Nie daj się oszukać, sprawdź VIN i historię
Moderatorzy: palio, jhosef, VIP
Re: Nie daj się oszukać, sprawdź VIN i historię
Bardzo prosze o sprawdzenie tej Meganki
nr VIN VF1BA0T0515245233
Z gory dziekuje, pozdrawiam.
Proszę o sprawdzenie mojego nowego nabytku. Problemy pojawiły się już przy zmianie filtra paliwa.
WVWZZZ1KZ8W130509
Z góry dziękuję.
WVWZZZ1KZ8W130509
Z góry dziękuję.
Kod: Zaznacz cały
Vehicle Identification No. WAUZZZ8LZ1A083203
Model Designation audi a3 1.9 tdi
Date of production 06.03.2001
Model year 2001
Sales type 8L1BGC
Engine code ASZ
Transmission code DRW
Axle drive 6S
Interior trim code EG
Roof color Q5
Exterior color / Paint Code Q5 / Z5L
Activated carbon canister 1E0 Without activated charcoal canister
Additional child seat anchors 3B0 Without additional child seat anchor
Additional dust seals 6U0 Without additional seals outside
Additional tires (winter tires) 2WA Without additional tires
Air bag 4UE Air bag for driver and front seat passenger
Anti-theft protection system 7AA Electronic vehicle immobilization device
Antifreeze 1C1 Antifreeze up to -25 degree celsius tolerance up to -30 degree C
Auxiliary heating 9M0 Without auxiliary/parking heater
Backrest release 3H6 Backrest release for front seats with "Easy Entry" and add. backrest release on the inner side of right front seat
Batteries J0L Battery 340 A (70 Ah)
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake type, front 1LE Disc brakes, front
Brake type, rear 1KK Disc brakes, rear
Braking systems 1AT Electronic stabilization program (ESP)
Breakaway interior mirror 4L2 Dipping breakaway interior rear view mirror
Bumper 2JB Standard bumpers
CD ROM/DVD/SD card 7QA Without CD/DVD for navigation
CD changer/CD player 7A0 Without CD changer/CD player
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
Catalytic converter control 8KA W/o catalytic converter warning light
Cd enhancing underbody panel 2D1 Complete cd enhancing underbody panel
Center armrest 6E0 Without center armrest front
Center rear seat belts 3C1 Static lap belt, center rear
Component part sets with country-specific design requirements B0A Component parts set without country-specific design requirement
Components with special surface appearance 6FB Body-colored exterior mirror housings
Cruise control 8T0 Without cruise control system (CCS)
Customized installation FC0 Without customized installation
Delivery equipment 2A5 Delivery equipment (transit coating) with thin seat cover
Door and lid locking system 4K4 Radio remote controlled central locking
Doors 0A1 2 doors
Drive layout 1X0 Front wheel drive
Electronic map cooling system QS0 Without electronic map cooling system
Emission standard 0GE Emission standard EU3
Engine cooling system 8Z5 Not hot country
Engine specifications D3E 4-cyl. turbo diesel engine 1.9 L/96 kW TDI with pump-jet injection system Base engine is T9J
Equipment levels A9D "Ambition" equipment
Exterior mirror setting 6XD Exterior mirrors: electrically adjustable/heated
Exterior noise suppression measures 2B3 Additional exterior noise suppression (hood, capsule and dash panel)
Fire extinguisher 6A0 Without fire extinguisher
First aid kit / warning triangle 1T3 First aid kit with warning triangle
Floor mats 0TD Front and rear floor mats
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated charcoal canister
Front fog light/additional headlight 8WB Front fog lights
Front license plate bracket 6W5 Front license plate bracket
Front stabilizer 0AL Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel filler cap/door, locking option 2W0 Fuel filler cap
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 0F9 Cooled fuel system for diesel engine
Fuel tank treatment 2LB Fuel tank with special material treatment
Gearshift boot/cover 6R2 Leather gearshift boot
Gearshift knob/handle 6Q2 Leather gearshift knob/handle
General operating permit, alterations C16 Operating permit, alteration
Generators 8GL Alternator 120 A
Hand brake lever handle 6PA Plastic hand brake lever handle
Handling standard production and pre-production series FA0 Control of standard production
Headlight 8JH Ellipsoidal headlight for driving on the right
Headlight activation 8K0 Without special headlight activation
Headlight washer system 8X0 Without headlight washer system
Headlight-range adjustment 8Q1 Headlight-range adjustment
Heat accumulator system/additional heater 7E3 Sheathed type glow plug heater
Heated door lock cylinder 9X6 Heated door lock cylinder left with micro switch
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AK Climatronic with impact pressure control free of cfc
Horns 8Y1 Two-tone horn
Identification plates 1EX Special identification plate for EC for M1 passenger vehicle
Ignition/starter switch locking system 0RA Without ignition/starter switch locking system
Insert for the filling up of unleaded fuel/fuel type 2G8 Filler neck module 2 without insert
