Witam, po sprawdzeniu VIN tej erki
https://www.otomoto.pl/oferta/volkswage ... yOnq5.html" onclick="window.open(this.href);return false;
Wychodzi mi ze to kombi, niby moc się zgadza, ale jest bardzo mało danych
VIN WVWZZZAUZFW018905
Dziwne rezultaty po sprawdzeniu VIN Golfa 7R
Moderatorzy: G0 Karcio, zlos, VIP
Nr nadwozia WVWZZZAUZFW018905
model golf 2,0 r 4motion
bluemotion technology
GOLF
Data produkcji 17.06.2014
Rok modelowy 2015
typ handlowy 5G1RXR
Kod silnika CJXC
Kod przekładni QSP
numer napedu osiowego 6A
Wyposazenie TW
kolor dachu 0R
kolor zewnetrzny / numer koloru 0R / 0K1
Charism" 2H4 Driving profile selection and hydr.
damper control
Activated carbon canister 1E1 Activated carbon canister
Additional child seat anchors 3B4 Child seat anchor for
child seat system ISOFIX
Additional tires (snow tires) 2WA Without additional tires
Additional warning lights 9TC Additional reflectors (door area)
Airbag 4UP Driver's and front passenger air bag
with knee air bag and front passenger
air bag deactivation
Alternative drive system 0K0 Without alternative drive module
Alternators 8GV Alternator 180 A
Antennas 8ZH Antenna for AM/FM reception, "diversity"
Area monitoring systems 6K3 Front Assist incl. city automatic
emergency braking for ACC low
Audio-response system/voice control QH1 Voice control
Auxiliary heater 9M0 Without auxiliary/parking heater
Backrest release 3H9 Backrest release for front seats with
"Easy Entry"
Base engine TT6 4-cylinder SI engine 2.0 l
unit 06K.C
Batteries J0T Battery 360A (69Ah)
Battery/alternator capacity NY0 Standard battery/alternator capacity
Body measures 5C0 Without special body measures
Body style K8G Hatchback
Brake pad wear indicator 9U1 Brake pad wear indicator
Brake systems 1AZ Electronic stabilization program (ESP)
Brake type in rear 1KY Disc brakes, rear
Brake type, front 1LM Disc brakes, front
Breakaway interior rearview mirror 4L6 Breakaway interior rear view mirror,
automatically dimming
Bumpers 2JF Painted bumpers
Camera systems/accident sensors KA1 With rear view camera system (type 1)
Camera/distance sensor QK0 Without camera without distance sensor
(driver assistance system)
Carrier frequency for radio remote control 5D1 Carrier frequency 433.92 MHz-434.42 Mhz
CD ROM/DVD/SD card 77G Data storage device for EU, integrated
CD/DVD drive and SD card slot EC6 With DVD drive and two SD card slots
Center armrest 6E3 Front center armrest
Center console 3D3 Center console
Center rear seat belts 3C7 3-point seat belt for center rear seat
Charging cable EV0 Without charging cable
Chrome package QJ3 Chrome package
(type 2)
Climatic zones 0Y1 Standard climatic zones
Compass/road sign display QR8 Without traffic signs recognition
Component part sets with country-specific design requirements B0A Component parts set without
Components with special surface appearance 6FH Exterior mirror housings painted
Control number (no PR family) S0T Pre-production series/SOP next MY
Cruise control system 8T8 Adaptive Cruise Control
(w/ "Follow-to-Stop") and Speed Limiter
Customized installation FC1 Customized installation
Delivery equipment 2A0 Without delivery equipment
Differential lock 1Y3 Differential lock (XDS)
dynamic traction control
Direct tire pressure monitoring system 7K1 Tire pressure warning light
Door and lid locking system 4F2 Central locking system "Keyless Entry"
Door and side trim panels 3LE Door and side trim panel
Doors 0A1 2 doors
Drawers under front seats QN3 Drawers under front seats
Drive layout 1X1 Four wheel drive
Driver alert system EM1 Rest Assist (drowsiness detection)
Driving on the left/on the right AV1 Driving on the right
ECO function for driving profiles and Drive select EF1 ECO function
Electric interface for external use UI4 Electric interface for external use,
AUX-IN, USB (iPod-capable)
Electronic engine sound measures GM1 Standard outside sound
Emissions standard 7MM Emission standard EU6 plus
Engine cooling system 8Z5 Not hot country
Engine specifications DS4 4-cylinder SI engine 2.0 l/221 kW
TFSI, homogeneous
base engine is TT6
Equipment levels A9R Top sports
Exhaust tailpipe 0P4 Exhaust tailpipe, double-flow
Extended safety system 7W1 With extended safety system
(Pre-Crash Basic)
Exterior mirror setting 6XR Exterior mirrors: with memory function,
electrically adjustable, separately
heated
Fire extinguishers 6A0 Without fire extinguisher
First aid kit / warning triangle 1T2 Warning triangle
Floor mats 0TD Front and rear floor mats
Folding table 1U8 W/o folding table on front seat backrest
Follow-on warranty EA3 1 year subsequent warranty,
