jakość i moc??
Type-monoblock
Class-AB
4 ohm stereo-N/A
2 ohm stereo-N/A
4 ohm mono-250 watts RMS
2 ohm mono-500 watts RMS
Max power-1000 watts
Frequency response-20Hz – 300Hz
SNR-99dB
THD-0.15%
Bass boost-0 – 24dB
HPF-45hz – N/A
LPF-45Hz – 35hz – 250Hz
Input mode-2 channel
Subsonic filter-16Hz – 80Hz variable
Remote control-Included
Line out-2 channel
Phase switch-0 - 180 degrees
LED voltage display-included
Height-55mm
Width-400mm
Depth-250mm
Co o tym sadzicie? z gory dzieki