Inserts 5TC Without decorative inserts
Label for central electric 0W1 Label for central electric German-speaking countries
Label for radio remote control 7CA Without label for radio remote control
Left exterior mirror 5SL Left exterior mirror: aspherical
Light package (lighting) QQ0 Without add. lights (interior lighting)
Lock operation for tailgate/trunk lid 4E0 Tailgate/trunk lid unlocking from outside
Lockable wheel bolts 1PC Wheel bolts with anti-theft protection (unlockable)
Lumbar support 7P0 Without lumbar support in seat backrests
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Mud flap 6N0 Without mud flaps
Multi-function display/trip computer 9Q2 Multi-function display/on-board computer with check control
Navigation device 7Q0 Without navigation device
Outdoor temperature gage 9Y1 Outdoor temperature gage
Owner's manuals 0VC Information kit in German
Paint preservative/transit coating 5K1 Paint preservative (wax)
Park distance control 7X0 Without park distance control
Platform group class 7PE Platform group class 5
Platform module floor pan, rear 4P0 Rear floor panel module, type 1
Preparation for two-way radio installation 9D0 Without preparation for two-way radio installation
Proportioning valve 1H0 Without proportioning valve
Radios 8UD Radio "concert"
Rear axle 0N1 Standard rear axle
Rear fog light 8TC Rear fog light for driving on the right
Rear headrests 3Q1 Rear headrests
Rear seats 3NC Rear seat bench/backrest, split folding
Rear spoiler 5J0 Without rear spoiler
Rear stabilizer 0BB Rear stabilizer
Rear trim panel 6V1 Rear trim panel (ECE)
Rear window wiper and washer system 8M1 Rear window wiper and washer system with intermittent control
Right exterior mirror 5RU Right exterior mirror: convex (large viewing field)
Roof insert/convertible top 3FA Without roof insert (standard roof)
Rough-road/sports version 2UA Standard design
Safety certificate 0LW Special plates/stickers/ safety certificates for Germany
Scuff plates 7M0 Plastic scuff plates in door apertures
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P0 Without seat belt reminder
Seat covering N0E Woven fabric seat covering
Seat heater 4A3 Seat heater for front seats separately controlled
Self-collection / special control A00 No self-collection
Service interval prolongation QG2 No possibility of activating service interval prolongation
Shock absorption, chassis, front G66 Front shock absorption
Shock absorption, chassis, rear 1JK Rear shock absorption, sports design
Side air bag 4X1 Side air bag front
Side lights 7R3 Side turn signal lights (white)
Sill top/sill cover 5E1 Without sill top with door cover
Spare wheel/breakdown set 1G3 Alloy spare wheel with original equipment tires
Speaker installation 9VD Speaker (active)
Special editions E0A No special edition
Special labels/plates 0ST Labels/plates in German and French
Steering 1N6 Power steering
Steering column systems 2C5 Axial and vertical adjustable steering column
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2PV Leather trimmed sports steering wheel
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Tachograph/logbook 9NX Without electronic logbook
Telephone/telematics 9ZF Mobile phone preparation with hands-free speaking system
Throttle actuation 0L2 Electric throttle actuation
Tie down straps/net/pocket 6M0 Without tie down straps/net/pocket
Tires H6U Tires 205/55 R16 91W
Trailer hitch 1D0 Without trailer hitch
Transmission specifications G0K 6-speed manual transmission
Transmission types/gearshift mechanisms 0G4 Cable gearshift
Type approval countries/countries with special requirements B99 Type approval EC
Type sign 2Z1 Type sign at rear and "Quattro" nameplates respectively
Vehicle class differentiation units/platform components 0CJ Vehicle class differentiation 8L0
Vehicle specifications F0A No special purpose vehicle, standard equipment
Vehicle type AZ0 Vehicle with standard production scope
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L67 Suspension range 67 installation control only, no requirement forecast
Weight category rear axle 0YZ Without determination of weight category for rear axle
Wheels C3F Cast alloy wheels 6.5J x 16 5-arm style, offset 42
Window regulator 4R1 Power windows
Windshield glass type 4GH Windshield in heat-insulating glass with sunshield
Windshield wiper intermittent control 8N4 Windshield wiper intermittent control with potentiometer (four speeds)
PFA
PH5
PI1
PR1
PT8
PW1
Front seats Q1D Sports front seats
RCL
Base engine T9J 4-cylinder diesel engine 1.9 L unit 038.K
Control number (no PR-Family) SA6 Inventory control model 1
Instrument inserts U2A Instrument insert with km/h speedometer, radio-controlled clock, tachometer and trip odometer
Tire suppliers V0G MICHELIN tires
YMI Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1KZ8W130509
Model Designation golf 1.9
