-głośnik VIBE BLACK AIR 12
Speaker Size : 12″
RMS Power : 550 w
Peak Power : 1600 w
Minimum Input : 275 w RMS
Sensitivity : 89 db
Freq. Response : 25 Hz – 1.5 khz
Impedance : Dual 2 Ohm
Mounting Depth : 170 mm
Mounting Diameter : 285 mm
Voice coil diameter : 7.5 mm
Voice coil : 2″ aluminium 4 layer
Magnet weight : 50 Oz
Magnet rating : Y35
X-max : 10mm
Recommended Enclosure Volume : 1.5 – 2 cubic feet
Recommended Amplifiers : BlackBox S2 / S4 / B1
- radio Alpine CDE-9846R
- wzmacniacz Magnat RX mono
Moc RMS, 1 Ohm 1 x 700W
Moc RMS, 2 Ohm 1 x 500 W
Moc RMS, 4 Ohm 1 x 350 W
-kondensator Carpower CAP-10 1F
-kable dietz 50mm2