max. 90000 km
Fresh air intake for passenger compartment (with particulate filter) 2V5 Fresh air intake system with activated
charcoal canister
Front fog lamp/additional headlamp 8WA Without front fog light
Front license plate carrier 6W1 Front license plate carrier (large)
Front seats Q4P Sports front seats
Front stabilizer 0AE Front stabilizer
Front underbody guard 1SA Without additional front underbody guard
Fuel quantity for initial filling 1Z0 Initial standard fuel filling
Fuel systems 1A7 Fuel system for fuel-injected engine
(tropicalized)
Gearshift knob/handle 6Q6 Aluminum gearshift knob/handle
General operating permit, alterations C11 Operating permit, alteration
Hand brake lever handle 6PB Without hand brake lever handle
Head restraints 5ZF Front headrests
Headlamp washer system 8X1 Headlight washer system
Headlamps 8IM Gas discharge headlights with
dynamic bending light
Headlight control 8K3 Separate daytime running lights with
low beam assistant and "Coming Home"
feature
Headlight range control 8Q5 Headlight-range adjustment, automatic/
dynamic with dynamic bending light
(AFS 1)
Heat accumulator system/auxiliary heater 7E0 W/o heat accumulator/auxiliary heating
Heated washer nozzles 9T1 Heated washer nozzles, front
Heating and air conditioning system 9AK Climatronic with impact pressure
control free of cfc
Heavy-duty/sports version 2UK Controlled chassis
sports version
Horns 8Y1 Two-tone horn
Hybrid drive 20A Without electric motor ( hybrid )
Identification plates 1EX Special identification plate for EC
for M1 passenger vehicle
Insert for the filling up of unleaded fuel/fuel type 2G7 Filler neck module 1 with insert
Inserts 5TD Decorative aluminum inserts
Installation differentiation for vehicle components 0ES Installation differentiation for
transmission DQ250
vehicle components
Instrument clusters U5A Instrument insert, km/h speedometer
Interior light in footwell 6T1 Interior light in footwell
Lane change assist/lane keeping system 7Y0 Without lane change assistant
Left exterior mirror 5SL Left exterior mirror: aspherical
License plate lighting KL1 LED license plate lighting
Light control systems 8G0 Without light assistant
Light package (lighting) QQ3 Ambience and environment lighting
Lockable wheel bolts 1PE Wheel bolts with anti-theft protection
(unlockable)
Luggage compartment cover 3U1 Foldable trunk cover
Luggage net/pocket on backrest(s) 4U5 Luggage pockets on backrest
Lumbar support 7P4 Manually adjustable lumbar support in
front seats
Manufacturing sequence differentiation 0FA Standard manufacturing sequence
Mass damper for steering wheels 1Q2 Mass damper for steering wheel, 36 Hz
Molding roof liner 6NW Unsplit molding roof liner
Moldings 4ZE Black moldings
Multi-function display/trip computer 9S6 Multi-function display/on-board computer
"Colour"
Nameplate set 0PJ Nameplate set "R20"
(without model designation)
Navigation device 7UG Navigation system - High
Online services EL0 Without online service
Operating voltage 9Z0 Operating voltage 12V
Outer rear seat belts 3ZB 3-point seat belts, outer rear with ECE
label
Owner's manuals 0VT Information kit in Polish
Paint coating FB0 Standard paint coating
Paint preservative/transit coating 5K7 Transport protection film (minimum
protection) with additional transport
protection measures
Park distance control 7X2 Park distance control, front and rear
Parking brake UH2 Parking brake
Partition 3CA Without partition
Pedal cluster VF1 Pedal cluster
Pedestrian protection VL1 Extended pedestrian protection measures
Platform module, luggage compartment floor 4P0 Rear floor panel module, type 1
Preparation for sound combination for rotating beacon 9F0 Without sound combination for rotating
emergency light and radio antenna
preparation
Preparation for two-way radio installation 9D0 Without preparation for two-way radio
installation
Radiator grille 6KQ Radiator grille
Radios I8G High radio (Gen1)
Reading light 8S6 Two reading lights front
Rear axle 0N4 4-link rear suspension
Rear combination lamps 8SP LED taillamp assembly
Rear fog lamp 8TB Rear fog light
Rear head restraints 3T2 Three rear headrests
Rear license plate carrier 6P0 Without rear license plate carrier
Rear luggage/load compartment floor 3GN Variable cargo area concept
Rear seat catch UK1 Standard rear seat release
Rear seats 3NU Rear seat bench unsplit, backrest split
folding with center armrest
Rear spoiler 5J4 Body-colored rear spoiler
Rear stabilizer bar 0BG Rear stabilizer
Rear window wiper and washer system 8M1 Rear window wiper and washer system