Date of production 12.10.2007
Model year 2008
Sales type 1K1011
Engine code BXF
Transmission code JCR
Axle drive 5S
Interior trim code HA
Roof color A1
Exterior color / Paint Code A1 / 041
"Multimedia", video/DVD/notebook connection 9WC Without "Multimedia" in vehicle
Additional body covers, side 6EA Without additional side body covers (stone guard)
Additional child seat anchors 3B4 Child seat anchor for child seat system ISOFIX
Additional warning lights 9TC Additional reflectors (door area)
Air bag 4UF Driver's and front passenger air bag with front passenger air bag deactivation
Air duct, front area VK0 Air duct, standard
Antennas 8ZN Antenna
Backrest release 3H9 Backrest release for front seats with "Easy Entry"
Base engine T71 4-cylinder diesel engine 1.9 L unit 03G.1
Batteries J0N Battery 330 A (61 Ah)
Battery/alternator capacity NY0 Standard battery/alternator capacity
Brackets 3P1 Bracket for first aid kit and warning triangle
Brake type, front 1ZF Disc brakes, front (Geomet D)
Brake type, rear 1KD Disc brakes, rear
Braking systems 1AC Anti-lock brake system (ABS)
Cassette and CD storage unit 4W0 Without cassette and CD storage unit
Center armrest 6E3 Front center armrest
Center rear seat belts 3C7 3-point seat belt for center rear seat
Child seat anchor, front 3G0 Without child seat anchor front (ISOFIX)
Climatic zones 0Y1 Standard climatic zones
Compass/traffic sign display QR0 Without compass/traffic sign display/ traffic signs recognition
Components with special surface appearance 6FA Components without special surface appearance
Cruise control 8T2 Cruise control system (CCS) electronic
Delivery equipment 2A0 Without delivery equipment
Door and lid locking system 4K3 Radio remote controlled central locking operated from inside and safe securing
Door and side trim panels 4AF Door and side trim panel in foam film and woven fabric
Door pockets, front 3YQ Door pockets without insert mats
Doors 0A1 2 doors
Electric interface for external use UF0 Without electric interface
Emission standard 0GG Emission standard EU4
Engine specifications MF7 4-cyl. turbo diesel eng. 1.9 L/66 kW TDI pump-jet injection system Base engine is T1T/T71/TG0
Equipment levels A8B Basic equipment
Exhaust tailpipe 0P0 Rear exhaust tailpipe (standard)
Exterior mirror setting 6XN Exterior mirrors: electrically adjustable, separately heated
First aid kit / warning triangle 1T0 Without first aid kit and warning triangle
Floor mats 0TA Without floor mats
Front fog light/additional headlight 8WA Without front fog light
Front license plate bracket 6W1 License plate bracket front (large)
Front seat, left 3TB Standard seat, front left
Front seat, right 3SB Standard seat, front right
Front stabilizer 0AD Front stabilizer
Fuel systems 0F8 Cooled fuel system for diesel engine
Fuel tank treatment 2LD Fuel tank without differentiation of special material treatment (fluorination/co-extrusion)
Gearshift knob/handle 6Q1 Plastic gearshift knob/handle
General operating permit, alterations C21 Operating permit, alteration
Generators 8GU Alternator 140 A
Headlight 8BG Twin-headlight for driving on the right, with integrated high beam
Headrests 3J1 Height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E6 Electric auxiliary air heater
Heated washer nozzles 9T0 Without heated washer nozzles
Heating and air conditioning system 9AP Climatic air-conditioning system (semi-automatic)
Hill hold control UG0 Without hill hold control / hill descent control / comfort driving assist
Horns 8Y0 Single-tone horn
Insert for the filling up of unleaded fuel/fuel type 2G5 Filler neck module 1 without insert
Installation differentiation for vehicle components 0EJ Installation differentiation for transmission MQ 250 vehicle components
Instrument inserts U5A Instrument insert, km/h speedometer
Interior light in foot area 6T0 Without interior light in footwell
Left vanity mirror 4SB Vanity mirror left
Lockable wheel bolts 1PA Standard wheel bolts
Luggage compartment cover 3U1 Foldable trunk cover
Luggage compartment lining 5A2 Comfort trunk lining
Luggage net/pocket on backrest(s) 4U0 Without luggage nets/pockets on backrests
Mass damper for steering wheels 1Q0 Without mass damper for steering wheel
Multi-function display/trip computer 9Q0 Without multi-function display/ on-board computer
Nameplate set 1DG Nameplate set "TDI"
Operating voltage 9Z0 Operating voltage 12V
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE label
Owner's manuals 0VB Information kit in French
Paint coating FB0 Standard paint coating
Partition 3CA Without partition
Pedal cluster VF0 Standard pedal cluster
Pedestrian protection VL1 Extended pedestrian protection measures
Platform group class 7PA Platform group class 1
Preparation for sound combination for rotating emergency light 9F0 Without sound combination for rotating emergency light and radio antenna preparation
