potrzebny schemat Elektryczny silnika ARL
- Gobo90
- Forumowy spamer :)
witajcie potrzebuje schemat podłączenia wszystkich czujników itd w silniku ARL najlepiej jakis opis wszystkich złączy w kompie i schematy macie coś takiego może ?
- leo...
schemat szafy z seata leona 2003 ...
32-pin connector, blue
1 - Terminal 15, positive
2 - Right indicator warning light
3 - Output signal from electronic speedometer
4 - Trailer indicator light
5 - Fuel gauge
6 - Airbag (conventional)
7 - Terminal 31, electronic earth
8 - Coolant temperature gauge
9 - Terminal 31, earth
10 - High oil pressure switch
11 - Not used
12 - Alternator warning light, terminal 61
13 - Free
14 - Rear fog light warning lamp
15 - Sidelight
16 - Tailgate/luggage compartment open contact (only in some countries)
17 - Mainbeam warning light, terminal 57a
18 - Left indicator warning light
19 - Free
20 - Instrument panel lighting, terminal 58d
21 - Driver door contact
22 - Coolant level indicator
23 - Terminal 30, positive
24 - Terminal 31, earth
25 - Self-diagnosis / cable K
26 - Right sidelight
27 - Left sidelight
28 - Input signal from electronic speedometer
29 - Brake fluid level
30 - S Contact:
31 - Seat belt warning system
32 - Free
32-pin connector, green
1 - Not used
2 - Coil reader for immobiliser 1
3 - Free
4 - Data BUS display (CAN), engine
5 - Cable W
6 - Windscreen washer fluid level
7 - Brake pad wear
8 - Free
9 - Free
10 - Free
11 - Time vehicle stopped signal
12 - Air conditioning off signal
13 - Handbrake indicator light
14 - Free
15 - Free
16 - Free
17 - Coil reader for immobiliser 2
18 - Oil level/oil temperature signal (WIV)
19 - Data BUS (CAN), High signal, engine
20 - Data BUS (CAN), Low signal, engine
21 - Free
22 - Bonnet switch contact (VIW)
23 - MFA - Left
24 - MFA - Right
25 - MFA - Reset
26 - Exterior temperature signal
27 - Data BUS (CAN) output, High signal, engine
28 - Data BUS (CAN) output, Low signal, engine
29 - Data BUS (CAN) output display, engine
30 - Free
31 - Free
32 - Free
10-pin connector, for multifunctional display
2 - Outside temperature input signal
3 - Outside temperature input signal
4 - Lighting, terminal 58d
5 - RDS signal
6 - Terminal 31, earth
7 - Vehicle speed signal
8 - RDS signal
9 - °C/°F indicator
10 - Clock signal
5 - Fuel gauge
11 - Not used
13 - Free
15 - Sidelight
19 - Free
27 - Left sidelight
30 - S Contact:
32 - Free
1 - Not used
3 - Free
5 - Cable W
7 - Brake pad wear
8 - Free
9 - Free
10 - Free
14 - Free
15 - Free
16 - Free
21 - Free
23 - MFA - Left
24 - MFA - Right
25 - MFA - Reset
30 - Free
31 - Free
32 - Free
5 - RDS signal
8 - RDS signal
9 - °C/°F indicator
10 - Clock signal
