[inny] vw touran 1.6 tdi
Wszelakie info dotyczące diagnostyki,takie jak np.oceny logów itp.
Moderatorzy: italiano_83, G0 Karcio, Haki, Qto, marcin7x5, VIP
pucek007
Auto: Audi a6 c7
Post autor: pucek007 » wt sie 21, 2018 19:39
Witam vw po dzwonie z jeleniem, wrocil z naprawy sprawdzony vcds-em i takie o to bledy.Prosba o rozszyfrowanie :pub:
Model samochodu touran
Rodzaj silnika 1.6 TDI
Oznaczenie silnika
Rok produkcji 2011
edit:: czujniki ogarniete , problem z airbagiem i klaksonem.
Tuesday,21,August,2018,19:07:11:10074
VCDS Version: Beta 11.6.0
Data version: 20111008
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 18 19 25 42 44 46 52 56 61 62 69 72
77
VIN: WVGZZZ1TZCW015659
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: None
Part No SW: 03L 906 023 PH HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 6940
Revision: --H43--- Serial number: 00000000000000
Coding: 00194034032401080000
Shop #: WSC 01324 020 00200
ASAM Dataset: EV_ECM16TDI02103L906023PH 003009
ROD: N/A
VCID: 7BF1F3DF4125
No ASAM data for: "EV_ECM16TDI02103L906023PH" (VW36)
1 Fault Found:
6260 - ROD - Unknown Error Code
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Mileage: 241026 km
Date: 2080.14.24
Time: 20:09:33
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 323B401609230EFF4C1102E990227051310000
VCID: 7BF1F3DF4125
No fault code found.
Address 08: Auto HVAC (J301) Labels: None
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004003
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7F0907CF553D
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 F HW: 5K0 937 084 F
Component: BCM PQ35 B 011 0048
Revision: BA011001
Coding: 40180A3880251AE0400800C0140000E44B518E08426DA1606480C7000041
VCID: 356525E72781
Subsystem 1 - Part No: 1T1 955 119 A
Component: Wischer 28061 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH
Component: RLS 010711 05 54 0403
Coding: 0230ED
3 Faults Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 6
Fault Frequency: 1
Reset counter: 93
Mileage: 241026 km
Time Indication: 0
Date: 2016.14.25
Time: 10:09:04
Freeze Frame:
Term 15 Off
Voltage: 12.20 V
OFF
ON
OFF
OFF
OFF
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 124
Reset counter: 114
Mileage: 235979 km
Time Indication: 0
Date: 2015.14.16
Time: 17:16:53
Freeze Frame:
Term 15 Off
Voltage: 13.05 V
OFF
ON
OFF
OFF
ON
02394 - Parking Light Left Front (M1)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 13
Reset counter: 114
Mileage: 240405 km
Time Indication: 0
Date: 2016.14.19
Time: 19:11:27
Freeze Frame:
Term 15 On
Voltage: 13.10 V
ON
ON
ON
OFF
OFF
Address 10: Park/Steer Assist
Cannot be reached
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 E HW: 1T0 909 605 E
Component: 02 AIRBAG VW8 022 0100
Revision: 02022000 Serial number: 003K4D03KY3E
Coding: 0012338
VCID: 37792FEF3D8D
1 Fault Found:
00588 - Airbag Igniter; Driver Side (N95)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 BF HW: 5K0 953 569 J
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110705200050
Coding: 5180140000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS_VW36.rod
VCID: 6FE9D78F055D
5 Faults Found:
147465 - Terminal 15
B1148 14 [008] - Component Failure
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 93
Mileage: 241026 km
Date: 2080.14.24
Time: 20:09:30
226827 - Turn Signal Switch
B1144 13 [008] - Reserved by ISO 15031-6:2005
Freeze Frame:
Fault Priority: 2
Fault Frequency: 50
Reset counter: 93
Mileage: 241026 km
Date: 2080.14.24
Time: 12:56:51
226839 - Turn Signal Switch
B1144 11 [008] - Voltage Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 241026 km
Date: 2080.14.24
Time: 14:26:43
227339 - Windshield Wiper Switch
B1145 13 [008] - Reserved by ISO 15031-6:2005
Freeze Frame:
Fault Priority: 2
Fault Frequency: 47
Reset counter: 93
Mileage: 241026 km
Date: 2080.14.24
Time: 12:56:51
227355 - Windshield Wiper/Washer Switch
B1149 13 [008] - Resistance Too High
Freeze Frame:
Fault Priority: 3
Fault Frequency: 47
Reset counter: 93
Mileage: 241026 km
Date: 2080.14.24
Time: 12:56:51
Address 17: Instruments (J285) Labels: None
Part No SW: 1T0 920 875 A HW: 1T0 920 875 A
Component: KOMBI H04 0607
Coding: 181B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 356525E72781
2 Faults Found:
12718592 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 93
Mileage: 241026 km
Date: 2080.14.25
Time: 10:09:02
12671232 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 225
Mileage: 235966 km
Date: 2079.14.16
Time: 14:43:37
Address 18: Aux. Heat Labels: None
Part No: 1K0 815 071 N
Component: Zuheizer 030 1312
Revision: A Serial number: 09010046
Coding: 0000011
Shop #: WSC 26158 136 61581
VCID: 306B14F3D8E3
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 280611F1003149
Coding: 358002
VCID: 37792FEF3D8D
2 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 93
Mileage: 241026 km
Time Indication: 0
Date: 2016.14.25
Time: 10:09:01
03075 - Parallel Parking Assistance Control Module (J791)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 225
Mileage: 235966 km
Time Indication: 0
Date: 2015.14.16
Time: 14:43:24
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H04 0607
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EADF469BBEBF
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1T0 959 701 T HW: 1T0 959 701 T
Component: Tuer-SG 009 2121
Coding: 0131253
VCID: 489B5C134073
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.292 1002
Revision: 1AH03733 Serial number: 00111760309801
Coding: 0000258
VCID: 3C7330C304AB
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1T0 959 702 R HW: 1T0 959 702 R
Coding: 0131253
VCID: 47995F2F4D6D
Address 56: Radio (J503) Labels: None
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 032 0079
Revision: 01000001 Serial number: VWZ1Z2L3093614
Coding: 05000400040009
VCID: 72EFDEFB166F
Address 61: Battery Regul. (J840) Labels: None
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: 030B185A
VCID: F1ED51F79369
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2104
Coding: 0131216
Shop #: WSC 01324 020 1012552
VCID: 326F1EFBD6EF
Address 69: Trailer (J345) Labels: 1K0-907-383-MY8.lbl
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H09 0100
Revision: 3A001001 Serial number: 00000150336143
Coding: 410D000100000000
VCID: 306B14F3D8E3
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 A HW: 5K0 959 704 A
Coding: 0131216
VCID: 33611BFF29F5
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 E HW: 7P6 035 730 E
Component: TELEFON H09 2730
Revision: 1B001001 Serial number: 00007660301549
Coding: 0A01000000010101
ASAM Dataset: EV_UHVNA A01015
ROD: EV_UHVNA_VW36.rod
VCID: 346318E32CFB
End ---------------------------------------------------------------------
Wróć do „Diagnostyka”
Użytkownicy przeglądający to forum: Obecnie na forum nie ma żadnego zarejestrowanego użytkownika i 0 gości