Protective side molding 4B1 Protective side molding
Radios 8AA Without radio
Reading light 8S1 Reading light front
Rear cargo area 3GA Without cargo area
Rear headrests 3T2 Three rear headrests
Rear license plate bracket 6P1 License plate bracket rear (ECE)
Rear seats 3NZ Rear seat bench unsplit, backrest split folding
Rear stabilizer 0BD Rear stabilizer
Refrigerator 1W2 Glove compartment cooling system
Remote-controlled garage door opener VC0 W/o remote-controlled garage door opener
Restraint systems, front 3QT 3-point seat belts with tensioner and height adjustment, front
Right exterior mirror 5RQ Right exterior mirror: convex
Right vanity mirror 4TB Vanity mirror right
Roll-up sun screen for rear and side windows 3Y0 Without roll-up sun screen
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Safety headrest system 3K0 Without safety headrest system
Scuff plates 7M5 Without protective film for scuff plate
Seat adjustment 3L1 Manual height adjustment for left front seat
Seat belt check 9P3 Seat belt reminder, electric contact in buckle
Seat covering N4C Fabric seat covering
Seat heater 4A0 Without seat heater
Shock absorption, chassis, front G02 Front shock absorption
Shock absorption, chassis, rear 1JA Rear shock absorption, basic design 1
Side air bag 4X3 Side air bag front with curtain air bag
Side and rear windows 4KC Side and rear windows in heat-insulating glass
Ski bag 3X0 Without load-through provision
Smoking/non-smoking package 9JB Smoking package, ashtray front and rear
Socket 7B0 Without socket
Spare wheel/breakdown set 1G6 Space-saving spare wheel
Speaker installation 8RE 4 speakers (passive)
Special alarm systems 9A0 Without taxi alarm system
Special labels/plates 0SS Labels/plates in English and French
Special registration measures 3M0 Without special measures
Steering 1N3 Speed-related variable steering assist (Servotronic)
Steering wheels 1ME Steering wheel
Sticker (customized or special edition) 0KA Without stickers and badges
Supertone system and tone sequence control 9J0 Without supertone system and tone sequence control
Telephone/telematics 9W0 W/o car phone preparation/installation
Tire pressure warning light 7K0 Without tire pressure warning light
Tires H6R Tires 195/65 R15 T
Tool kit and jack 1S1 Tool kit and jack
Transmission specifications G0C 5-speed manual transmission
Trunk sill protection 2P1 Plastic trunk sill protection
Type approval countries/countries with special requirements B08 Type approval France
Upgrading measures GP0 Vehicles w/o special upgrade measures
Vehicle class differentiation units/platform components 0HA Vehicle class differentiation 1K0/5K0
Washer fluid level indicator 8W0 Without washer fluid level indicator
Weight category front axle L06 Suspension range 06 installation control only, no requirement forecast
Weight category rear axle 0YB Weight range 2 installation control only, no requirement forecast
Wheel covers 1NC Full wheel covers
Wheels C8V Steel wheels 6J x 15
Window regulator 4R4 Power windows with comfort operation and circuit breaker
Windshield glass type 4GF Windshield in heat-insulating glass
PH1
PR3
Child seats QA0 Without child seat
Chrome work package QJ0 Without aluminum/chrome work package
Drawers under front seats QN0 Without drawers under front seats
Nameplates for sales name QD1 Nameplates for sales name
Service interval prolongation QG1 Service interval prolongation
Tire suppliers V0A Tires w/o specification of tire brand Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZXW456069
Model Designation golf gti turbo
Date of production 14.12.1998
Model year 1999
Sales type 1J16R4
Engine code AGU
Transmission code ECW
Axle drive 5S
Interior trim code RJ
Roof color A1
Activated carbon canister 1E1 Activated carbon canister
Additional body covers, side 6EJ Additional body cover on sill without wheel arch
Additional tunnel cover 4J1 Floor tray, extension center console
Additional warning lights 9TB Additional warning lights (door area)
Antennas 8L3 Roof antenna
Anti-theft protection system 7AB Electronic alarm system with vehicle immobilization device (for RoW)
Automatic transmission indicator light 9FA Without automatic transmission indicator light
Backrest release 3H0 Without backrest release for front seats
Batteries J1L Battery 280 A (60 Ah)
Brake pad wear indicator 9U0 Without brake pad wear indicator
Brake type, front 1ZH Disc brakes, front (Geomet D)
Brake type, rear 1KS Disc brakes, rear (Geomet D)
Braking systems 1AH Electronic differential lock (EDL)
Bumper 2JC Comfort bumpers
Chassis 2E0 Base chassis
Components with special surface appearance 6FF Body-colored exterior mirror housings and various add-on parts
Cup holder 4M6 Cup holder
Door pockets, front 3YR Door pockets with insert mats
Doors 0A2 4 doors
Engine compartment lighting 9L0 Without engine compartment lighting
