mass Air Flow Sensor (G70): Open or Short to Ground
P1144 - 35-00 - -
wtyczke sprawdzilem niby miedzy stykami a przewodami na odleglosci 10cm przejscie jest.
Rozkladam rece na to.
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 117 gości