with intermittent control
Refrigerant KK1 Refrigerant R134a
Refrigerator 1W2 Glove compartment cooling system
Regional code for radio ER1 Regional code " ECE " for radio
Restraint systems, front 3QT 3-point seat belts with tensioner and
height adjustment, front
Right exterior mirror 5RQ Right exterior mirror: convex
Roof insert/convertible top 3FB Spoiler roof
Roof rails/roof load rack 3S0 Without roof rails/roof load rack
Scuff plates 7M7 Scuff plates in door apertures
Seat adjustment 3L3 Manual height adjustment for front seats
Seat belt check 9P3 Seat belt reminder, electric contact in
buckle
Seat heater 4A3 Seat heater for front seats
separately controlled
Seat trim covers N6L Leather seat coverings
Service indicator QI6 Service indicator 30,000 km or 2 year
( variable )
Service interval prolongation QG1 Service interval prolongation
Side airbag 4X3 Side air bag front with curtain air bag
Side and rear windows 4KF Side windows in heat-insulating glass,
from B-pillar and rear window dark
tinted
Smoker's/non-smoker's package 9JA Non-smoking package
Socket 7B2 12-volt socket in luggage boot
Spare wheel/breakdown kit 1G9 Space-saving spare wheel for temporary
use, radial tire
(5-hole)
Speaker installation 8RM 8 speakers (passive)
Special editions E0A No special edition
Special labels/plates 2KW Labels/plates in German, French, and
Dutch
Special registration measures 3M0 Without special measures
Start-stop system/regenerative braking 7L6 Start/stop system with regenerative
braking
Steering QZ0 Speed-related variable steering assist
(Servotronic) w/ reduced steering height
Steering system arrangement L0L Left-hand drive vehicle
Steering wheels 2FW Leather trimmed multi-function sports
steering wheel w/ Tiptronic
Storage compartment package QE0 Without tray areas package/box
Sun visors 5XI Sun visors with mirror, illuminated,
airbag label on sun visor
Suspension system in front G04 Front shock absorption
Suspension system in rear UB9 Rear shock absorption for sports design
Telephone / telematics 9ZK Telephony (rSAP)
Theft protection system 7AS Anti-theft alarm system, passenger
compartment control, backup horn and
towing protection
Tire suppliers V0A Tires w/o specification of tire brand
Tires H13 Tires 235/35 R19 91Y
Tool kit and jack 1S1 Tool kit and jack
Trailer hitch 1D0 Without trailer hitch
Transmission specifications G0R 6-speed automatic transmission for
four-wheel drive vehicle
Tray 7N3 Comfort tray on roof liner
TV reception/digital radio reception QV0 W/o TV reception/digital radio reception
Type approval countries/countries with special requirements B17 Type approval Poland
Vehicle class differentiation units/platform components 7LG Vehicle class differentiation -5G0-
Vehicle inlet ES0 Without vehicle inlet
Vehicle specifications F0A No special purpose vehicle, standard
equipment
Versions FM0 Basic equipment variant
Washer fluid level indicator 8W1 Washer fluid level indicator
Weight category front axle L35 Suspension range 35
installation control only, no
requirement forecast
Weight category rear axle 0YB Weight range 2
Wheel covers 1NL Covers for alloy wheels
Wheelbases 0B1 Wheelbase
Wheels C2T Alloy wheels 8J x 19
Window regulator 4R4 Power windows with comfort operation and
circuit breaker
Windshield glass type 4GW Heat insulating windshield
Windshield wiper intermittent control/ light/rain sensor 8N6 Windshield wiper intermittent control
with light/rain sensor
PDD Zawieszenie z adaptacyjną regulacją DCC
PI9 Obręcze aluminiowe "Cadiz" 8J x 19
PKS Heated (without wires) and
infrared-reflecting windshield
PLA Pakiet "Czujnik deszczu"
PS1 Dach szklany, panoramiczny
W32 Pakiet "Business"
W91 Aktywny tempomat ACC z systemem Front
Assist, podgrzewaną szybą przednią i
instalacją telefoniczną
WDA System "Park Pilot" - czujniki
parkowania z przodu i z tyłu z
wizualizacją odległości na ekranie radia
WL6 Tapicerka skórzana Nappa Carbon
WW1 Pakiet "Zimowy"
ZND System nawigacji satelitarnej "Discover
Pro"
GOLF
Rok modelowy 2015
typ handlowy 5G1RXR
Kod silnika CJXC
Kod przekładni QSP
Wyposazenie TW
kolor dachu 0R
damper control
"Easy Entry"
unit 06K.C
(type 2)
Doors 0A1 2 doors
TFSI, homogeneous
base engine is TT6
(Pre-Crash Basic)
heated
max. 90000 km
charcoal canister
(tropicalized)
feature
(AFS 1)
control free of cfc
sports version
transmission DQ250
vehicle components
(unlockable)
front seats
"Colour"
label
protection measures
preparation
installation
buckle
( variable )
tinted
use, radial tire
(5-hole)
Dutch
braking
towing protection
equipment
circuit breaker
WW1 Pakiet "Zimowy"
Pro"