Engine specifications MQ4 4-cyl. gasoline engine 1.8 L/110 kW 20V turbo, EU 3D base engine is T8C
Equipment levels A8H Top sports equipment
Exterior noise suppression measures 2B1 Additional exterior noise suppression
Flame retardent materials 4Q1 Flame retardent materials
Floor mats 0TQ Front and rear floor mats (polypropylene)
Front fog light/additional headlight 8WD Integrated front fog light
Fuel systems 0F2 Fuel system for carburetor gasoline engine
Gearshift knob/handle 6Q3 Wooden gearshift knob/handle
General operating permit, alterations C07 Operating permit, alteration
Generators 8GD Alternator 90A
Grab handles at roof frame 5N6 Folding grab handles at roof frame soft fold-away
Hand brake lever handle 6PC Leather hand brake lever handle
Headlight 8JS Twin headlight for driving on the right with clear lens
Headlight washer system 8X1 Headlight washer system
Headrests 3J7 Articulated and height-adjustable headrests for front seats
Heat accumulator system/additional heater 7E0 W/o heat accumulator/auxiliary heating
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Inserts 5MW Decorative inserts, dark myrtle wood
Key for locking system 8QE Key for locking system with remote control
Left vanity mirror 4SD Left vanity mirror, illuminated
Luggage compartment floor covering 6SC Tufted trunk floor covering
Luggage compartment lighting 9E1 Luggage compartment lighting
Luggage compartment lining 5A7 Comfort trunk lining with service lid/ cover
Luggage net/pocket on backrest(s) 4U1 Luggage nets/pockets on backrests
Lumbar support 7P4 Manually adjustable lumbar support in front seats
Molding roof liner 6NH Comfort molding roof liner unsplit roof cutout rear (radio antenna)
Multi-function display/trip computer 9Q1 Multi-function display/on-board computer
Nameplate set 0NH Nameplate set "GTI"
Outdoor temperature gage 9Y0 Without outdoor temperature gage
Outer rear seat belts 3ZG 3-point seat belts, outer rear with height adjustment
Paint preservative/transit coating 5K0 Without surface protection, with additional transit coating
Protective side molding 4B2 Body-colored protective side molding
Radiator grille 6KG Radiator grille
Radios 8AD Radio "gamma"
Reading light 8S2 One reading light front, two reading lights rear
Rear headrests 3T3 3 rear headrests height-adjustable
Rear seat catch 6QA Rear seat catch
Rear seats 3NW Rear seat bench/backrest, split folding with center armrest
Right vanity mirror 4TD Right vanity mirror illuminated
Seat covering N2T Fabric seat covering
Shock absorption, chassis, front 1GD Front sports shock absorption
Shock absorption, chassis, rear 1JC Rear shock absorption for sports design
Side lights 8F6 Dark colored side turn signal lights
Socket 7B2 12-volt socket in luggage boot
Spare wheel/breakdown set 1G2 Steel spare wheel with original equipment tires
Speaker installation 8RM 8 speakers (passive)
Special color trim 0UA Without special color trim
Special labels/plates 0SB Labels/plates in German
Speedometer cable and seal 8CC Speedometer sensor without seal (electronic speedometer sensor)
Start/stop system/regenerative braking 7L0 Without inertia benefit system/ deceleration fuel cut-off/idle stop valve
Steering 1N1 Power steering
Steering wheels 2PX Leather trimmed sports steering wheel
Taillight assemblies 8SB Taillight assembly w/ dark colored lens
Throttle actuation 0L0 Mechanical throttle actuation
Tool kit and jack 1S7 Tool kit and aluminum jack
Transmission shafts 1WB Transmission shafts w/ 100 mm in diameter
Trunk sill protection 2P0 Without trunk sill protection
Type approval countries/countries with special requirements B01 Type approval Germany
Vehicle class differentiation units/platform components 0CE Vehicle class differentiation 1J0
Weight category front axle J65 Suspension range 65
Wheel covers 1NL Covers for alloy wheels
Wheels C9A Alloy wheels 6.5J x 16 offset 42
Windshield glass type 4GC Windshield in heat-insulating glass with sunshield
PH6
PT1
PTB
Front seats Q2Q RECARO sports seats, front
Service interval prolongation QG0 Without service interval prolongation
RCA
Base engine T8C 4-cylinder gasoline engine 1.8 L unit 06A.C
Instrument inserts U0C Instrument insert with tachometer clock and km/h speedometer
Tire suppliers V0A Tires w/o specification of tire brand Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Niestety nie dysponuję dekoderem Renaulta.albert107 pisze:Witam
diehard1800
Witam.
Posiadam od niedawna samochód VW Bory 173tyś przebiegu. Auto niby serwisowane do samego końca w ASO jednak mam duże wątpliwości co do przebiegu. Bardzo proszę sprawdzenie samochodu po VIN WVWZZZ1JZ3W412794 oraz o historię serwisową, albo chociaż o info czy ten przebieg (173tyś) może być prawidłowy. Pytam ponieważ sprzedawca (handlarz) zapewniał mnie że przy 155tyś był robiony rozrząd. Boję się, że ściemniał i pewnego dnia pasek może pęknąć :
Z góry dziękuję.
Z góry dziękuję.
