[inny] Nietypowy problem.../Logi
Wszelakie info dotyczące diagnostyki,takie jak np.oceny logów itp.
Moderatorzy: italiano_83, G0 Karcio, Haki, Qto, marcin7x5, VIP
ted1280
Post autor: ted1280 » pn wrz 14, 2020 09:03
Mam nietypowy problem z autem Polo 6r poniewaz wyskakuje ,,lampa alladyna" aczkolwiek nie wiem który z tych błedów moze byc za to odopowiedzialny.
VCDS Version: Beta 11.6.0
Data version: 20111008
Monday,14,September,2020,00:30:00:10074
Chassis Type: 6N0
Scan: 01 03 08 09 15 17 19 25 44 55 56 69 0B
VIN: WVWZZZ6RZCY530932
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (J623-CBZB) Labels: None
Part No SW: 03F 906 070 HE HW: 03F 907 309 J
Component: SIMOS10.22AH10 2684
Revision: --H10--- Serial number:
Coding: 001900D6200400080000
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_ECM12TFS02103F906070HE 004004
ROD: N/A
VCID: 6CD3C083344B
No ASAM data for: "EV_ECM12TFS02103F906070HE" (VW25)
No fault code found.
Readiness: 0110 0101
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 6R0 907 379 AK HW: 6R0 907 379 AF
Component: ESP8.2i front H05 0001
Revision: --------
Coding: 210228E3217000B2842E14E584D300401300
Shop #: WSC 00788 648 00255
VCID: 87191F2F8DED
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 6R0 907 044 H HW: 6R0 907 044 H
Component: Climatronic H11 0711
Revision: V0000000
VCID: 387B2CD33093
1 Fault Found:
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 241
Mileage: 83807 km
Time Indication: 0
Date: 2026.14.05
Time: 08:23:08
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
Part No SW: 7H0 937 089 F HW: 7H0 937 089
Component: BCM T5GP Li4 H50 0251
Revision: BS050001 Serial number: 0465 264110975
Coding: 24B029BF08A10000092008916C2B0FD05A40672F60051041200000010000
Shop #: WSC 124697 483 00190
VCID: 397D29D70B99
Subsystem 1 - Part No: 1K0 955 559 AH
Component: RLS 051011 05 54 0403
Coding: 02302D
Subsystem 2 - Part No SW: 6R0 959 801 AB HW: 6R0 959 801 AB
Component: J386__TSG_FT 008 1621
Coding: 08BC30
Subsystem 3 - Part No SW: 6R0 959 802 AD HW: 6R0 959 802 AD
Component: J387__TSG_BT 008 1621
Coding: 08BC30
Subsystem 4 - Part No SW: 6R0 959 591 B HW: 6R0 959 591 B
Component: J245 PS25.255 H02 0007
Coding: 081001
Address 15: Airbags (J23) Labels: 5K0-959-655.clb
Part No SW: 6R0 959 655 K HW: 6R0 959 655 K
Component: VW10Airbag01K H09 0020
Revision: -------- Serial number: 003GX00WSGRQ
Coding: 00314B
ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
ROD: EV_AirbaVW10BPAVW250_VW25.rod
VCID: 4A9F661B5E7F
Driver's Airbag Crash Sensor:
Serial number: 3575HRB40590Q4PG79GO
Passenger Side Airbag Crash Sensor:
Serial number: 3585HRB40590Q4PG6HGW
Driver's Rear Airbag Crash Sensor:
Serial number: 3515RRB405P0OPMKG1KQ
Passenger's Rear Airbag Crash Sensor:
Serial number: 3525RRB405J0OPMKO90H
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 6R0 920 860 H HW: 6R0 920 860 H
Component: KOMBI H03 0505
Serial number: 00000000000000
Coding: 140C01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
VCID: 397D29D70B99
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 089
Component: GW-K-CAN TP20 H50 0251
Revision: BS050001
Coding: 002000
VCID: F0EB54F39863
1 Fault Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 241
Mileage: 83807 km
Time Indication: 0
Date: 2026.14.05
Time: 08:24:39
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0505
Serial number:
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW25.rod
VCID: EADF469BBEBF
Address 44: Steering Assist Labels: 6Q0-423-156.lbl
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F69178FC5DD
Address 55: Xenon Range (J431) Labels: None
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0112000001000000
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlRegulVWLWRPt_VW25.rod
VCID: F7F96FEFFD0D
Address 56: Radio (J503) Labels: None
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 031 0075
Revision: 01000001 Serial number: VWZ1Z2L3545685
Coding: 05000400020001
VCID: 33611BFF29F5
1 Fault Found:
03138 - Input AUX IN
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 241
Mileage: 83807 km
Time Indication: 0
Date: 2026.14.05
Time: 08:25:27
Address 69: Trailer
Cannot be reached
Address 0B: Sec. Air Heating
Cannot be reached
End ---------------------------------------------------------------------
Bednarus
[inny] Re: Nietypowy problem.../Logi
Post autor: Bednarus » pn wrz 14, 2020 09:53
Odczyt błędów tu nic nie pomoże. Kontrolka ciśnienia oleju świeci ponieważ jest za niskie ciśnienie, spowodowane np.: niskim stanem oleju. Jeżeli poziom jest w porządku, to jest kilka możliwości: uszkodzona pompa oleju nie daje właściwego ciśnienia, zapchany filtr oleju, zapchane sitko na pompie oleju, itp. Może też być uszkodzony czujnik ciśnienia oleju.
xkoksiarzx
Post autor: xkoksiarzx » ndz paź 04, 2020 20:31
Witam serdecznie, potrzebuję login do sterownika silnika VW Golf 3 1.6 8v 75KM AEE 1996r, nigdzie nie mogę znaleźć informacji na ten temat. Bardzo proszę o pomoc.
wesol
Post autor: wesol » ndz paź 04, 2020 20:59
To nie ligi tylko autoscan. Te odczyty błędów musiałby raczej być robione wtedy gdy ta kontrolka się pali aktualnie to raz i dwa raczej z modułu silnika.
Wróć do „Diagnostyka”