Auto z Belgii, więc żadnej historii serwisowej może nie być, to raz, dwa - nigdy nie wierz handlarzowi i lepiej zmień ten rozrząd.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1JZ3W412794
Model Designation bora 1.6
Date of production 11.12.2002
Model year 2003
Sales type 1J22E4
Engine code BCB
Transmission code ERT
Axle drive 5S
Interior trim code RW
Roof color Z4
Exterior color / Paint Code Z4 / C9Z
Base engine T27 4-cylinder gasoline engine 1.6 L unit 036.L
Body style K8B Notchback
Brake type, front 1LS Front disc brakes with integrated adapter
Brake type, rear 1KP Disc brakes, rear
Chrome work package QJ1 Chrome work package
Component part sets with country-specific design requirements B0C Component parts set, complying with vehicle type for Belgium, various parts
Control number (no PR-Family) SA0 Model year change calendar week 45
Controls (steering wheels/steering column) 4LA Without controls
Cup holder 4M5 Cup holder
Doors 0A2 4 doors
Engine specifications D3H 4-cylinder gas. engine 1.6 L/77 kW (16V) with multi-point injection Base engine is T27/TL0/TT0/TV5
Equipment levels A8G Sports comfort equipment
Exterior noise suppression measures 2B0 Without additional exterior noise suppression
First aid kit / warning triangle 1T2 Warning triangle
Floor coverings 3MF Dilours floor covering with scuff guard
Front stabilizer 0AE Front stabilizer
Fuel quantity for initial filling 1Z2 Increase in initial standard fuel filling
Gearshift boot/cover 6R1 Leatherette gearshift boot
Gearshift knob/handle 7F3 Leather/wooden gearshift knob
General operating permit, alterations C27 Operating permit, alteration
Headlight 8BN Halogen headlight for driving on the right
Inserts 5MD Decorative aluminum inserts
Installation differentiation for vehicle components 0EB Installation differentiation for transmission MQ170 vehicle components
Luggage compartment cover 3U0 Without luggage compartment cover
Luggage compartment floor covering 6SM Needle-punched trunk floor covering (Dilours)
Nameplate set 0QE Nameplate set "1.6"
Outer rear seat belts 3ZM 3-point seat belts, outer rear
Owner's manuals 0XN Information kit in French and Dutch
Platform module floor pan, rear 4P1 Rear floor panel module, type 2
Radiator grille 6KC Radiator grille
Rear axle 0N5 Standard rear axle
Rear seat catch 6QB Locking rear seat catch
Rear seats 3NS Rear seat bench/backrest, split folding locking, with center armrest
Rear window wiper and washer system 8M0 W/o rear window wiper and washer system
Seat covering N0N Woven fabric seat covering
Shock absorption, chassis, front G86 Front sports shock absorption
Taillight assemblies 8SA Taillight assemblies, standard design
Tires H6S Tires 195/65 R15 V
Transmission types/gearshift mechanisms 0G3 Gearshift linkage
Tray 7N0 Without tray on roof liner
Type approval countries/countries with special requirements B02 Type approval Belgium
Weight category front axle L13 Suspension range 13 installation control only, no requirement forecast
Wheels C3H Cast alloy wheels 6J x 15 "A-Light", offset 38 (1J0 601 025 P)
P04
PJ1
PSF
Front seats Q4P Sports front seats
Nameplates for sales name QD2 Nameplates for sales name
WBV
WKA
Country-specific product program X2A National sales program Belgium Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
Kolego Vin dziekuje za pomoc i mam jeszcze seata do rozkodowania vsszzz6lz3r236543
Witam po raz pierwszy na forum.
Mam ogromną prośbę o rozkodoawnie Passata B5 FL WVWZZZ3BZ4E231213.
Z góry dziękuje i pozdrawiam
Witam , czy ma ktoś możliwość sprawdzenia mojego Vin-u , ponieważ w internecie wychodzą mi chyba z 3 różne wersję ,\
WVWZZZ1HZVW067576 , może da rade ustalić jaki ma silnik , o jakim oznaczeniu ,
Zapraszam do oceny , i dawania nowych pomysłów.
Kod: Zaznacz cały
Vehicle Identification No. VSSZZZ6LZ3R236543
Model Designation ibiza sport
Date of production 16.04.2003
Model year 2003
Sales type 6L1524
Engine code ATD
Transmission code GGU
Axle drive 5S
Interior trim code DY
Roof color Z4
Additional instruments 8LA Without additional instruments/switches
Additional warning lights 9TA Without additional warning lights
Air cleaner (engine) 1L0 Standard air cleaner
Backrest release 5B0 Backrest release for left front seat right front seat w/ "Easy Entry" funct.
Body measures 5C7 Additional body measures
Body treatment 6J1 Special body treatment
Brake type, front 1LQ Front disc brakes with integrated adapter
Braking systems 1AP Electronic Stability Control (ESC) with electromechanical brake booster
Bumper 2JG Body-colored bumpers
Cd enhancing underbody panel 2D0 Without cd enhancing underbody panel
Center high-mounted stop light 8R1 Center high-mounted stop light
Center sun visor GA0 Without center sun visor
Component part sets with country-specific design requirements B0X Component parts set, complying with vehicle type for Germany, various parts
Cruise control warning and speed limit system 6Y0 Without cruise control warning system
Cup holder 4M0 Without cup holder
Dashboard 4N6 Dashboard with deleted option
Door and side trim panels 3LE Door and side trim panel
Doors 0A1 2 doors
Engine cover NM1 Engine cover
Engine specifications MS7 4-cyl. turbo diesel eng. 1.9 L/74 kW TDI pump-jet injection system Base engine is T5X/T21/T71
Equipment levels A8F Sports equipment
Exterior noise suppression measures 2B2 Additional exterior noise suppression
Frame forestructure AC1 Long frame forestructure
Fresh air intake for passenger compartment (with particulate filter) 2V1 Dust and pollen filter
Front license plate bracket 6W0 Without license plate bracket front
Front stabilizer 0AQ Front stabilizer
Fuel filler cap/door, locking option 2W1 Lockable fuel filler cap
General operating permit, alterations C08 Operating permit, alteration
Glove compartment 4Z4 Glove compartment door without light
Grab handles at roof frame 5N3 Folding grab handles
Heated rear window 8P1 Heated rear window
Horns 8Y4 High-sounding horn
Interior light in driver compartment 9GB Interior light with switch-off delay and door pillar switch
Left vanity mirror 4SJ Without left vanity mirror, but pocket in sun visor
Luggage compartment lining 5A6 Full fleece trunk lining
Luggage net/pocket on backrest(s) 4U3 Luggage net on backrest, right seat
Molding roof liner 6NA Unsplit molding roof liner
Nameplate set 2VP Nameplate set "TDI" "I"
Pillar lining 4XC Exterior pillar lining
Platform group class 7PB Platform group class 2
Platform module floor pan, rear 4P2 Rear floor panel module, type 3
Radiator grille 6KA Radiator grille
Radios 8YE Radio for comfort-class vehicle
Reading light 8S0 Without reading light
Rear axle 0N7 Heavy-duty rear axle (design 2)
Rear license plate bracket 6P0 Without license plate bracket rear
Rear spoiler 5J4 Body-colored rear spoiler
Restraint systems, front 4QV 3-point seat belts with electric tensioner and height adjustment, front
Right vanity mirror 4TC Right vanity mirror with cover
Seat covering N0D Fabric seat covering
Shock absorption, chassis, front G19 Front shock absorption
Shock absorption, chassis, rear 1JE Rear sports shock absorption
Smoking/non-smoking package 9JD Smoking package, ashtray front
Steering wheels 2PH Leather steering wheel
Tires H2J Tires 205/45 R16 83W
Vehicle class differentiation units/platform components 0CY Vehicle class differentiation 6L0
Weight category front axle L40 Suspension range 40 installation control only, no requirement forecast
Wheel housing liners KG2 Wheel housing liner front and rear
Wheels C2P Alloy wheels 6.5J x 16
Windshield wiper arms/blades 9PB Windshield wiper arms/blades with additional guide vanes
PC2
PH1
PJ3
PLE
Air duct, front area VK1 Air duct, type 1
Base engine T5X 4-cylinder diesel engine 1.9 L unit 038.L
Drawers under front seats QN2 Drawer under right front seat
Foot area lining QM1 Foot area lining with cover
Front seats Q4H Comfort sports seats, front
Vehicle Identification No. WVWZZZ3BZ4E231213
Model Designation passat estate
Date of production 16.01.2004
Model year 2004
Sales type 3B6262
Engine code AVF
Transmission code GVS
Axle drive 6S
Interior trim code MX
Roof color 8E
Exterior color / Paint Code 8E / A7W
Additional body covers, side 6EP Additional stone guard body covers
Anti-theft protection system 7AH Electronic vehicle immobilization device with alarm system, passenger compartment control and backup horn
Batteries J1D Battery 380 A (72 Ah)
Body style K8D Station Wagon Variant/Avant
Brake type, front 1ZC Disc brakes, front (Geomet D)
Center rear seat belts 3C3 Lap belt with retractor for the center rear seat
Component part sets with country-specific design requirements B0J Component parts set, complying with vehicle type for Italy, various parts
Door and side trim panels 3LJ Door and side trim panel in foam film, insert in leatherette
Double-size standard radio/dual-view display 2T0 Without double-sized standard (DIN)
Duty-free tires 1V0 Without duty-free and cost-free tires
Emission standard 0GZ Emission standard EU3, diesel with EOBD
Flame retardent materials 4Q0 No flame retardent materials
Floor coverings 3MQ Ibolours floor covering
General operating permit, alterations C11 Operating permit, alteration
Insert for the filling up of unleaded fuel/fuel type 2G0 Without insert for the filling up of fuel
Installation parts for engine (engine mount system) 1VG Installation parts for four-cylinder engine
Luggage compartment floor covering 6SL Tufted trunk floor covering (cut pile)
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Mass damper for steering wheels 1Q1 Mass damper for steering wheel, 26.5Hz
Moldings 4ZB Bright moldings
Owner's manuals 0VG Information kit in Italian
Paint coating FB3 Surface, interior trim, soft-touch paint
Parking light indicator light 8NA Without parking light warning light
Radios 8AR Radio "gamma" with removable operating panel
Reading light 8S4 Two reading lights front, two rear
Roof rails/roof load rack 3S5 Black roof rails
Safety certificate 0LK Special plates/stickers/ safety certificates for Italy
Seat covering N7J Part leather seat coverings, seat insert with hole pattern
Shock absorption/suspension, chassis 1BA Standard suspension/shock absorption
Side lights 8F2 Side turn signal lights
Socket 7B3 12-volt socket(s)
Special labels/plates 0SK Labels/plates in Italian
Transmission shafts 1WD Transmission shaft for tripod joints
Transmission shafts, rear axle 1YA Without transmission shafts f. rear axle
Transmission types/gearshift mechanisms 0G1 Gearshift lever
Type approval countries/countries with special requirements B14 Type approval Italy (San Marino, Vatican City)
Vehicle class differentiation units/platform components 0DE Installation differentiation for build status of vehicle class B5 (VW Passat)
Weight category front axle 0JJ Weight category front axle weight range 9
Weight category rear axle 0YF Weight range 6 installation control only, no requirement forecast
Wheel covers 1NA Without wheel covers
Wheels C4Q Alloy wheels 8J x 18
Window regulator 4R3 Power windows with comfort operation
PH2
PJ2
RCH
Hands-free system VX0 Without hands-free system
WEI Nie mam dostępu do historii serwisowej, nie sprawdzam numerów na PW, nie pisać.
adek94 pisze:Witam , czy ma ktoś możliwość sprawdzenia mojego Vin-u , ponieważ w internecie wychodzą mi chyba z 3 różne wersję ,\
Korzystając z darmowych dekoderów typu automo.pl za przeproszeniem kupa ustalisz, one są po prostu losowe, nawet często w płatnych odmianach nic mądrego nie podadzą.
Kod: Zaznacz cały
Vehicle Identification No. WVWZZZ1HZVW067576
Model Designation golf cl estate
Date of production 13.06.1996
Model year 1997
Sales type 1H5234
Engine code 1Z
Transmission code CTN
Axle drive 5S
Interior trim code 47
Roof color C3
Exterior color / Paint Code C3 / R5V
Additional body covers, side 6ED Additional body cover on wheel arch and side sill for bumper without skirt
Ashtray light 8PB Ashtray light
Brackets 3P0 Without bracket for first aid kit and warning triangle
Brake type, front 1LY Disc brakes, front
Brake type, rear 1KM Drum brakes, rear
Braking systems 1AG Nine-inch power brake
Bumper 2JE Partially painted bumpers
Clutch actuation 1K2 Hydraulic clutch actuation
Component part sets with country-specific design requirements B0B Component parts set, complying with vehicle type for Austria, various parts
Dashboard 4N1 Padded dashboard
Door and lid locking system 4F1 Central locking system
Door and side pockets, rear 4YB Stowage box rear (door and side panel)
Door and side trim panels 3LV Door and side trim panel for special editions
Door pockets, front 3YH Door pockets, front
Doors 0A2 4 doors
Engine specifications M2K 4-cyl. turbo diesel eng. 1.9 L/66 kW TDI and MVEG 2 base engine is T2F
Equipment levels A8C Comfort equipment
Exterior noise suppression measures 2B5 Additional exterior noise suppression
Front fog light/additional headlight 8WH Front fog lamp and cornering lamp
Front spoiler 5L1 Front spoiler
Front stabilizer 0AF Front stabilizer
Front turn signal lights 6Z2 White turn signal lights
Fuel tank treatment 2LA Fuel tank without special material treatment
Fuel tank vent line 1TE Fuel tank vent line with gravity valve and second vent line with PVC breather hoses
Gearshift boot/cover 6R3 Rubber gearshift boot
Gearshift knob/handle 6Q4 Comfort gearshift knob/handle
Glove compartment 4Z2 Lockable glove compartment door
Headlight 8BU Halogen headlight for driving on the right
Headlight-range adjustment 8Q0 Without headlight-range adjustment
Heating and air conditioning system 9AB Manually controlled air conditioning
Identification plates 1EJ Special identification plate
Interference suppression 8E0 Without interference suppression
Interior noise suppression measures 3W0 Without additional noise suppression measures for passenger compartment
Key for locking system 8QC Key with light
Label for brake-proportioning values 0Q0 Without label for brake-proportioning values
Lashing rings/rails for load restraint 6B1 Lashing rings for load restraint
Left exterior mirror 3BS Left exterior mirror: aspherical, electrically adjustable and heated
Luggage compartment cover 3U2 Sliding trunk cover
Nameplate set 2QY Nameplate set "TDI" in base trim
Night vision system 9R0 Without night vision system
Outer rear seat belts 3ZE 3-point seat belts, outer rear with height adjustment and ECE label
Proportioning valve 1H1 Load-sensitive proportioning valve
Protective side molding 4B3 Protective side molding
Rear axle 0N2 Heavy-duty rear axle
Rear fog light 8TF Rear fog lights, left and right
Rear stabilizer 0BA Without rear stabilizer
Right exterior mirror 3AF Right exterior mirror: convex, electrically adjustable and heated
Roof rails/roof load rack 3S2 Black roof rails
Seat covering N2Z Seat covering for special editions
Side air bag 4X0 Without side air bag
Side assist/lane departure warning 7Y0 Without lane change assistant
Special editions E3A "Rabbit"
Steering column systems 2C1 Height adjustable steering column
Steering wheels 2PY Steering wheel for air bag system (RoW) (lightweight design)
Tires H0L Tires 195/60 R14 H
Type approval countries/countries with special requirements B12 Type approval Austria
Vehicle class differentiation units/platform components 0DG Installation differentiation for build status of vehicle class A3 (VW Golf/ Vento/Variant), unit components
Wheel covers 1NH Full wheel covers
Wheels C2N Alloy wheels 6J x 16
Windshield wiper intermittent control 8N2 Windshield wiper intermittent control infinitely variable
PN1
Base engine T2F 4-cylinder diesel engine 1.9 L unit 028.C
Front seats Q1A Standard front seats
Instrument inserts U1L Instrument insert w/ km/h speedometer, clock, tachometer and special color trim
witam jestem tu nowy i mam prośbe czy ktos rozkodował by moj vin WVWZZZ1HZSP510276 z góry dziekuje za pomoc
koledzy, mozecie rozkodowac toledo II?
VSSZZZ1MZXB013672
VSSZZZ1MZXB013672
